Question about Tablets & eReaders
Had a very serve nose bleed lasted 9 hours that was 4 weeks ago and still not back on my tablets xarelto waiting an appointment from ENT have been having breathing problems ,
Should my tablet battery go dead in two hours?
This is a loaded question... really. It has factors involved.
Are you watching videos, is the brightness all the way on 100? Or is it set on auto. Are you using bluetooth, and other power consuming actions on the tablet?
All of these things weigh in on whether a battery lasts 2 hours or 4....6....8.
If your battery is wearing down in 2 hours. Age of the tablet my constitute a battery replacement. Always wait until a battery is empty before charging it up.
Get an app stopping program. Installed so as to not having apps running in the background, draining your battery without you even knowing it.
I hope this helps a little.
Mar 17, 2016 | Tablets & eReaders
How can I change the battery in m9100 kocaso
Try the follow to see if it will fix it:
There is a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
After performing the power reset on the device the device will behave in one of the following ways:
1. The tablet will turn on like normal.
2. The tablet will show the battery icon only.
3. The tablet will show nothing on the screen at all.
All of these are normal for the device and should not be cause for alarm. If the device still fails to power on after being left on the charger for 4-6 hours,
Then most likely the battery will need replacing.
Here is a link to where you might be able to get a new battery:
Replacement 4000mah Battery for Kocaso M9100 M9000 9 MID All Winner A13...
Jan 23, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
Why won't my zeepad 9xn charge? When I plug it in the indicater light flashes on the off quickly! I just to it not even a week ago
You must first charge your Zeepad for a minimum of 9 hours prior to using it for the first time. Though it may show that it is fully charged after 4 or 5, you must leave it on the charger. When you go to turn it on, you must hold the power button for at least 3 seconds.
Jan 03, 2015 | Tablets & eReaders
I had a notice that there was an important system upgrade about 2 weeks ago. I allowed the update. After that, when I turn the tablet off, it stays off for about 10 seconds and then turns itself back on....
Wait for the next upgrade. They should fix it because you are not the only one, pretty sure. (call them and get their tech support to acknowledge it also, if you can)
Nov 02, 2013 | Samsung Galaxy Tab Tablet PC
My Kindle Fire is losing 97% of charge after 1.5 hours reading. Help?
If it is a FIRE then it may have an app like MAIL running in the back ground. Turn off all apps. It's a tablet, it will only last a few hours.
The eReaders last for weeks, the Tablets last for hours.
If it's an eReader then on the home page search for jfhjfhj - if it says 4 books not indexed then you have 4 books corrupted, go DOWN and delete those 4 books from the kindle and redownload them.
Oct 04, 2013 | Amazon Kindle Wireless Reading Device
Computer wont come on
Did you installed the fjsecs Security Panel Application????...
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/lifebook/LIFEBOOK/E-Series/Security.htm
Read this manual, maybe can help you.
http://solutions.us.fujitsu.com/www/content/pdf/SupportGuides/T4220_UG_B5FJ-4091-02EN-00.pdf page 26
To unlock the machine is completely necessary that you remind the password...
Just pres the display buttons in the order that you selected in the program.
http://static.phing.com/listings/48/481970/2882-8dc5j0_l.jpg
The buttons next to the power button at the right of the display.
There is a microphone symbol next to the buttons....
1 = a and arrow down
2= b and arrow up
3= rotate screen button
4= fn button
ent = alt.
If you selected http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/lifebook/LIFEBOOK/E-Series/images/Screenshots/Image5.jpg
Example:
If you checked the boxes 1234 pres the buttons 123and4 at the same time.
next press ent (ent is next to power button)....
when you press any button that make a beep sound...
If the pass is wrong it will beep constantly for one minute..
other example: 1 - 2 - 14 - 4
in the first just 1 press 1
in the second 2 press 2
in the third 1 and 4 press 1 and 4 at the same time
in the fourth 4 press 4
finally press the button ent.
I hope you can access to your laptop....
Feb 06, 2012 | Fujitsu LifeBook T4220 Tablet PC
Sound problem
Has the audio output been muted? Check for that.
Sep 06, 2017 | Gateway M275 Tablet PC
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
