Question about Russell Hobbs Coffee Makers & Espresso Machines
Russell hobbs coffee maker model no 18623 water comes out slow and there is a big steam build up
SOURCE: Russell Hobbs Steam Glide 2200 won't produce steam.
I had a problem and tracked it down to the pump. If you take the iron apart, the pump sits towards the front of the iron and has 3 tubes connected to it. Remove the srew-down bracket and free the pump from the plastic clasps on the base. Disconnect tubes and wires (remembering where they go.
Remove the circular securing spring from the front of the pump and drop the metal barrel from the housing. Unscrew the rear plastic assembly and set aside. there is a joint inside where the plastic assembly was - this is has an o-ring and is simply a pull-apart. It deos not need screwing. Pull the metal barrel apart, taking care to note the sequence for reassembly. Inside the barel is a larger rubber washer. Pull on the metal tube that goes through the centre of the washer using a pair of pliers - it will come free.
You will then see the problem - the spring inside the metal barrel will have broken. Take care, because at the other end of the spring is a small plastic washer that must be retained. Find a pen that has a short spring inside and use this as a replacement. If necessary, you can trim the spring to make it the right lenght. Ensure you have removed all broken pieces of spring, and reassemble. Try it out before finally attaching the pump inside the iron. It took me 2-3 attempts to get the spring tension right. If you can find a 'PENAC RB-085B BA1002' pen, the spring is perfect.
Once you have got it right, reassemble.
I have to replace the spring approx every 6 months as the replacement is obviously not meant for the job and wears or rusts or breaks. However, I am getting extended use from my otherwise broken iron.
Take care - things inside get HOT!!
Hope this helps.
Posted on Dec 17, 2008
  • 10865 Answers
SOURCE: Russell Hobbs coffee maker 3323
here is the manual
http://www.russellhobbs.co.uk/pdf/product_95_13401.pdf
Posted on May 20, 2009
manishkr31
  • 95 Answers
SOURCE: I need a user manual for Russell Hobbs model 4435
hi you download instruction manual from this link:
http://www.russellhobbs.co.uk/Dual_Pot_Slow_Cooker_qp_143.html
You can also try this link (optional):
http://dl.owenriq.net/a/a034fc9c-1198-4a38-a948-cce0e02a6620.pdf
Posted on Sep 20, 2009
  • 3 Answers
I found someone in NZ who sells a complete set.
http://www.trademe.co.nz/Home-living/Kitchen/Tea-coffee-making/Coffee-machines/auction-236701780.htm
Posted on Oct 17, 2009
beltronic205
  • 1474 Answers
SOURCE: got russell hobbs slipstream iron,
Check plug/electrics fuse okay, could be stat or heating element
Posted on Feb 22, 2011
Instructions manual to use Russell Hobbs model 3323 machine
Try Googling ( Russell Hobbs)(3323)(manual) without parens OR contact Russell Hobbs directly to request it.
Apr 28, 2018 | Russell Hobbs Coffee Makers & Espresso...
My Iron heats up but no steam comes out and no noise please help !! Russell Hobbs steam 2200
If the water used is hard it will build up with shale, and block the steam vents, best to flush with clean water after every second use . Best to take to the dealer and have it serviced .
Jul 10, 2015 | Russell Hobbs Irons
My Russel-hobbs coffeemaker RHCM5 does not hea tthe base were the glass jug sits, nor does it warm water and make coffee. The red power light is on (red).
Unplug the coffeemaker and remove the bottom cover.
  • Check the heater in the base for continuity.
  • Check the thermostat contacts - they may be heavily oxidized or burned out. Some models have an electronic timer - the relay can go bad in these. Your model doesn't look like it would have that.
  • It's possible that the power switch is bad even though the indicator lights up. Check it for continuity also.
Jun 09, 2011 | Russell Hobbs RHCM3333 Coffee Maker
Broken filter holder
I found one at www.cafeparts.com
Oct 18, 2009 | Russell Hobbs RHCM3333 Coffee Maker
Basic instructions on use of Russell Hobbs Type CP1 coffee perco
We too have a CP1, we need to find parts for a full restoration, after 50 years of service (it too was a wedding present to my parents in 1967) mum left it on, it boiled dry. I've messaged Russell Hobbs, but in case they can't help, anyone know a vintage parts source?
Jan 16, 2009 | Russell Hobbs RHCM3333 Coffee Maker
Russell Hobbs filter, cappuccino, expresso, steamer coffee maker
I HAD A GE CAPPUCCINO/EXPRESSO MAKER GIVEN TO ME WITH NO MAUAL OF ANY SORT THE MODEL NUMBER IS 169069. I REALLY WOULD APPRICIATE HELP WITH THIS THANK YOU...
Jul 14, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
73 people viewed this question
Top Russell Hobbs Coffee Makers & Espresso Machines Experts
Paul Bade
No_ky
ray gallant
Are you a Russell Hobbs Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
