Question about Ovens
I have a Jenn Air Model D146 with large heating elements not heating as fast or as hot as they used to. The small elements work fine.
The Over/Range is ~25 y/o and both large heating elements are not heating fully and taking very long to heat. One large burner has been acting this way for a few years and recently the second became defective as well. The small burners are both working great. I am wondering if a full cartridge replacement is required or if there is something else a repair man or myself could try. Two cartridges would cost $300+ so I'd rather not pay a repair man if all he is going to do is order and install cartridges since I can do that myself.
SOURCE: crosley gas oven will not heat up
That's my mom!!! Go Sheila!!! Hehe.. -RET-
Posted on Jun 04, 2008
  • 17 Answers
SOURCE: large burner won't shut off
This stove uses a special switch that turns one way for the large burner and the other way for the smaller burner. I was not aware that this had a seperate simmer burner on it, however. I think you using the wrong term there.
This is not computer controlled--the only computer on it should be the oven switch. I would assume that you need to replace the switch for the dual-size burner. If you take your model number in to Sears, or log onto Sears dot com, you should be able to get to the PARTS DIRECT web site on the computer, and if they ever sold that model you should be able to pull up a parts breakdown with expanded drawing and part numbers and prices. You should be able to buy the part from them. The part should be virtually the same as ANY recent model Frigidaire or Kenmore stove with the same style burner. This should be a very easy repair for you to make yourself, assuming that you know a little about working with electricity--remember, this stove USES 220 VOLTS!
Check out all of the wiring coming into the switch and going from the switch to the burner to be sure that there is not a short!
If you have one of the older smooth surface stoves, where the burners are part of the ceramic top, all bets are off, but anything you bought new in the last half-dozen years, should have a separate burner underneath a glass top, and the repair should be simple. Even with the older stove, it is still likely the switch, and should be no problem.
Posted on Feb 09, 2009
  • 478 Answers
SOURCE: Jenn Air JJW9630CAB Lower oven does not heat at
Go to to order lower oven thermostat.
Posted on Mar 13, 2009
SOURCE: Jenn-Air part RI302 4 pt gas re-igniter with flame rectification tytronics #Z21-20 and 7431 PO38-60
We had the same problem on a Thermador cooktop with the same RI-302 ignitor. Turns out it was one of the switches that sits on top of the gas valves. These switches cause the ignotor to fire when the valve is turned. In our case, one of the switches had malfunctioned and was "always on" causing the ignitor to continuously fire.
Posted on Mar 24, 2009
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Posted on Mar 16, 2010
My old Jenn-Air W230 wall oven only gets to "warm" in the bake position - even at a temperature setting at 500 degrees. However the broil function works well. Could the problem be a bad thermostat o
the oven sensor could be bad,its a small rod inside the oven cavity near the top,or you could have a bake element with a "hot-spot" in it that can no longer pass enough current to properly heat the oven to the correct temperature setting(most elements with a hot spot will show a discolored area on the element where its been overly hot)this is the "hot-spot" it will soon break apart there
Nov 30, 2012 | Jenn-Air Ovens
I have replaced the baking element on our Jenn Air oven for years. However, I have recently put in two replacement elements and they both did the same thing...the element did not warm up at all, and when...
Sounds like you have a bad or loose wire on the element plug. If you could post the model number of the unit I will see if I have the service manual for your range.
Sep 30, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Jenn air gas oven won't light off/heat up
Thanks for choosing FixYa and welcome. you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defective heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
Jun 13, 2011 | Jenn-Air Ovens
I have an older jenn air model ww30430 and I cant get the fan to turn off or the upper oven to work. any suggestions
if your unit is switch position is the upper heating element is have convection? you cannot turn off the fan,but if your unit have separate option to choice the other option to oparate separately the upper heating element this one can be use.
Dec 24, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
Need a wiring diagram for a jenn-Air range. Oven element burned out and replacing it didn't fix the problem. Don't want to spend $150 for a thermostat if ther is something else in the circuit that could be...
Hi. It could be your thermostat not sending power to bake element. If elements are really burning out that fast, check the voltage coming to stove. If more than 220 volts, could be a problem with the power coming into your home. Check also the element if it has continuity.
Oct 21, 2010 | Ovens
Jenn-air stove Model SCE30600B. Won't heat
check all the wiring at the main bus, and at the board connections could be a bad board
Oct 08, 2009 | Jenn-Air Ovens
Lower electric wall oven won't heat up
It is highly likely that your heating element is open so I would ( with power removed) verify the integrity of the element by detaching it and making sure it is not elecltrically OPEN, It is nothing more than a big power resistor that when current is flowing,..gets hot but if it becomes open.. you will not have any curent flow thru it ( or heat generated from it). That would be the first place I would look.. It could also be the control that feeds it..
A few ideas to check..
Feb 15, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Oven is no longer heating
If this is an electric oven you probably need to change the heating element. If it gas check to see if the pilot is lit
Nov 24, 2008 | Jenn-Air Ovens
Oven and stove top not getting hot.
The most probable cause is that the heating elements are getting 110V instead of 220V. Check the voltage to the heating elements.
Sep 07, 2007 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
