Question about Music
How to open a roll up piano - Music
I have a piano made by Laffargue piano co ewyork. The serial number is 70805. The piano has Seaverns written on it. Can you tell me the age of my piano please?
(1905)!! Please Read On How To Tell How Old Your Piano Is !! I Learned This From Grandma !!
Piano serial numbers usually have five to seven digits, but may have fewer or more, depending on the manufacturer and age of your piano. Serial numbers may also include a letter as well.
Here are the TOP FIVE places to locate the serial number of your spinet, console, or upright piano:
Serial number locations are found:
1) On the piano's cast iron plate. After lifting up the lid, look along the top front area of the plate. The serial number may be to the right or the left, or in the middle.
2) Under the opened lid on the ledge, stamped on a little plaque, to the right or to the left.
3) Stamped on the back of the piano; near the top of the wood frame.
4) Printed on one of the hammers, found on either end of the piano (newer or imported pianos).
5) Printed on one the keys - behind the nameboard, inside the piano (newer or imported pianos)
Aug 25, 2017 | The Music
27439 nordheimer by heintzman piano how old is it
    The Nordheimer Piano & Organ Company was established by brothers Samuel and Abraham Nordheimer in 1844. The firm was located at 122 King Street, Toronto. For the first 2 decades, the firm worked as importers and retailers of pianos, organs and melodeons. In about 1866 they built their first pianos with much success. The firm continued to grow and flourish during the rest of the 19th Century, building a full line of uprights, squares, and reed organs. In 1886, The Nordheimer Brothers went into partnership with Gerhard Heintzman of Toronto and opened the Lansdowne Piano Company, Ltd. In 1890, Nordheimer built a new, state-of-the-art factory in East Toronto. In 1927, Heintzman purchased the Nordheimer name and continued to produce Nordheimer pianos until the 1960's.
    It would appear your serial number relates to the years between 1931>1932...
Apr 18, 2017 | Music
Owner's manual for a sharper image play n roll piano
I know someone else with the same problem - did you ever find one anywhere?
Jun 02, 2012 | Sharper Image Play N Roll Piano
Keys on yamaha digital piano are sounding more than one note at a time how can i fix this?
The keypads can develop dirt , failure of pads which can result in such malfunctioning. If you are able to open the piano then carefully remove the keypads , clean the surface and reset.
this must solve the issue unless the pads/springs/mechanism are having fault.
Jul 05, 2011 | Roland Hp337 Digital Piano
4 keys do not work on Play and Roll Piano
There MAY be a break in the flexible conductors going to the keys... probably not repairable I am afraid.
Apr 26, 2011 | Sharper Image Play N Roll Piano
Registration of Piano, where do I do this?????\r\nE: Thanks, Jon Peterson
To register the keyboard, click on this link:
On the page which opens, click on "Yamaha Musical Instruments & Professional Audio Products" link.
Enter your email address on the next page which opens and then fill up the registration form providing the relevant details.
Hope thi helps.c85fe00.png Thanks for using FixYa
Dec 27, 2010 | Yamaha YPG535 Portable Grand Piano Package...
My kimball electromatic player piano won't automatically rewind, or even stop, when it reaches the end of the roll. It just keeps going and pulls the tape off the roller. If I press the stop button, it...
Look near the end of the roll for a hole or other trigger method that triggers the stop. It could be a hole in just one column or possibly a heavy mark on the roll. The later would be sensed by an optical pickup which MIGHT have a lamp burned out. From the site:
It appears that vacumn via holes triggers the stop and the rewind by "pouch" switches. I suspect those swithches trigger and lock the relays in the same pix at the site.
First thing to do is to see if those switches actuate at the end of the roll so as to stop and then rewind.
Aug 28, 2010 | Music
Wurlizter player piano roll turns but no sound
Is the vacuum pump working? Most players are actuated by a vacumm system which must be working to drive the hammers.
Mar 20, 2010 | Music
I have a Roland HP 2e digital piano - Foot pedal problem
The ROLAND pianos USUALLY require that you use a normally closed sustain pedal.
MANY pedals are the opposite and close when pressed. SOMETIMES you can open the pedal and reverse the way the switch works.
Oct 05, 2009 | Roland Music
What type of sustain pedal Roland EP-90 digital piano is using - open or closed at rest?
CLOSED is typical for Roland pianos when at rest. (open to sustain).
Note that the jack PROBABLY has a grounding contact so when no pedal is used/plugged in, the jack is shorted at the piano.
Sep 19, 2009 | Music
Music Logo
15 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
