Question about Samsung Refrigerators
I need to replace buld on samsung fridge freezer Model RL 41 WGIS don't know how to remove cover
SOURCE: samsung fridge freezer rs21dcns not cooling
press for diagnose the power freece and power cool, you will get an information about the self diagnosis. you can call samsung and will get a clue what is going on. maybe the heating is not working well.
Posted on Oct 01, 2007
zeusfaber
  • 247 Answers
SOURCE: Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Posted on Feb 28, 2008
SOURCE: Samsung fridge freezer
Hi I have same problem as gordon. fridge 5 years old.
Posted on Mar 02, 2008
  • 1462 Answers
SOURCE: removing doors from a samsung rsg 5 dumh american fridge freezer
doors are removable. wiring to the door is plug and socket
Posted on Oct 15, 2008
SOURCE: RS2555SL - Replacing the relay step-by-stemp
It wasnt too hard, I was trying and trying because I dint want to brake the cover, but I used a flat screwdriver and realeased the plastic cover from the top, it has a little tab, push it up and it will realese the cover, I hope it help you, by the way the realy you can get it at ebay for $7.00, I got it there
Posted on Jul 09, 2009
Samsung RM255LABP/XAA freezer only gets to 27 degrees, won't harvest ice. Fridge and lower freezer work fine. After pressing the ice maker reset button, I hear a ding don sound coming from the control...
It won't harvest ice on its own unless it detects a temperature of 10 degrees. The ding ding sound is the control letting you know that the ice maker is functioning fine. Remove the evaporator cover in the freezer and make sure the coil isn't frozen over and the fan isn't restricted from turning. Check the door gasket is getting a good seal. If that's all good replace the sensor on the ceiling of the freezer.
Aug 31, 2016 | Samsung Refrigerators
Instructions on how to remove and replace control panel and water dispeser on samsung RL 56 GPGBP fridge freezer. Need to change damaged door
water dispenser part comes up as a plastic bottle
no info online on how to replace that
to get to the controller on the door
I always buy the part first so you know how it is secured to the door
with power off
if the main control board is no meant to be removed but the outer door side
see if you have to lift the door seal edge carefully and undo all the screws of the white plastic molding
with that molding removed
see if is is possible to get into the wiring connection of the panel and replace it that way
Jul 03, 2016 | Samsung Refrigerators
Where is fuse in samsung srs626hnss
Is there no power? What are the specific problems?
Jun 05, 2016 | Samsung Refrigerators
Samsung american fridge freezer, not freezing, clicking noise at the back of the fridge
Your PTC relay is bad and needs to be replaced. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken If the part is way expensive you can replace with a 3 in 1 relay for refrigerators alot cheapier and work just as good.
Jan 31, 2010 | Samsung Refrigerators
The freezer is cold, but frig will only go down to 41-43 deg rang
Make sure both condenser and evaporator fans are running. Is it possible that you might have something blocking the air flow from the freezer to the fridge?! Can you hear the fan running up on top?
Jul 02, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge not cooling
Is there any frost buld up in freezer compartment?Is your freezer fan running?Need more info You may have a freezing issue you will need to leave doors open over night to make sure it is free of ice .Plug it in in the am and see if it works if it does then it froze up.And will need to replace part .Need more info to let you know what it may be Good luck:)
May 10, 2009 | Kenmore 60721 Refrigerator
hey gordon is this model 4 drawer electronic control with the display in the ice door
Feb 16, 2008 | Refrigerators
Fridge Freezer door replacement
You will need to order part number 059129. It will be in Europe/Germany phone +43-140447-200 for customer svc, +43-140447-300 for parts. Don't know if there is a US distribution office.
Feb 15, 2008 | Freezers
Refrigerators Logo
35 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
