Question about York Hardware & Accessories
I need to replace the clock for a 76300 York timer
2 Suggested Answers
SOURCE: do they make a replacement
Timer is not identified:
1) Add a comment with in-focus photo of timer posted on Flickr for possible help.
2) If you have a Tork 1101 timer, then a clock motor is sold: T101M or T201M
3) If you need new timer to fit specific purpose, add a comment with voltage saying what timer controls for more information.
Posted on Jun 14, 2011
When pool pump stops at various times when it should be running and not everyday, but sometimes twice a day, if I tap the Tork timer dial it turns on. Only the timer dial, tapping anything else does not...
Could be loose wiring, or bad clock motor.
Check if wires are connected, and make sure only the copper part of wire and no insulation is under the screw plate.
Make sure all wires are same gauge so that screw plate clamps down on wires.
Open following link to identify timer and then add a comment with model number and voltage for possible help. Tork T1100 series has replacement clock motor.
Jun 29, 2011 | York Hardware & Accessories
Do they make a replacement clock motor for a york timer
Jun 14, 2011 | York Hardware & Accessories
York timer controls pool pump. When I want to turn the pump off for maintenance, the "Off" lever will not stay down and turn the unit off.
More information may be needed.
Turn off the breaker to turn off power to load.
If this is a mechanical timer, and the override lever is not working, turn off power at the breaker.
Use WD40 to see if you can loosen the lever.
With mechanical timer, usually when override is not working, it signals you need new timer.
Add a comment and describe timer and what you have tried so far and what solved the problem.
Add a comment with in-focus photo of your timer posted on Flickr for possible identification and more complete help.
I cannot find reference to York timers on the web to recommend a replacement timer.
If timer is 120V then Intermatic T101, or if timer is 240V then Intermatic T104
Intermatic competitive reference crossover guide does not show York brand timers as of right now.
You might have a Tork timer?
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 15, 2011 | York Hardware & Accessories
The timer clicked OFF but poot pump kept running. Had to trip breaker to stop pool pump.
Your Intermatic timer has a manual override.
The override is a good diagnostic.
Click the manual override and see if pump turns on and off.
Next, watch if the clock is rotating.
If the clock is rotating, the OFF tripper may be worn out and you need a new tripper
If the clock wheel is not rotating, you need a new clock motor.
If you have T104, your clock motor is 240Volts
If you have T101 or T103, your clock motor is 125Volts
Buy trippers and clock motors at Grainger
Clock motor replacement takes a small star-screwdriver bit
If your manual override is not working, then the gears might be rusty and need to be cleaned or your timer needs to be replaced.
You can buy same model number timer and then swap the insides without changing boxes.
Add a comment if you need more help.
Nov 02, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Replacing timer motor
T-104 has 240Volt clock motor
WH-40 water heater timer has same 240Volt clock motor
T-103 has 120Volt clock motor
T-101 has 120Volt clock motor
T-100 series 120Volt and 240Volt clock motors sell at Grainger for $16
See large image of clock motor on back of Intermatic timer
To replace clock motor you need 6-sided star-screwdriver from auto parts store or hardware
You may also need tweezers or magnetic screwdriver if tiny screws fall down behind timer when replacing
Order 120 or 240 volt clock motor
Turn off power to timer
Remove plastic cover over screw terminals
Take photo of wiring or make a drawing
Note exactly which terminals the clock wires connect to
Clock motor wires can connect to either terminal, there is not a plus or minus wire to clock
Loosen screws on front of timer to remove white-colored clock motor wires
Push the spring retainer located inside box at top ... this will release timer mechanism from box
Tip timer out and then lift up to release timer
Replace clock motor that is held by 2 screws
Keep clock wires away from other timer parts on back of timer
Snap timer back into box
Re-attach wires to terminals just like they were before
Tighten screws very tight against copper wires
Turn on power
Check that dial is rotating as time passes
See more
Oct 17, 2010 | Intermatic T-104R3 220v timer in a rain...
Need to find parts for a york timmer model 1103
i have lost the screws that go on the timer wheel to start and stop the timer.
Nov 10, 2009 | York / Cam-stat Compressor Cycle Timer...
Need Trippers for Pool Timer
Maybe a bit late, but try Paragon. They have red features and were commonly installed during that period.
Jul 12, 2009 | Intermatic Digital Time Clock In Metal...
York timer roblem
Grasp the timer dial with your fingers and pull out on it to turn. Set the time of day with arrow at bottom and release. That's it!
Jun 15, 2009 | York / Cam-stat Compressor Cycle Timer...
Hardware & Accessories Logo
41 people viewed this question
Top York Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a York Hardware and Accessory Expert? Answer questions, earn points and help others
