Question about Singer Sewing Machines
I have a problem with my Singer Confidence Quilter 7469. My bobbin winder is not disengaging the needle so the it winds for 2 seconds stops and beeps
2 Suggested Answers
SOURCE: I have the singer confidence
i found on screen error 88
Posted on Dec 01, 2010
I have a IZEK singer sewing machine, I wound 3 bobbins with it and when I went back to sew it would not work
Sandy, I'm not familiar with IZEK machines, but it sounds like the bobbin winder has not correctly disengaged. Put it back into bobbin winding mode and run it (no need to wind a bobbin, just check that the bobbin winder turns), then stop and disengage the bobbin winder and try sewing again. Hope this solves it for you. If it won't turn the bobbin winder either then it may have slipped or broken the drive belt and you will need to take it to your local sewing centre.
Mar 02, 2015 | Singer Izek Computerized Sewing Machine
Husqvarna mega quilter
Each machine is different. Most of the machines that are electronic have a sensor to shut it off if you place the bobbin on the winder and push the winder into its position to wind. Give it a try. Also, check your spindle at the end to pull it outwards or attempt to untighten like you do a jar. This is the old mechanical machine but it is possible this machine uses it. Next you must look on your monitor for a particular symbol that represents the bobbin. This would likely be a button to turn it off and on.
Apr 26, 2014 | Sewing Machines
I have a Singer Confidence 7469 and was sewing and the machine just stopped. I cannot lower the needle or turn the wheel, it just beeps.
Check to see that all of the thread is out from under and around the bobbin. You may have to take the thing off that the bobbin fits into. Sometimes lint and excess thread pieces will build up under there. Did you check to make sure the wheel that you turn when you wind the bobbin is snug?
Apr 05, 2014 | Singer Confidence 7469 Mechanical Sewing...
Adjust the timing on a singer confidence quilter 7469q
Hook/needle timing needs a hands on guidance to get it fix, 2 options either you can watch in utube 'singer sewing machine hook timing' or 'google' for singer 7469q service manual for your referral.
Nov 10, 2013 | Singer Confidence 7469 Mechanical Sewing...
Singer 7469 clicking sound
You've either got a bent needle or your machine is slightly out of time. Take it in to have it serviced.
Jul 24, 2013 | Singer Confidence 7469 Mechanical Sewing...
I have a singer confidence 7469 quilter, the upper thread keeps bunching up in the bobbin case. I've tried re threading numerous times with no luck.
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
Jan 29, 2013 | Singer Confidence 7469 Mechanical Sewing...
Singer confidence Quilter 7469 manual
SINGER CUSTOMER SUPPORT:
1-888-633-8635
MONDAY THRU FRIDAY 8AM TO 4PM CST
Apr 03, 2012 | Singer Sewing Machines
Bobbin won't wind Singer 7422
Your problem lies with the main shaft that is to tight to release the bobbin winder mechanism, because of old grease and oil becoming sticky. A short term solution will be to remove the needle, in order not to hurt you, and then hold on to the needle bar with your left hand, while engaging the bobbin lever with your left hand. This will prevent the main shaft to rotate and your winder should work. In the long term, take it to your dealer to clean the oil and grease. You will not be able to open the machine casing yourselve, as you might damage the casing and or electronics.
Nov 10, 2008 | Singer 7422
Problem winding the bobbin movement of needle doesnt disengaged , then all lights light up as if its a warning after one winding a maximum of two times. singer 7422
Check the buttonhole switch ,if not there there is a microswitch on the bobbin winder that may be out of adjustment
Oct 24, 2008 | Singer 7422
Sewing Machines Logo
56 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
