Solve for(x-4)=9 - Office Equipment & Supplies
6=a/4+2 how do you solve this equation
For 6=a/4+2, a/4=6-2, so a/4=4, so 16/4=4, so a=16
Mar 01, 2015 | Office Equipment & Supplies
How do u solve this 13 2/9 - 4 5/6 = 8 7/18?
There is nothing to solve for: no unknown variable.
13 2/9-4 5/6=13-4 +(2/9-5/6)=9 +(4/18-15/18)=9 -3/18
Now write 9-3/18=8+18/18-11/18=8+(18-11/18=
8 7/18
Nov 17, 2014 | Office Equipment & Supplies
Need help in knowing how to solve 6x^4-6y^4
These other forms might help you solving your problem!
gif&s=25&w=69&h=22
gif&s=25&w=159&h=22
I hope this helps you solving this math problem!
With kind regards,
MisterN
Aug 10, 2011 | Mathsoft StudyWorks! Mathematics Deluxe...
How do i solve the equation x2-13x+36=0
Use the quadratic formula or completing the square.
Completing the square:
x^2 -13x=-36
x^2-2*(13/2) +(13/2)^2=-36+(13/2)^2
The left side can be factored as (x-13/2)^2.
The right side is (13^2-36*4)/4=(169-144)/4=25/4
Assembling the two sides
(x-13/2)^2=25/4
Taking the square roots x-13/2=+ or - 5/2
Case 1 : x-13/2=+ 5/2.
Solving for x you get the first root as x=(5+13)/2=18/2=9
Case 2 : x-13/2=-5/2.
Solving for x, you get the other root as x=(13-5)/2=8/2=4.
The roots are x1=9, and x2=4
Apr 20, 2011 | Casio FX-115ES Scientific Calculator
Explain to solve if 5+3+2=151022,9+2+4=183652,8+6+3=482466,5+4+5=202541,then what is 7+2+5=?
explain to solve if 5+3+2=151022,9+2+4=183652,8+6+3=482466,5+4+5=202541,then what is 7+2+5=?
Nov 12, 2010 | Dual Exercise & Fitness
Indicate h 4
When this copier power abnormal or heater abnormal then show H4
Solve: # interrupt C interrupt press 14 press start key if it is power abnormal then solve if you not solve you must be change Heater Lamp.
Mar 31, 2010 | Sharp AR-5320 Black and White Copier
How do you enter or solve for x? ex: 4/5 x = 6
well if 4/5 x = 6, then 5/5 would equal?? 7.5. 6/4 = 1.5 unit for each One. therefore 1.5 (Value of one) multiplied by 5, for 5/5 or a whole = 1.5 x 5 = 7.5.
Mar 25, 2010 | Casio fx-300ES Calculator
Can it solve 8^x=4 ???
You can use algebra to solve it.
Use the fact that 4 =2^2 and 8=2^3 and substitute in the equation
(2^3)^x =2^(3*x)
Then 2^(3*x)=2^2
By equating the exponents
3x=2 and x=2/3
Using the solve( function
With the calculator physical keys between square brackets, and the SHIFTed or ALPHA keys between parentheses, type in the following
8 [^ ] [ALPHA] [ ) ] (X) [ALPHA][CALC] ( =) 4 [SHIFT][CALC] (SOLVE)
Once the foregoing command entered press [=]
Display shows Solve for X on top line and probably 0.000 on bottom line.
Press [.] 5 to give 0.5 as a guess for the value of x
After a moment the calculator returns with the solution.
The display shows three lines
1st Line: 8[^] X =4
2nd Line: X= 0.66666666
3rd Line : L-R =0.
Your solution is 0.6666666. In fact the exact solution is 2/3.
Hope it helps.
Thank you for using FixYa and for rating this solution.
Dec 03, 2009 | Casio FX-115ES Scientific Calculator
"Too Few Arguments" Error
the problem is you haven't given it anything to solve...
always add a comma and the variable after any solve, differentiate or intergrate problem...
eg:
solve(x^2=4) is wrong!
intead put:
solve(x^2=4, x)
Hope this helps
Nov 03, 2008 | Texas Instruments TI-89 Calculator
How to use ti 89 with a problem like "-(3x+1)-(4x-7)=4-(3x+2)'
Just plug in one side of the equation and find the answer. Then plug in the other side and compare answers.
Feb 19, 2008 | Texas Instruments TI-89 Calculator
k24674
jasbo
jasbo
