Question about Doro Computers & Internet
I WOULD LIKE AN ADDRESS BOOK FOR MY DORO 6520 FOR ADDITIONAL CONTACT DETAILS, IE, ADDRESS, DATE OF BIRTH, ALL PHONE NUMBERS, NOTES, ETC
SOURCE: Address Book - Manual entry
I have just worked it out after numerous attempts!!!
1) Pair your mobile phone with the KCA BT100 (Passcode 1234)
2) Disable the "handsfree" option on the mobile phone for this pairing
3) Select the contact you want to send, bear in mind that the maximum you can send is 300!
4) 'Beam' the contact and your phone will search for bluetooth devices
5) Select the KCA BT-100 and press send/enter
A few seconds later the contact will be sent.
Once you have sent all the contacts you wish to send, turn off the car. Enable the handsfree function on the pairing, when you view the telephone screen you will see that the phonebook option has now been highlighted and you can select from the contacts you have just enetered!
Enjoy!!!
Posted on Jun 18, 2008
  • 4 Answers
SOURCE: Can't view my contacts in the address book
You have a filter on. When you see the screen that says "no addresses" you need to go to the top where it says "FIND:" then click the "Blackberry" key to the left of your trackball. Scroll up to "Filter" and click. One of your "categories" is checked. Click on whatever one is highlighted to uncheck. All of your addresses should pop up.
Posted on Mar 13, 2009
firesnake09
  • 2923 Answers
SOURCE: Phone Book Transfer Nokia N70 - Blackberry 9000
Syncronization! The Nokia phone will not just easily transfer or sync the contacts to your Black Berry because they are running on 2 different softwares.
In order for you to transfer all the contacts to your Black Berry is through synchronization
The Nokia N70 came with a CD called the Nokia PC Suite. And Black Berry should have a sync software.
What are the things you need:
1. Computer
2. Nokia N70
3. Black Berry phone
4. Nokia PC Suite CD
5. Black Berry sync software
How:
1. Install the Nokia PC suite to the computer.
2. Connect the Nokia N70 to the computer.
3. Export all the Contacts from Nokia N70 to your computer (refer to the manual)
4. Once the contacts are saved in your computer, disconnect the Nokia and connect your Black Berry.
5. Run the sync software of Black Berry and import the Contacts that are saved in the computer going to your Black Berry (refer to the manual of Black berry).
This is hiow to transfer the contacts from one phone to another.
I would also suggest to contact Nokia so that you will have a clearer idea on how to do it.
Posted on May 23, 2009
  • 13 Answers
SOURCE: I just got a new iphone 3gs. I need to transfer
Try the iPhone transfer software here, which can transfer iPhone to computer and transfer computer file to iPhone smoothly.
Posted on Sep 30, 2009
  • 3 Answers
SOURCE: Hands free Parrot will not hold any details in its memory
Use parrot sw update with a computer. Connect your computer to parrot via bluetooth and complete update. Delete all old paired devices too.
Posted on Feb 18, 2011
I have a doro 6520 phone and would like do block certain numbers how do I do that
Start by going to “Contacts” and tap on the contact you want to block. Then, press the menu key at the top left of your Doro 6520. You will see a menu where you will select “Block Number” or “Add to Auto Reject List”. The title may vary depending on the model you own
May 04, 2018 | Doro Cell Phones
Can you block a phone number on a Doro 6520 cellphone
Yes you can
How to block a phone number on Doro 6520 - Phone-Info
https://phones.brain-start.tech/block-phone-number/how-to-block-a-phone-number-o...
Aug 12, 2017 - Because you have an Doro 6520, you can also block text messages from a phone number. First, open the application "Messages" and then press the menu button located at the top left of your Doro 6520. Then you will see a list and you will need to press "Settings". Then click "More". You will have access to ... People also ask How do you block a number from your phone?
How do you block a number on a consumer cellular phone?
How do you block a phone number on an LG flip phone?
How do you block a number on a ZTE phone?
Feedback
How to put or remove a blacklist contact on yo ur Doro 6520 - Phone-Info
https://phones.brain-start.tech/.../how-to-put-or-remove-a-blacklist-contact-on-yo-ur-d... Jul 17, 2017 - To actually add the number to the blacklist on your Doro 6520, simply go to the contact containing the number in question, click on the 'menu' key of your Doro 6520, and select the 'block this contact' option or 'add it to the blacklist'. That's it, your contact is now added to the blacklist of your Doro 6520.
Doro 6520 - Turn call barring on or off
https://userguide.vodafone.co.nz/doro/6520...os/calls.../turn-call-barring-on-or-off/ Turn call barring on or off. You can block certain types of calls such as incoming calls when you're abroad. Key in your barring password and press the Navigation key. The default barring password is 0000.
Feb 20, 2018 | Cell Phones
How to reset clock on 6520 mpbile
Follow the instructions on the screen to set up your phone and prepare it for use.
  1. Find "Reset all" Press the Navigation key. Select Settings. Select Security. ...
  2. Restore factory default settings. Key in the phone lock code (default is 1234) and press the Navigation key. Press the Navigation key to confirm.
Doro 6520 - Restore factory default settings - Device Guides
https://userguide.vodafone.co.nz/doro/6520...os/basic.../restore-factory-default-settings/.
or go to this link might help.
How to reset clock on 6520 mobile Google Search
Oct 28, 2017 | Computers & Internet
Manual for doro 6520 clamshell mobile phone
Try Googling (doro)(6520)(manual) without parens.
May 20, 2017 | Doro Cell Phones
How do I block a number coming in to my mobile Doro 6520
Unfortunately sir doro 6520 don't have this feature...
Feb 07, 2017 | Doro Cell Phones
I have doro liberto 820 mini, which is a smartphone, I mostly like it and its features but it will not let me transfer any data to my new, empty, micro sd card? Showing 'storage full' message?
Normally the mini SD card is for your cellphone provider to give you a number and hold things like your address book. It is not provided as a data store.
The specs dont mention storage as a feature. You could contact them from this link.
http://www.doro.co.uk/doro-liberto-820-mini.html
Jul 31, 2016 | Doro Cell Phones
How do recover my old Facebook password and email address
Try to login to FB. When it fails, select "forgot your email or password" and follow the instructions. You may be asked to answer a secret question, to enter your birth date or receive a text message on your cell phone. Unfortunately, FB does not publish a number to contact a human being and is not a secure website so you should NEVER give them any information that can be used against you. Best bet: set up a new account using a different phone number. Give them a false birth date that you can remember and different information about your school, work. etc... Have your friends like you
and forget about the old account. (I did)
Mar 23, 2015 | Facebook Computers & Internet
Computers & Internet Logo
Top Doro Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Taelisin
Joseph Wright
Are you a Doro Computer and Internet Expert? Answer questions, earn points and help others
