Question about Craftsman Garden
My lawn tractor wont start its a24.0 hp electric startauto trans craftsman i change battery starter igintion switch
    Loyalty:
    Visited the website for 30 consecutive days.
  • Craftsman Master
  • 858 Answers
Check your altinator
Posted on Dec 20, 2017
SOURCE: Craftsman Lawn Tractor - Electrical
make sure you mower deck is not still engaged. that might make it not start with that safety switch.
Posted on Oct 04, 2008
wadembly
  • 513 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
  • 376 Answers
SOURCE: gear of starter motor won't engage in flywheel to run the tractor
Look under 'My Profile' (Longhorn294 in the top right corner of this page)on page 5 at this post and solution. "craftsman riding mower starter will spin but not engage". Dwain
  • 3 Answers
SOURCE: Huskee 25 hp lawn tractor with briggs & stratton motor wont start
Most all manufacturers have the Users Manuel available on line you will need the Make and Model to pick the correct one. Have you replaced the battery. It can show the correct voltage but have no cranking amps. I believe if the solenoid is trying to engage the Dead Man switches are closed. With the starter disconnected from all power sources do the teeth on the starter turn or are they locked up? If they refuse to move do you have an Auto Zone around or another parts store or electrical engine repair store that can test the starter. Make sure the mowing deck is not engaged while you are trying to start the engine. I hope these rudimentary suggestions help.
Posted on Jul 18, 2009
  • 130 Answers
SOURCE: change the v-best on a craftsman 42' mower 6 speed transaxle lawn
if your going to do this get a book its not going to be easy.so you need a book i say take to shop.let me know
Posted on Jul 22, 2009
42 craftsman rider electricity at solenide non at starter.
Check power at solnoid on cable coming from battery. 12-13V. With key turn to start should have 12-13v
May 22, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 21hp, 48" lawn tractor, electric start, automatic trans
The alternator is built into the starter. Check with a volt meter to see if you have at least +13v while mower engine is running. Could be a bad battery.
Jun 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Lawn Tractor, 18 HP, 44" Cut; No SWtart!
Check the by pass switches on the seat, clutch pedal, and check the fuses.
May 15, 2010 | Craftsman Garden
My mower wont start...i replaced the battery and it just clicks
Have a friend jump start the mower while you a seated on it. Turn the key to the "on" position. Connect the black jumper cable from a known good battery to a good ground on the mower and the red cable directly to the electrical connection of the starter. If the starter does not engage, it is faulty.
Apr 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftmans 3000dlt ride on mower can't start it up all it does is click click changed the selenoid and starter still click click Ammeter runs to negitive when i try to start it and it's a brand new battery...
The starter itself may be bad. Take the starter off, connect it to the battery on the mower with jumping cables + to + and - to battery and ground other to starter. It should spin as if it was going to start the mower. You may have to try different places on the starter for a good ground. If the starter spins, then it's not the starter, but binding. If it was electrical such as seat switch or blade switch it would still turn over but not start. With the starter clicking, it sounds to me that the solenoid is fine.
Apr 13, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a white lawn tractor and i just change the battery and the spark plug and it wont start . I also have current to my switch to start but no current to the starter . Could you solve this.
do you have power from the switch to the starter solenoid ? What you should have is a battery lead going to the starter relay / solenoid. a battery lead coming from the relay / solenoid to the starter and a 12 or 14 gauge wire coming from the switch to the relay solenoid. Depending on the age of the machine this wire may actually go direct to the solenoid or it may have to go through a couple of safety switches. the first thing I would check is make sure you have power coming out of the starter switch to the start circuit. The terminal on the switch is usually marked with an s for starter / solenoid. If you have power coming out from here then trace this wire to either a safety switch or relay solenoid, keep checking for 12 vdc until you dont have power and you will either find the problem or the bad part... hope this helps you
Sep 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
May 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Oct 04, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
