Sinotec wash machine how to adjust water tempreture T1311LS
F&P smartdrive washing machine 4 years old works fine but want the warm water hotter as it is to cold. can i adjust it?
run hot water b4 turning on machine temp are set by electronics can be adjusted slightly for just certain cycles will not make much different turn your water heater up 20 degree its what you want
Jun 27, 2016 | Washing Machines
How to adjust the water level on a Frigidaire top loading wash machine?
Hello friend, thanks for your post!
I see you would like to adjust the water level on your Frigidaire washer. I have researched that question for you and there is not a way to adjust the water level inside of your washer. I hope this information is helpful. -Matt
Sep 29, 2014 | Frigidaire Washing Machines
Where is the temperature sensor on a samung washing machine wf8702rsw?
Such sensors are usually located in the water input assembly where the water is mixed and the computer adjust how far the valves are open for desired water temps. Like adjusting the water valves in the shower for a desired water temp.
Sep 27, 2014 | Samsung WF8704RSW
My washer keeps flashing f24 and wont turn on what does it mean?
Hello, This is a water tempreture sensor error due to if the tempreture sensor value is out of range during the water heating up step during the cycle. Unplug washer or disconnect power, Check the water tempreture sensor and connection to it,check the resistance of the heating element using a multimeter. If you have any further questions message me back this error code diagnosis is for a whirlpool duet washer if you happen to have a different type of washing machine message me back your make and model number of your machine. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Aug 18, 2011 | Whirlpool Washing Machines
Frost free freezer frosting up
check for the tempreture adjustment knob in the refrigerator section as it might accidently have been turn to extreme high ...setting the refrigerator tempreture to very low can cause this problem in the frezer section try turning the knob to medium or tempreture according to the outside tempreture....
Jan 21, 2011 | Kenmore Refrigerators
Have the Indesit Moon washing machine and it will not finnish the wash cycle and go into spin mode. Is there anything I can do? Thanks
A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced.
Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power.
Please donot forget to rate and accept my answer...
Apr 14, 2010 | Indesit W 123 Front Load Washer
After instillation, the washer runs several times-then we noticed my hot water heater is shutting the pilot light off. Back pressure possibly on the Hot water side? Was purchased as floor model and N
what kind of water heater do you have?? as far as the washer it has a mxing valve inside the unit that mixes the hot and cold water to get the proper tempreture, write me let me know about the water heatrer,, that is what you are asking about
May 19, 2009 | GE Profile WPRE6100G Top Load Washer
Hobart LX30H washing to hot.
what temp is it washing at. washing should not be the problem. This machine is designed to rinse at 180 degrees + to sanitize dishes. The machine could be converted to a chemical sanitize, it would use bleach in the rinse water instead of 180 degree water to sanitize.
Sep 04, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Washing Machines Logo
Top Washing Machines Experts
