Question about Avision Office Equipment & Supplies
AVISION AD240 E4? - Avision Office Equipment & Supplies
Error code (E8)
Error E08 In Avision AV 121, what's wrong with that?
Aug 11, 2011 | Avision AV220 Pass-Through Scanner
Avision AV121. Won't feed paper.
my scanner AV121 hanged while scanning documents, first from the software then hanged in feeder and wont scan any more?
Jul 31, 2011 | Avision AV 121
Avision AV8350??? the error led is on, first time the led on & off For 8 number Sequence. then on for ever.
When you first turn the scanner back on, the READY light will blink, indicating that the diagnostics are in progress. If the Ready LED and Paper Jam LED blink 8 times, the error indication is "Light Check Fail (ADF)" or "Flatbed /ADF inverter check error".
Followings are the solution for the above problem:
1. Lamp is on? Yes. CCD error, Optical assembly is to be replaced.
2. Lamp is on? No. Flatbed or ADF Inverter error. Lamp inverter circuit is to be replaced.
3. Lamp is on? Yes. Issue resolved.
4. If the Lamp is still off, then Lamp is to be replaced.
5. If the issue still persists, then you may have to contact the authorized Avision Service personnel for further diagnosis and suggested repair or replacement.
Hope the above information is helpful.
Please revert if you have any doubt.
Thank you for contacting FixYa.
Regards,
TechSatya
Jan 16, 2010 | Avision AV 8350 Flatbed Scanner
Once i powered the avision 220 on, The moniter shows E and 7
When you first turn the scanner on, the READY light will blink, indicating that the diagnostics are in progress. Observe
the front panel Error LED (Red) closely. In a short time, the Error LED indicates the results of the offline diagnostics as
explained below.
Ready LED(Green) is off and Error LED(Red) indicates 7, the error indication is"Face down light check failure".
1. CCFL is on? Yes. CCD error, Optical assembly is to be replaced.
2. CCFL is on? No. Inverter error. Lamp inverter circuit is to be replaced.
3. CCFL is on? Yes. Issue resolved.
4. If the CCFL is still off, then CCFL is to be replaced.
Regards,
TechSatya
Nov 01, 2009 | Ambir Technology Avision 220 Pass-Through...
Lost my Driver and software CD for my scanner AV220c2, pls let me know from where to download
you can download the driver from www.avision.com. I dont know where to download the tool (avscan or svcapture).
Mar 27, 2009 | Umax Avision AV220
Please tell me where is available Avision AV830C Plus 30ppm Color Simplex 8.5x14" ADF/Flatbed in india (mumbai)
Dear Mr. Sanjay,
The Avision AV830C Plus scanner is available with the following company:
ADi e-logic
HIG-1, Rajiv Nagar, Aiginia
Bhubaneswar
Email:adi.elogic@gmail.com
Contact No: 919853339333
Regards,
TechSatya
Feb 19, 2009 | Avision AV 3200 C Flatbed Scanner
Avision AV830c plus scnaner paper jam error
Hi, Can you provide the detailed description of the issue? Is there any on screen error message or panel error code? regards, TechSatya
Mar 08, 2008 | Avision AV 3200 C Flatbed Scanner
54 people viewed this question
Top Avision Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Avision Office Equipment and Supply Expert? Answer questions, earn points and help others
