Question about Cameras
Put in new batteries and red lite come on and screen becomes msdc in did it plugged in and unplugged. took some pictures earlier but never seen any on the computer. push, etc but msdc. 8 batteries with middle battery up and others down I do not have a plug in only a cord to the computer
SOURCE: Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Posted on Dec 13, 2006
SOURCE: Acer aspire 3500 wont hold charge or turn on
I had to buy an new ac/dc plug piece off of ebay (cost only like $3 bucks) to sodder onto the mother board of my Acer. Somehow the little plastic/metal piece you plug into your computer comes off the mother board really easy. Acer wanted me to purchase a whole new mother board (at frigging $350), which, frankly wasn't an option. So I bought the little plug gizmo, soddered it on, and I'm doing good now.
Posted on Jun 26, 2008
SOURCE: HP ZV5000
For all those with the ZV series power jack problem, I have replaced a few of these jacks and it is not an easy job unless you are an engineer.
The entire laptop needs to be disassembled, all the panels need to be removed, including the keyboard and you almost have to remove the motheboard.
Even when you eventually gain access to the offending part, you will need to be competent in using a soldering iron to remove the jack without damaging the printed board, then clear the holes so the new jack can be fitted.
While you are doing all this, you need to remember that the circuitry is static sensitive. This means that you can kill your motherboard just by touching it.
When you have finally finished the job, unless you have been pretty smart, you'll end up with a box full of different size screws and you won't know what goes where!
With the ZVs I have repaired, I usually supply a short jumper lead that plugs into the power jack on the back of the laptop. This is two or three inches long with a cable power socket on one end and a power plug on the other. This means that the user can leave the power plug plugged into the laptop all the time and just disconnect and reconnect the power unit from the other end of the patch lead instead of wearing out the laptop's power jack.
Posted on Sep 13, 2008
SOURCE: No Power - Power Indicator 3 Seconds
This line of hp notebooks is the most notorious for power jack issues. There a re a few different symtpoms but 95% of all problems can be fixed with a power jack resoldering or replacement. It very rarely damages anything else on the motherboardis and seldom has anything to do with the power adapter/supply itself. There are a few options:
1) take to computer repair shop and get new power adapter. (As this requires a complete tear down of the notebook, it can be a bit expensive in terms of labor. The part is less than $10 on ebay and is readily available. You can download the service manual and break down the notebook yourself and take just the mb and new adapter to the shop and save some money. I don't recommend attempting to soldering on the MB yourself
2) If you don't need portability as much as just being able to use the laptop at home, then purchase an xb2000 expansion base from craigslist and power thru the docking port on the side. Be sure and confirm that the adapter is included with the purchase as some owners may have discarded it since their particular model didn't need it.
3) If you can manage to get an XC1000 cable for a reasonable price off ebay or craigslist, this is a portable option. However, as they stopped making these All-In-One media cables a while back, those who have them know their value and command a pretty hefty price. I personally would rather pay a computer repair shop a $150 before I pay some person who capitalizes on my misfortune.
4) I am in the process of confirming this least expensive solution but I don't see why it wouldn't work.
-- adapter from the xb2000 expansion base (you can pick these up cheap or free)
-- xc2000 all-in-one media cable ($35 - $50)
-- 120w power adapter for Presario R4000,R4100, R4200, and Pavilion ZV6000 (oval shaped multi-pin connection required.) Note: The original lower wattage adapter will not work. ($25 - $30)
Although this solution may cost a little bit depending on how creative you are, you can sell your old power adapter to offset the cost of the new adapter AND you can sell all 3 for what you paid when the laptop dies completely.
5) the paper clip trick has been known to solve a few problems where the connection in the socket is the problem
Ultimately, you can purchase a MB and replace it your self, the MBs run around $150 and you can use the service manual to break down the notebook. However, this is only a recommended solution if you have video problems since breaking down the laptop is just time consuming and the soldering of the power adapter is cheap
Posted on Dec 08, 2008
SOURCE: I have a Gateway NX560XL laptop. The other day it
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Posted on Jul 01, 2009
Mar 10, 2014 | Vivitar ViviCam 8025 Digital Camera
Aug 03, 2012 | Vivitar ViviCam 8025 Digital Camera
Jun 17, 2017 | Mitsuba DV777 Camcorder
Mar 12, 2011 | Cameras
Mar 07, 2011 | Nintendo DS Lite Console
Feb 22, 2010 | Vivitar ViviCam 8025 Digital Camera
Dec 28, 2009 | Vivitar ViviCam 5385 Digital Camera
Dec 25, 2009 | Vivitar ViviCam 8025 Digital Camera
Nov 03, 2009 | Vivitar ViviCam 8025 Digital Camera
Oct 09, 2009 | Nintendo DS Lite Console
Apr 24, 2018 | Samsung Cameras
37 people viewed this question
