Question about Proform Exercise & Fitness
Proform 400c.changed walking belt.tread mill is much noisier. Whining sound. Sounds like it is coming from main motor board. tried readjusting walking belt tension with no change in noise
limotec
  • 33 Answers
SOURCE: Whining noise from engine
Hello
altho new you may have a whining water pump or tensioner or it may be over tensioned.
take a long screw driver & place in on the timing cover to try to here where the noise is coming from, this should help you find the proplem with the car
Regards Paul
www.limotec.co.uk
Posted on Jan 11, 2009
  • 1126 Answers
SOURCE: NO I WOULD LIKE A OPERATOR'S MANUAL FOR A
Here is a link to ProForm for 293250 manual download.
http://www.iconservice.com/cgi-bin/ncommerce3/ExecMacro/proform/manuals.d2w/report?name=293250&match=exact&lan=
Just right click on the file and select 'save as'. You will need Adobe Reader to view once downloaded, and it's at no charge.
Posted on Nov 08, 2009
maxtreadmill
  • 832 Answers
SOURCE: Treadmill will not level out and motor sounds all the time
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Posted on Jun 27, 2010
  • 218 Answers
SOURCE: Clicking sound coming from front
bad bearing in the front roller
Posted on Aug 12, 2010
ercupa190
  • 12223 Answers
SOURCE: treadmill proform model 831.29605.0 (proform xp 550e was working fine till I Changed the walk belt. After changing belt, display looked ok but treadmiil would non trurn on. Operated incline. incline
1) i recommend that you lube very well deck belt + rollers bearing
2) see the videos.
3) see the block
4) Try to RUN the software calibration, for troubleshooting.
5) measure the input voltage motor, if there are the motor need repair.
6) Measure the output voltage board, for input voltage board, if there are NOT, the board is faulty.
Posted on Jun 28, 2012
Proform 400c treadmill trips when start button pressed
Step 1:
see the video and lube deck beltg+rollers bearings.
and test again. if there are o.k . Fine
If the problem persist.time to replace the old deck board complete.
However you must sure and test the following:
Step 2:
test the input voltage motor: if there are the motor NEED repair, See my personal TIPS for motor help.
2) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the diagrams attached.
Step 3:
Jan 09, 2013 | Proform Exercise & Fitness
Treadmill proform model 831.29605.0 (proform xp 550e was working fine till I Changed the walk belt. After changing belt, display looked ok but treadmiil would non trurn on. Operated incline. incline
2) see the videos.
3) see the block
Jun 27, 2012 | Proform Treadmill Motor Controller 241697
I have a proform xp 620 treadmill and the control panel keeps shutting off and on. i can start walking then it shuts off and then seconds later it comes back on
adjust the sensor switch first.2) change the batteries if have it.3)tight the flexible cable vs display board.4) tight the connector from display board vs lower board.
If the problem persist.you must test the following:1) Test the main motor.2) See if the drive belt is broken, loose, or slip3)finally the main motor board possible is faulty
see block diagram12_1_2011_11_16_04_pm.gif12_1_2011_11_16_27_pm.gifgood luck.
sincerely.
e.cuadramanagua,nicaragua
Dec 01, 2011 | Proform XP Weight Loss 620 Treadmill
When starting, the motor starts sluggishly. It sounds different and goes very slowly. At higher speeds, way high, it runs fine. Speed censor says one thing, but tread moving very slowly.
Treadmills are usually made up of various components. The rolling surface (tread) is usually placed on a set of rollers when the unit starts due to the low friction between both the surface (tread) and the rollers the surface (tread) starts slowly while the rollers move regularly and the sensor is placed on the movement of the rollers.
What you need to do is get the unit serviced usually there is a way the tread it tightened to have better grip on the rollers. This method differs from one make to the other so get an expert who knows about proform rollers. Once the system is tightened the problem will be solved.
Hope this solution has been helpful?
Jan 05, 2011 | Proform 595LE Treadmill Walking Belt
Proform tredmill---stops after a couple of steps--will start back up after getting off---motor control board?
Inspect the walking board and belt first.Feel the tecture at the outer edge of the belt, then feel the center. If it feel fuzzy, the walking belt is worn.
Check the walking board for damage, deep scratches, excessive friction will cause an over current shutdown of the controller.
If the walking belt and board are good, lubricate the walking board and belt and try again.
Does the motor spark allot when running?? This will also cause over current.
Have you tightened the belt (too tight??)
After covering these suggestions, if the same problem is apparent, change the motor controller..
Dec 16, 2010 | Proform 755cs Treadmill Motor Control...
My tread mill looses speed during my workout. the
If you haven't adjusted the belt refer to your owners manual for the proper procedure if you still have the same results then it could be caused by a lack of lubrication under belt or a worn belt.
Apr 10, 2010 | Proform Exercise & Fitness
Exercise & Fitness Logo
42 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
