Question about Dyson Vacuums
I need a diagram for the on- off switch assembly for a Dyson sweeper dc17
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 76 Answers
Youtube
Posted on Aug 24, 2017
bestdarngood
  • 3037 Answers
SOURCE: Cannot Assemble Dyson DC17
press the button on the side of the wand that detaches it from the main vacuum and try pushing it into the hose, let me know if this doesn't work
Posted on Mar 20, 2008
SOURCE: How to replace belt on Dyson DC17
Preface: Dyson folks were great, answer so simple I was embarassed after I called. 5 minute fix.
1. Loosen 3 screws from bottom plate using flathead screwdriver or coin edge and remove it.
2. Wiggle roller until it pulls straight out.
3. Squeeze new belt and loop it over metal drive gear (you'll easily see the gear).
4. Keeping belt on gear, insert edge of roller through belt and rotate the roller while pushing it through belt until it is inside the belt, then continue rotating roller and sliding it over until belt is in position over gears on roller.
5. Insert roller into slots on that it came out of, reattach bottom cover and its done.
Posted on Apr 04, 2009
SOURCE: Cannot reinstall valve pipe assembly on Dyson dc17 vacuum
Take off the cyclone canister and flip open the filter cover. (The U-shaped tube at the bottom of the vacuum is probably already off-if not, release the lock with a screwdriver and remove it.) Release the vacuum from the upright positon, so that the head is extended. Align the value pipe assembly so that the clear tabs line up while the small extension off the value pipe faces the front of the vacuum (ie, is near the filter area). Now you have to carefully twist the value pipe clockwise while lining us the small extension with the black groove inside the head piece by moving the head back into the upright positon at the same time. Replace the U-shaped tube.
Posted on Apr 30, 2009
SOURCE: roller motor on a DC17 dyson wont turn on
there is a reset button under the cover that houses the on/off switches. remove the handle/wand and look on the back (where the top of the hose sits) for 2 screws (its a torx/star head screw size t10 i believe). remove them and locate 4 small locking tabs that hold the switch cover to the frame of the vacuum. Depress them and pop the cover off (2 towards the top and 2 towards the bottom). Youll see 3 switches (2 square red buttons and one small cylindrical shaped one). Push the small red one (the one to the left if my memory serves me right). you should hear a click. if you do than the switch is reset. if not check all connections to all 3 switches. if you see nothing loose or not connected, you may need a new brushbar motor. try it
Posted on Aug 09, 2009
  • 4 Answers
SOURCE: Power shuts off on my dyson dc17 animal
I had the same issue. Got on the phone with Dyson. THe vacuum has a safety feature where if the motor gets too hot it cuts off. You have to leave it for 45 minutes or so and then it will work again. There is an underlying issue though. My problem was the black gasket thats in the debris bin shifted, probably from when emptying i pushed it on something. The black gasket should actually hang off the bottom like a skirt and the 2 groves should fit in on the groves of the gray mechanism. This seal is what provides 100% suction. Because of this..my vaccumm has been accumulating pet hair by the belt which i hear alot of people talking about and especially in the filter area. This is because I broke the seal by not having the gasket in place properly and it wasnt sucking 100%. They are sending me a complete new cyclone unit which has the debris catcher as well as she said its probably so caked up with debris it will never work again 100%. no questions asked they are sending it to me free of charge.
So if you remove the clear cyclinder debris catch thing all you will have is the purple cyclone on top and on the bottom is the black rubber gasket....
Posted on Jan 04, 2010
Sweeper stopped after using wand
Hi there, it's Jack at Dyson.
Most of our vacuums include a thermal cut out, which shuts the machine off if it starts to overheat. Usually this will be because the filter needs a wash, or because there's a blockage in the machine. From what you've described it sounds like there's a blockage in the hose, wand or duct.
To resolve this, please follow the steps shown in our online Support guide: http://content.dyson.com/support/help.asp?article=954&product=DC17-ANIMAL
It's important to wash your machine's filter at least once every 3-6 months, as shown in the video above. Use cold water without detergent, and allow at least 24 hours for it to dry completely before replacing it.
This should resolve the issue, but if you would like some further advice from our experts, please email us at askdysonUS@dyson.com. We'll be in touch as soon as possible.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 30, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Switch button assembly dyson
If you're having difficulty with your DC17's switch, I'd encourage you to give our Helpline a call on 1-866-693-9766, as we'd appreciate the opportunity to provide further assistance.
We'll look forward to hearing from you.
Best wishes,
Jack
May 25, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
Can you wash canister and vortex assembly in Dyson DC17
you need a Hyla they use water as a filter and the smell goes down the drain
Jan 22, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
I opened my dc17 dyson to clean teh motor. trying
I'm not sure about all the switches used in the vacuum, but I recently took some pictures of the power button assembly. The buttons in the picture below are (from left-to-right): Circuit Breaker, Brush Switch, Power Switch
The next picture shows how the plastic buttons that operate the brush and power switches should go together:
And finally, this is how the power button assembly reattaches:
Jul 02, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have to push the sweeper, there is no drive
Be sure your belt isn't slipping on the beater bar. Might be time to get a new belt or at least take off the beater bar and clean everything. Dust can cause it to slip
Jul 10, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
I need assembly instructions for my Dyson dc17 vacuum -
I was able to find a link to the owners manual for your Dyson DC17 upright, and I have added the link below. I have checked the manual yet, but this should explain to you how to assemble your Dyson. If for any reason it doesn't, or you'd like me to further help you, please don't hesitate to add a comment to this repair page, and I'll be more then happy to walk you through it.
Owners Manual For Dyson DC17:
http://media.dyson.com/downloads/us/floorcare/manuals/dc17_opmanual_usa.pdf
May 12, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
In need of a picture of the on/off switch for Dyson DC17.
This is over a year too late, but perhaps this will help other people in your situation. Here is how the switch assembly should go together:
Feb 01, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuums Logo
43 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
