Question about Samsung Refrigerators
I need to replace buld on a Samsung fridge freezer Model SM/T
zeusfaber
  • 247 Answers
SOURCE: Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Posted on Feb 28, 2008
SOURCE: Samsung fridge freezer
Hi I have same problem as gordon. fridge 5 years old.
Posted on Mar 02, 2008
ghappliances
  • 126 Answers
SOURCE: i need a replacement door
FIRSTLY WHY DO YOU NEED TO REPLACE THE DOOR OF THE APPLIANCE.
MOAHMED
Posted on Sep 19, 2008
57 varieties
  • 1653 Answers
SOURCE: Whirlpool Fridge/Freezer Door Seal Replacement. Model: ART 462/3
In short no as long as you get the correct seal type from a spares shop, or Whirlpool. Just make sure that it is straight and there are NO gaps or splits in it when you refit it. Usually these will come pre cut to size for the particular model of FF but you can also buy seal strip on a reel from many spares shops. Also when you have removed the old seal make sure that you use a degreasing cleaner to clean around where the old seal was located and make sure the area is dry before fitting the new one.
Posted on Aug 29, 2009
toolkits
  • 1099 Answers
SOURCE: WHIRLPOOL FRIDGE FREEZER MODEL ART 201. REPLACING
It is often the case that if the thermostat is not working, the best route to take is to replace it rather than try to fix it, unless you have the necessary knowledge to do so. Most of the time, these are not as expensive as you would think and can be easily installed into the refrigerator. Here are some steps to follow to find out what the best route for you to take is in repairing or replacing your thermostat.
Good luck.....
Locate the thermostat and get all necessary model numbers, serial numbers and model codes. This information should be available for the refrigerator itself as well. Use this information to find and purchase the correct thermostat for your refrigerator.
Next, remove all power from the unit. Unplug the unit completely and make sure that it is not running before moving forward. Then, remove the old thermostat by cutting through the wiring.
To install the new thermostat, trim the lead wires to the right length. They are generally too long to start with. Terminate back into the circuit. The device will act as if it is a switch. This means that the direction or the coloring of the wires is not important. So long as you can cut off the current moving through them to the main defrost element you have no problem.
Make sure to properly dress the wires to insure that no part of them comes into contact with the defrost elements as this can cause them to melt.
Replacing a thermostat doesn’t have to be a lot of work, when you know what the problem is and can get easy access to the parts you need. Determine if your thermostat is bad by running through those tests first. When you do replace it, make sure to test to make sure it is working properly by allowing the unit to cool for several hours and testing the temperature within it.
Posted on Jul 30, 2010
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
I have a samsung fridge freezer model no RSH1DTMH and the fridge will not go lower than 13degrees and the freezer and water dispenser seem ok. The fridge freezer is only 3 years old. Any ideas/
We had the same fault on our Samsung American style RSH1DBRS fridge freezer as lots of other people seem to be having. After doing lots of research, we found the best solution seemed to be to buy a repair kit from Appliance DIY Repairs. The instructions were fantastic and the installation was a doddle. Excellent service & well priced.
Jan 19, 2011 | Samsung RS2630SH Side by Side Refrigerator
How to replace light bulb in fridge ?
open the plastic gaurd by lifting it up and then remove the old buld by threading it down. now replace it .
Sep 16, 2010 | Smeg FAB32 Bottom Freezer Refrigerator
Whirlpool refrigerator and freezer problem. a cup was place in the refrigerator to catch the percipitation coming from an inlet from the freezer. Which they are two inlets located in the center back of the...
It sounds as though you have frost or ice buld up under the panel in freezer compartment.Remove the 4 screws in freezer and 1 green ground wire.Inside you may see ice or frost buld up.Some causes are-Your drain tube may have a obstruction in it.It is located on center rear of freezer compartment.And if you pull fridge out and remove bottom rear panel you will see a plastic tube going into a drip pan.Pour hot water in the freezer and use hair dryer to defrost till water drians to bottom rear of the fridge.After you defrost the freezer cheak the bimetal defrost thermostat cliped on condensor see if it is balged on top where the wires go into thermostat.If it is you will need a bimetal defrost thermostat for it.If not cheak your defrost timer in can be locted around the temp control in fridge or under kickplate on bootom front of fridge.Advance the timer with a flat head srew driver look close it there will be a hole around light or control panel turn till fridge turns off.the element should turn on >if those @ things do not work you may need a thermostat control If you have electronil controls you may need a new board
Mar 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge defrosting
Sounds like the defrost is cycling on and off. The model number is incorrect and I will need a correct model number to help you better. Sea Breeze
Aug 25, 2009 | Samsung Refrigerators
Refrigerator and Freezer are not cold enough
sounds like your fridge is iced up.To cheak this you will need to remove rear panel in freezer compartment and cheak if there is ice buld up.If so you may need a defrost timer or your drain tube may be plugged..If those are fine cheak if your defrost thermostat is ok and not split.Hope this helped:)
May 20, 2009 | Refrigerators
Refrigerator not working freezer is like fridge
Need more info is there frost buld up in freezer?or water leaking into fridge compartment?Is the fan running in freezer part?
May 10, 2009 | Frigidaire Refrigerators
Fridge not cooling
Is there any frost buld up in freezer compartment?Is your freezer fan running?Need more info You may have a freezing issue you will need to leave doors open over night to make sure it is free of ice .Plug it in in the am and see if it works if it does then it froze up.And will need to replace part .Need more info to let you know what it may be Good luck:)
May 10, 2009 | Kenmore 60721 Refrigerator
hey gordon is this model 4 drawer electronic control with the display in the ice door
Feb 16, 2008 | Refrigerators
SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Oct 12, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
27 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
