Where is the reset button on a envirastation remote sending unit
Remote doesn't always work. New batteries.
Some people accidently obstruct the remote sensor on the system so that the remote can't send the signal. Check that it's not obscured by anything, including the position of the unit.
If that doesn't make any difference then either the remote is playing up, or the remote sensor has a fault on it.
Feb 26, 2016 | Yorx Audio Players & Recorders
Airwell remote
maybe the button for turn on is blocked
Dec 10, 2013 | Heating & Cooling
Envirastation model dws 170
Usually it is due to bad batteries or remote is too far away from home unit. Put units next to each other and press the channel button on front of the home unit. It will start a search to find the remote. If it finds it with a temp reading press the channel button again and you should hear a beep. Channel is locked in. If you still do not get a temp reading try changing batteries in both units and try again. Another try is to unplug the home unit and wait several minutes with no batteries in either house unit or remote. Replace batteries in remote then in house unit and plug back into power. Set all settings and see if you get the reading. If not try step one again. Weak batteries will do the same thing as well as remote to far away from unit.
Oct 06, 2013 | Measuring Tools & Sensors
I cannot find the owners manual to hometics envirastation dws-400 weather station, and need to know how to synchronize the outdoor temperature sensor with the indoor station readout (i.e. pressing what...
You must remove the batteries in the base unit, replace them, and it should work properly. You can press the Tx button on the back of the remote unit to verify the RF reception. To ensure it is working properly, place both units next to each other indoors and make sure they read the same temperature.
The manual can be found here. Refer to page 3 for more information.
May 03, 2011 | Health & Beauty
My remote only works on 1 and 2. # 3 does not work . How do I fix this?
You posted under Woods timers.
Woods makes a few different timers with remote.
One of them has 3 buttons
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
You can try unplugging all 3 remote units so they reset, and then try setting up on button #3 first.
You can also work around using this method: unplug all remote units. Plug in two remote units and turn both lamps ON. Then use button #1 to connect to both of those remote units simultaneously. This way, two different lamps can be controlled by one button.
If remote control is genuinely defective, then send it back for replacement.
Industry-standard is one-year limited warranty.
I own 2 sets of this timer.
One of the remote units stopped working immediately and has never worked since.
Both the remote controls work, but only 5 of the 6 remote units work.
I test timers and 6-8% arrive defective. Most go bad after a few years, some last quite a while.
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 24, 2011 | Woods Hardware & Accessories
Locked out & Remote not working
There should be a green button on the back of the motor unit, press it for 2 seconds and then hold down your remote button until the light flashs. or for 3-5 seconds and then activate the remote. that might solve your problem
Jun 29, 2009 | Chamberlain 950CB Remote Control
Replace remote control unit model ar-fb2
If your remote control have display but cannot transmit signal to the unit. Confirm first if the remote is really the problem, using your camera or cellphone camera as your eyes point the remote transmitter to your camera and "on" the remote. You should see light emits in your remote control, if no emitted light then the remote control is defective. But if there is a light the defect is in the unit receiver.
Check also if there is a reset or rst button in your remote control and reset it and try.
Check also if there are error codes in the unit, reset the unit by disconnecting the power supply in the unit for 10 sec. and "on" again and try.
The unit can be operate without remote control, use the manual button located in the unit.
If the remote control have no display replacement of remote is recommended.
Jan 15, 2009 | Heating & Cooling
My clock will not display the outside temp. after battery replace
Try replacing the AA batteries in the main clock/display unit - that worked for me, then you'll probably need to press the reset button next to the AA batteries, and maybe the reset button next to the AAA batteries in the remote unit - press reset on the main unit first. My remote is now registering and the red light is flashing, but I don't know how to reset to the correct time and date - it's been scanning for a while and found nothing...
Nov 21, 2008 | Audio Players & Recorders
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
