Question about Samsung Televison & Video
My samsung rf265 just went darkoff?. Now just the cooling compartment lights are flickering
I taped magnets on my regrigerator according to the suggestion from Samsung. It worked for a couple of months but now it went haywire.
Please help me understand the connection between magnets and the like flickering? Does the light act the same way when you open the right door? have you played around with the switch?
Dec 08, 2014 | Samsung Refrigerators
Why is my haier refridger not getting cold
There are alot of things that can cause no cooling...
a stuck tstat, will cause it to freeze up(electronic control)
a broken defrost timer will cause ice build up from no defrosting
out, or low on freon charge
inefficient compressor
door gaskets leaking
light switch not cutting off the light inside the cooling or freezing compartment
a bad fan motor(door) switch
I dont know how your unit works, but most only have one evaporator in entire unit..and its in the freezer compartment, and the cooling side gets it (coldnest) from the freezer compartment..with a door flap that alows cold air from the freezer to enter the cooler side.
Hope this helps..
Jun 04, 2014 | Samsung RS2630SH Side by Side Refrigerator
Samsung Fridge/freezer problems
The BBC has an open complaint on these machines and you may be elligible for extended work on this
Feb 20, 2014 | Samsung RS2630SH Side by Side Refrigerator
Samsung rf265 series french door with freezer drawer on the bottom: Water collects under the veg drawers in the refrigerator part. What might be wrong?
I have the same problem!!! We need a class action lawsuit against Samsung for this problem on their French Door fridge. Instead of fixing it they want the consumer to pay for repair. NO MORE SAMSUNG PRODUCTS FOR ME!!!!!
Sep 04, 2011 | Samsung RF265AA Bottom Freezer French Door...
Samsung rf265 series refridge is making a loud humming noise--only 1 year old
It is a well known defect.
the ice is builing up until it interferes with the fan.
The samsung people will not help you. You are screwed.
A&E appliance repair(Sears) told us to take all the food out and leave the doors open for 24 hours.
This happens at least once a month.
We cannot ever buy a fridge from Samsung again or from Lowes.
They ****** us hard. Good luck
Mar 21, 2011 | Refrigerators
Light inside the refrigerator flickers (or not) and the door makes a buzzing noise when opened. There appears to be a small light flickering inside the fridge behind the vegetable bend. The refrigerator...
Sounds like the electronic control in the rear compartment by compressor may be bad . There is a light in the crisper as well I believe and that one and the main light are controlled by the control in back.
Dec 03, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
We changed the filter on the icemaker but tye light is still on asking for a filter. now what makes the light go out?
The light stays on, actually. RF265/6/7 models have a blue LED water filter indicator that remains lit in normal mode. After about 5 months [on a 300 gal. filter] the LED indicator will turn pink and then red at about 6 months. Derived from RF266 users manual, hope this helps.
Oct 07, 2010 | Samsung RF265AA Bottom Freezer French Door...
Lights in refrigerator compartment flickering
You have a bad electronic control board . This part is mounted on the back of the refrig , at the lower left corner , inside a plastic holder . The part number is W10135090 . It costs about $ 100.00 . This board , also controls the 2 control knob lighting .
Apr 21, 2010 | Refrigerators
Samsung SyncMaster 920nw suddenly went black now squeaks/flickers
The 920nw did have a 3 year warranty on the unit but they will be out of warranty now. The flickering power light is an indication of a failure in the power supply board. When the board fails it can't start up correctly and the power shuts down over and over so you get the blinking light and no display. This is a very common failure point on all LCD monitors after a few years of use. There are parts called capacitors on the power supply board and they filter the output power. When they fail the power is not properly regulated and the power supply shuts down and tried to restart so you get the flashing. Here is a link to a repair guide that will show you how to dis-assemble the unit and then what to look for and replace to get it back up and running again.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
The repair guide has pictures and videos to guide you through the repair.
I hope this helps, if so please rate my solution.
BuddyMc
Nov 14, 2009 | Samsung SyncMaster 920NW Monitor
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
