Question about Irons
What do you do when the iron won't heat up - Irons
Steam switch won't work
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
God bless you
Apr 01, 2013 | Rowenta Irons
Singer 7467 wheel won't spin, unless little bit if I do manualy by hand...
do this
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.2_1_2013_6_01_09_pm.jpg
Jan 31, 2013 | Singer 7467S - Confidence Sewing Machine
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
Jan 25, 2013 | Philips GC 2510 Iron
Rowemta DA1560 won't turn on
1) No voltage to receptacle
2) defective cord or terminal connection
3)open thermostat
4) open heating element
4a) the heating fuse blown
5) test the outlet wal with lamp desk, if work, the iron is the problem follow the steps before mentioned. reset the c.breaker or change the blown fuse is necessary.SEE the diagram
God bless you
Sep 09, 2012 | Rowenta DA1560 Iron
Black and decker all temp steam iron stopped working while ironing and now it won't turn on.
please see the cause and fix it:
a) tank or ports clogged. Dissasembly and inspect replace tank and seal if badly clogged. Emptying iron after each use allow heats to evaporate remaining water and helps prevent clooging. Inspect valve and linkage: clean or replace as necessary
GOD BLESS YOU
Jul 22, 2012 | Applica Black And Decker All Temp Steam...
No steam coming out of iron russell hobbs precision heat digit model14773
i know mine won't steam either unless you have the dial set to steam. not sure if your has the same set up but i thought it might help to offer the information
Jul 16, 2012 | Irons
Iron won't come on or heat
Hi
The problem could be the power cord or the element.
Try replacing the power cord first and see what happens.
Feb 28, 2012 | Irons
My Iron will not turn on! It hasn't seemed to heat up right lately anyway,but now it won't heat up at all.
Has found all with detailed operation and with comment that from itself this model.Manual HERE
Jul 29, 2011 | Rowenta Irons
My iron won't heat. it has electricity but won't heat
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Ironnot Heating Up or not Working Right heatman101
Jun 25, 2011 | Rowenta DE-480 Iron
My iron's MODEL: 14977Z The iron's red light is on but won't heat to iron. was working a couple of hours ago
This is typical of a iron, it is cheaper to replace than to repair. The heating element is broken.
Jun 02, 2011 | Hamilton Beach 14977 Iron with Auto...
Irons Logo
59 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
