Stove trips earth leakage not the circuit breaker.Please advise
  • 240 Answers
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Posted on Feb 02, 2008
  • 121 Answers
SOURCE: my ac circuit breaker keep tripping
If your outside condenser has a locked rotor or short circuit, than the unit WILL trip the breaker - as it should. On the other hand if a breaker is tripped a few times it will have less of a capacity that the rating, (this is designed in it). You will need to determine if the unit is locked (and broken) or the breaker has become too sensitive.
Posted on Apr 22, 2008
  • 21 Answers
SOURCE: Shutdown of DW very near end of drying cycle
good to hear that you got this fixed.
Posted on Jun 10, 2008
  • 81 Answers
SOURCE: Keeps tripping circuit breaker everytime on plug the power cord in
2 common, possible problems. 1 - there is a "short" in the plug - easy fix - replace either the cord or plug - not expensive. 2 - bad control board - not so easy, not so cheap. Is it brand new, used? Also, it could be a bad "internal breaker" - not easy!
Posted on May 07, 2009
  • 132 Answers
SOURCE: two 15 amp arc fault breakers installed on two
It's possible that the first breaker that you said does not trip - it could be that breaker is failing to trip on a bad circuit. That is, it could be you have a bad circuit but that first breaker is not detecting it and pretends everything is OK. If your new breaker trips on the first breaker's circuit, the curcuit it probably bad and the breaker in not working properly. The most common problem for failed circuits is a stray ground wire in a box somewhere in the curcuit resting against a hot or neutral wire. You'll have to take apart every connection on that curcuit to find it. Not fun.
Posted on Jun 27, 2009
When I plug my mod.#2711 into the wall receptacle it trips the 30 amp breaker at the house service panel. I disconnected frig. compressor and no trip.
time to call in a technician as there is a dead short , seized motor or an earth leakage problem in the insulation that is tripping the breaker
Nov 06, 2016 | Electrical Supplies
How to fix a Hotpoint fan oven that trips the circuit breaker or has no heat
In this video I dismantle, diagnose and fix a Hotpoint fan oven that was tripping out the earth leakage circuit breaker. It was the heater element which is easy and cheap to replace.
on Dec 02, 2015 | Hotpoint Ovens
Forgot to open water supply for my new washing machine and when it started flashing I only realized the problem.As soon as it washes it trips my main switch and says Earth Leakage????Please help!!!!!
Hello Dora,
An Earth-leakage circuit breaker (ELCB) is a safety device used in electrical installations with high Earth impedance to prevent shock. It detects small stray voltages on the metal enclosures of electrical equipment, and interrupts the circuit if a dangerous voltage is detected.
You should have an appliance service person come out for a service call since there may be a dangerous shock hazard present on the machine.
Apr 17, 2016 | Washing Machines
As soon as i plug it in the circuit breaker trips.
You have a short. It is either short to ground or short circuiting. Check the cord very carefully for breaks. Make sure the ground plug is in tacked. Also try a different outlet to make sure the problem is the tool.
Mar 13, 2016 | Dewalt Dw303m Reciprocating Saws
Bough this used and wired a outlet and breaker for it but it keeps tripping our breaker what am I doing wrong ?
How would anyone know , when you do not tell us what you wired up . I would call a local electrician tho and let him correct it .
Feb 15, 2016 | Electrical Supplies
When I plug in (and switch on) the hostess trolley it trips the electric in the house. However, works perfectly in another house.
sounds as if your home power distribution / Fuse board has an earth leakage trip and is sensing a leak on the trolley, perhaps the other house is not so well protected, or the Earth Leakage Circuit Breaker ( ELCB) trip is faulty. It would make sense not to use the trolley until you have had it checked out
Jan 02, 2016 | Televison & Video
GW708U Fisher and Paykel Washing machine Power Controller board trips earth leakage breaker
Hi your pump may be leaking the earth to trip breaker.
Check or replace the pump.
Feb 04, 2013 | Fisher and Paykel Washing Machines
When using the oven portion of the microwave oven it continues to trip the circuit the microwave is alone on a 20amp circuit .When I microwave it doesn't trip at all.Is it possible to move up to a 30 or 50...
If the breaker is an earth leakage type, it is possibly an earth leak problem which could be caused by insulation breakdown on the heater inside the microwave.
I would consult an aporved electrician for advice.
Jan 04, 2011 | Microwave Ovens
As load is apply inverter trip
Tripping Of Your Inverter / Circuit breaker when you use Kitchen range Can be because of Overloading or because of Short circuit . If There is an Earth Leakage Problem , Your RCCB may trip if you installed one .
Get Checked by an Electrician . you may need to use a higher rated MCB and Wires .
Please Rate my answer and Support me
Nov 21, 2010 | Kitchen Ranges
Washing Machines Logo
Top Washing Machines Experts
