Question about Cameras
Why my camera doesnt function and have no place for make setting?
  • Cameras Master
  • 5,360 Answers
Well, exactly, just what I say myself.
Posted on May 06, 2017
Cannon sx160 is, says ISO start tracking AF, what does this mean?
  • turn off your camera
  • set the knob to manual mode see if this works
Jun 05, 2014 | Cannon Cameras
Error code fe e
Turn the aperture ring on the lens to its smallest setting (largest f/number). You can control the aperture from the camera body, the same way as on a lens without an aperture ring.
May 11, 2012 | Nikon Digital Slr D100 D300s
My new 2month old..d300s..my if Switch Off it shows On..LCD goes Blank..no live view..on top LCD..doesnt show the details of memory card..like how many photos to be clicked..CF...PC doesnt ditect..etc.....
Hello. Turn it on and then go into the menu and find the reset function. Reset it. What this means is a reset to factory settings.
If that does not solve the problem return the camera while it is still under warranty. Joe
kindly rate my answer as 4 thumbs up. Thank you.
Oct 02, 2010 | Nikon D300s Body only Digital Camera
Nokia n73 main camera doesnt function
there may be something wrong with the settings but if you already check the settings there may be something wrong with the camera of the unit.
Sep 16, 2010 | Nokia N73 Cellular Phone
95 8gb camera preoblem
It might be a minor bug no worries, try using camera without inserting mmc if this doesnt works try formatting ur phone to factory settings if even this doesnt works try upgrading your phone to newer version If all of the above dont work there is hardware problem and u might have to give your phone at nokia care{service center}
Feb 20, 2010 | Nokia N95 Cellular Phone
My camera does'nt on anymore
I've been experiencing the same problem and fixed it today. The Kodak Easyshare C613 has a defective battery door design and should be recalled. The problem is that the small copper connector in the hinged door doesn't make good contact between batteries.
  • First, check that both AA batteries are fresh. Then verify that the batteries are inserted correctly. Unfortunately, this camera has contradictory polarity (+ -) labeling. The hinged door has a positive (+) marking stamped in the metal on the side toward the lens while the plastic housing has a negative (-) marking on the side toward the lens. The metal marking is correct, ignore the markings on the plastic housing. The nub (+) side of the battery should be facing out of the battery compartment on the side toward the lens. The flat (-) side of the battery should be facing out of the battery compartment on the side toward the strap.
  • If fresh batteries are inserted correctly and you still have a problem, then use a small piece of paper to wedge the batteries in place. I folded a 1 inch square down to 1/4x 1/2 inch and placed it between the two batteries. Now my camera will turn on every time.
Hope this helps.
May 23, 2009 | Kodak EasyShare C613 Digital Camera
It doesnt open the webcam
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Dec 30, 2008 | Logitech QuickCam Messenger Web Camera
My screen is black. Can you help me?
Found a very useful recommendation on:
http://www.fixya.com/support/t136499-black_screen
This corrected the problem!!
The hardest part was getting the metal bracket for the SD card holder back in place. It needs to attach to the back cover first before snapping the back cover in place.
Jan 23, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
SET button difficulties
How old is the Camera -still in warranty? Check out the Canon support site for a repair estimate
Aug 29, 2007 | Canon PowerShot S30 Digital Camera
Aperture priority only in manual mode?
Yes. You pick the apature (the 3000 keeps it aorund the setting you pick) and then it automaticly adjusts the speed for you.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Cameras Logo
46 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
