Question about Ovens
Self cleaning is complete, door is unlocked, have turned both Selection knob and Oven knob to "off". However, self cleaning light still lit up and there is humming sound from oven. How do i stop it?
catriver
  • 878 Answers
SOURCE: Oven shut down during Self-cleaning
tde, sounds like your thermal fuse (TC0) opened on the back side of the oven. If this opens, it will shut the oven down. This happens alot during self cleaning on built ins. Sometimes I have to re-route the tco to a different area to prevent this from happening. Your part number is 4451442. You will have to pull the oven out far enough to remove the back paneling and replace the fuse....Catriver..post back.
Posted on Oct 25, 2006
  • 6 Answers
SOURCE: oven door locked
First check to see if you activated the "child lock-out". See your manual to deactivate.
You could also try unplugging the unit, or trip the circuit breaker in your home which supplies power to the oven. Wait 5 minutes and turn power back on. This will reset the controls.
Posted on Jan 26, 2008
reg501
  • 413 Answers
SOURCE: cant unlock self clean oven door
Door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method.
Posted on May 29, 2008
SOURCE: Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Posted on Sep 22, 2008
SOURCE: "door lock" light stays on and oven won't work
Same problems. When I removed the lock operating arm nothing happened. Motor is not operating. I've temporarily kluged it by tying the "unlock" (upper) switch circuit together and disconnecting one side of the power to the "locked" (lower) switch. At least we'll have an oven to use, but I'll have to come back and remove the lock motor assembly to find out what's really wrong.
BTW, if some knows those keyed-in service codes they could be useful.
Posted on Oct 28, 2008
Unlock oven door on model #FGGS3065PF
If the oven display is showing LOC, then the lockout feature was enabled. Press and hold the key pad with the padlock symbol for 3+ seconds. This is just below the Timer On/Off key pad and to the right of the Light key pad. You should see the word DOOR and the padlock icon flash until the door is unlocked and the control panel is released.
If the word DOOR and the padlock icon are lit, then the oven is in the self-clean mode. The lock should release after you cancel the self-cleaning cycle by pressing off and the oven cools down (at least one hour). Unfortunately, sometimes the heat of the self-clean cycle will damage the oven. Either the oven temperature sensor will not give the release signal or the door lock will not disengage. In that case, the oven needs to have the correct part serviced.
The documentation for the Frigidaire FGGS3065PF is available on the product page at Home Depot: https://www.homedepot.com/p/Frigidaire-Gallery-30-in-4-5-cu-ft-Slide-In-Gas-Range-with-Self-Cleaning-Convection-Oven-in-Stainless-FGGS3065PF/204759413 . See page 15 for the Oven Lockout feature. See page 28 for the self-cleaning information.
I hope this helps.
Feb 13, 2018 | Ovens
Self cleaning lock handle does not unlock
Unplug power, wait one hower and plug cord back.
That should reset the oven, if it does not, the oven timer control is clearly defective and should be replaced , you find parts here.
Oct 08, 2008 | Thermador Ovens
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
Oven Was Self Cleaning. Bottom Oven Opens Top Oven Does NOt
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jun 21, 2010 | Whirlpool RBD305PD Electric Double Oven
The lock will not release after cleaning
This is GE's trouble shooting advise:
Range - Oven Door Won't Unlock After Self Clean
The Oven Door has been Locked Accidentally:
  • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
  • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
  • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
  • Note: Do not force the latch at anytime!
Door Will Not Unlock After Cleaning:
On models with mechanical latches:
  • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
If the above suggestions do not work try the following to unlock your door:
  1. Disconnect power to range for 30 seconds.
  2. Reconnect power and see if door will unlatch.
  3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
  4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
  5. Wait approximately 30 minutes and try to unlock the door.
  6. If the door unlocks, the control has reset itself and there should not be any other problems.
  7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
Note: Under no circumstances should you ever force the door or latch open.
May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
Moffat Self-Cleaning Oven will not self-clean
did you try setting a start and stop time with the time knobs? i had the same problem til i set 3 hrs on the start and stop, then let it sit (after locking the door and turning the knob to clean). after it was warmed to cleaning temp, the light for cleaning came one...
Nov 10, 2008 | Ovens
Jenn Aire lock for self clean in locked position
The LOCK INDICATOR light must be OFF. This can take up to one hour!!!
Do NOT force the door.
Leave the SELECTION and TEMPERATURE knob alone. The Temperature knob MUST be set to CLEAN
Indicator Light OFF, knobs set to CLEAN - OPEN the slide lever.
Lever open, set the knobs to OFF and away you go
Oct 26, 2008 | Jenn-Air Ovens
Frigidare Self Clean Oven
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
3. PRESS THE "COOK TIME" BUTTON
4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
5. PRESS "START" BUTTON
6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
Sep 30, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self cleaning frigidare oven FEF368CCTD
If this stove has knobs, Make sure the clock keeps time. If it doesn't you will have to manually turn this off. (DON"T FORGET OR LEAVE WHILE CLEANING) Make sure there are no large puddles of oil or grease on the bottom of the oven.If the oven is really dirty it may stink a little. Nothing but the racks can be in the oven.Press the lock button and slide the lock lever to lock the door. Set the stop time for 3 hours and turn the knob by the clock to auto. Turn the oven knob to clean. (MAY have to push to turn all the way to clean) It should start heating up. Let it finish and then cool down. It will not let you unlock or open the door until it is completely cool. Wipe out any remaining ash with a wet rag. ALL CLEAN!
Jun 28, 2008 | Ovens
Door won't unlock after self clean
Try turning the breaker off for a few minutes, If that doesn't work try restarting the self clean mode and canceling after it starts. If that fails list a brand and model number with the problem.
Mar 02, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
