Question about The Computers & Internet
The jacks won't work on a 575 135 loadall - The Computers & Internet
Sound won't work on my Disney dvd/tv combo
Either the speaker is bad or broken wire OR more likely the headphone jack is the issue---when jack comes out it lets a leaf in the socket engage the speaker back----when used a lot the jack causes no sound.
Nov 02, 2012 | Disney DT1350-C 13" TV
IRiver E100 headphone jack
The connector is defective - probably just wear and tear
Aug 15, 2017 | iRiver E100 Digital Media Player
My computer won't turn on i can get to the internet because it has an internet button but the main part of the computer won't turn on
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Aug 19, 2011 | Sony Computers & Internet
My computer won't turn on and when I plug it in the charging light won't come on
Please check the adpter output voltage with multimeter in DC mode.
If output voltage is good then check any contact problem of the power jack with laptop dc jack for proper contact.
Try to power on with only ac power supply by removing the battery.
Jun 14, 2011 | Computers & Internet
Garmin nivi 200 won,t turn on
The mini-USB jack needs to be either resoldered or replaced. When the jack is loose, you will not be able to charge the internal battery. The jack becomes loose from overuse. The jack needs more mechanical support to the pronted circuit board. I have fixed this problem many times.
- Jim
Aug 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
Loadall automatic greaser just stopped working
clean it out completely and try it again they sometimes get air locked
Apr 23, 2009 | Lincoln Lubrication 2 Way Loading Lever...
Drive problem
Posted in wrong category!
May 23, 2008 | Jcb Refrigerators
Computers & Internet Logo
29 people viewed this question
Top The Computers & Internet Experts
Carl Rick
colinat108
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
