Question about Dryers
White knight 44aw tumble dryer with no heat the reset button will not press in all filters clean ... any ideas
MNfisherman
  • 11896 Answers
SOURCE: i require the instruction manual for a white
COpy and Paste any of these links in your address bar.
Here is the link for a wiring diagram
www.howtomendit.com/answers.php?id=128502
Manual links;
www.ciao.co.uk/White_Knight_44AW__Review_5857836
or retrevo.com, repairclinic.com, appliancepros.com, or appliance411.com
Posted on Sep 26, 2009
beltronic205
  • 1474 Answers
SOURCE: White Knight sensordry tumble dryer which only works on low heat
Could be element or thermostats, element is twin giving two heats ie !00watt/ +1800watt, possible one side has gone, you bcan check with multimeter and compare readings..Good luck
Posted on Oct 01, 2009
  • 497 Answers
SOURCE: White Knight 44AW electrics problem
You may have a short in the system, make sure your breaker is rated high enough to support the dryer
Posted on Oct 06, 2009
  • 534 Answers
SOURCE: my white knight tumble dryer does not heat
you have a heating element burnt out. You will need to remove the back of the dryer and in the bottom of the dryer casing you will see the element Looks like a toaster element. Take model and serial # to an appliance parts house for replacement. An appliance tech shouldn't charge you that much to repair if you dont want to do it yourself.
Good luck hope this helped you some
Dave
Posted on Jan 28, 2010
  • 494 Answers
SOURCE: WHITE KNIGHT TUMBLE DRYER NOT DRYING?
Here's a few things to check that most people can do on their own. Keep in mind, that if you start taking the unit apart, you need to unplug the unit first. We don't want anyone getting zapped!
1) Obvious things first. If you have a propane gas dryer, make sure you are not out of gas! Go to the tank, lift the lid, look at the % gauge. If it's pointing at 5% or less, you may be empty or about to run out of gas. Order a gas delivery.
2) Another obvious tip. Check your lint filter. It may be so clogged that your dryer can't breathe. Clean it. Using a flashlight, look down into with the filter opening and see if there is a lot of lint still inside. If so, try using a small vacuum attachment and clean out lint. This applies to both gas and electric2_bing.gif dryers.
3) Most gas dryers have either a small access panel in the front or at the very least, a peep hole. Open the panel or pop out the plastic peep hole cover so you can view the igniter. Turn on the dryer and watch for orange glow at the burner. If it does not glow, it will not light the gas burner. You may have a broken igniter and will need to replace it or have a new one installed. If you do it yourself, be sure to unplug the dryer and do not touch the very fragile ceramic piece of the igniter. You can confirm it is broken by locating the broken piece below where it is attached or noting it is missing a piece of ceramic on the igniter.
4) This tip applies to both gas and electric models. Another thing you can do is check for blockage in your vent. Unplug the dryer, and pull the unit out as far as you can to get access to the back of the unit. Be careful not to step on or kink the gasline. Pull the venting off the back of the dryer. There is usually a squeeze clamp holding it on. Clean out lint in dryer and from within the vent tube. Some cheap venting are made of expandable plastic or aluminum and can get squished to the point they restrict air flow. Make sure your vent is not collapsed and doesn't get squished when you push the unit back. Once you have cleaned and reassembled it, plug it in turn on the dryer and watch for ignition. If it lights, go outside to the vent cap and check for lint there and make sure your vent flap opens with the hot air flowing out. Clean and adjust as necessary. If you have a long vent tube like I have on mine, then you should clean it out annually. I use a wind-up toilet snake and crank it around knocking lint loose from the walls of the vent. I can always tell when it needs to be cleaned again, when clothes2_bing.gif no longer get dried in the first cycle. If you are unsure of, or unable to perform this task, then you'll need to hire a repairman.
Anyway, these are just the easy, quick fixes that most homeowners2_bing.gif can perform on their own. If none of these solve the problem, you will need to troubleshoot further or hire a repairman. Hope this helps.
Posted on May 23, 2010
I have a White Knight tumble dryer with reverse action, model 0312 44A 15003. The timer does not count down. It heats up fine. The reverse action never happens now. Any idea what needs fixing?
You need to check your schematics on the electrical and find, then replace the sensor that controls the timer, then the reverse action. It may need removed then replaced to reset. Be very careful and aware of the eletricity going through the system.
Jun 12, 2017 | Dryers
Tip
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our
video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
on May 10, 2010 | Abbaka White Knight 44AW Electric Dryer
How do i wirea white knight tumbler dryer heater
take the back off look for heater and follow wire make up two wires the same colour fit a spade clip to both ends and replace
Mar 08, 2015 | White Knight Press 44AW White Tumble Dryer
Hi does anyone know how to replace door gasket on white knight 44aw dryer
Look under the lip near the mounting area. There should be a spring, just gently pull it around till it is 180 degree or more . it will fall off.
Jul 26, 2014 | White Knight Press 44AW White Tumble Dryer
White knight 44aw
There should be a tiny red reset button on the back. If you press this, it should resolve the problem
Dec 30, 2013 | Dryers
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
Yesterday the trip switch for the downstairs mains sockets tripped. When i reset it and plugged switched on my White Knight 44AW drier it span as usual but now there is no heat.
For a full list of appliance Video Repair help see our video section
Jan 19, 2010 | Abbaka White Knight 44AW Electric Dryer
White Knight tumble dryer making a clicking noise when on & has no heat
utube.png You-Tube video "XNxE9eXx2Rk" placeholder (do not delete) utube.png
May 02, 2009 | Dryers
Dryers Logo
Top Dryers Experts
