Question about Blenders
The shaft or drive coupling is RB75 blender. How do I replace it and which parts will I need?
  • 22 Answers
SOURCE: broken blender coupling
Try going to MarBeck.com they are a great source for small appliace parts.
http://www.marbeck.com
Posted on Dec 22, 2008
SOURCE: can't get drive coupling off bosch unversal blender blade fixture
what you need to do is hold the blades with a towel to protect your hand, then, use a visegrips needle nose to grab the coupling (pushing the guard down) and twist it loose. It may be very tight, when I loosened mine, the plastic portion of the coupling pulled off leaving the metal "nut" tight to the shaft. Either way, remove the coupling/nut in the standard "lefty loosey" direction. Many thanks to the people at pleasanthillgrain.com for walking me through the process. Blessings to you.
Posted on Jun 01, 2009
SOURCE: need to order parts for food processor for stainless steel blende
I neede a new blade unit for my phillips smoothie maker, I just googeld the model number + spare part and was redirected to the websites! Eventually you fine it!!
Posted on Sep 23, 2009
SOURCE: The blender coupling on my
10-01-2009 Sara - see solution for rlaymon 1-9-08 "Top part of base broke off" by TanyaCS on 1-20-08 - good ideas. I just fixed mine - 2 hour job + half hour to put a new cord in. Like TanyaCS my broken coupling was rusted to shaft - used WD-40 twice and let sit - meanwhile took out motor and removed fan - kept screws and washers in order on workbench (kitchen counter) - the fan hole is "D" shaped - fan end of shaft also "D" shaped - I filed a "flat" on the other side of the factory "flat" (side of 'D' that is straight) - Used big pliers on broken coupling and adjustable wrench on on the "flats" on fan end of the shaft. Broken end came right off. New cord is 18 gauge extension cord capable of at least 6 amps. Cut off the un-needed end. Or order a replacement cord $4 when you order the rubber drive coupling $4, pin with slinger washer $3. Bet you also need new rubber feet - didn't buy for mine - wish I had. Bert
Posted on Oct 01, 2009
EwingElect
  • 276 Answers
SOURCE: braun hand blender shaft coupling has rounded
Refer to http://braun.com/ to find the website for your country.
Otherwise, refer to http://braun.com/us/consumer-service.html which will help you locate a local Service Center.
Posted on May 20, 2010
How to replace waring blender 028538 drive coupling
Check and see if your blender was made in China.
If so, the chances are really slim for a finding parts for a fix.
If it was made in the USA, try "e-bay" for parts.
If you need a parts list, you will need to find one first.
Also, type Waring Blender into your search engine on your computer, to see if a dealer or repair place has a web-site.
God bless your efforts.
Sep 16, 2016 | Waring Blenders
Replacement end coupling
Possibly an appliance parts supplier can help.
Nov 27, 2013 | Waring WSB40 Blender
The coupling to the motor is loosely rotating on the motor shaft. Has the threads on the coupling worn out. it is a breville optiva cbl6 blender
The coupling bush wear out in due time and must be replaced. if there is a wearing detected it must be changed or it will result in failure of the bush/ bearings of the motor and jar. You will need to remove using anti clockwise direction, Get the correct spare part from the dealer to replace. Good day
Aug 16, 2010 | Blenders
THE COUPLING WITH TEETH THAT LOCKS INTO THE BLENDER BOWL CAME OFF. HOW DO YOU REPLACE IT? DOES IT GLUE ON?
Actually the drive gear was vulcanized onto the shaft during the production. If you can get glue to hold it on you're all set but I think you'll end up replacing the whole blender soon. Thank you, Dana
Oct 18, 2009 | KitchenAid KSB3 Classic Work Top Blender
I have a Waring Pro Speciality Blender. After only a few times in use, the jar began leaking and I noticed glass shards around the outer rim of the jar. The blades are fixed on this model. I wrote to the...
If you don't see a physical crack or stress line on the jar, the issue could be either the gasket or blade assembly - Waring doesn't list any parts for sale for this model, but you may be able to call them and get these parts. There are not very many reviews on this particular Waring, so I am working with very limited information (and this is just my opinion), but the few that I have seen suggest that this might be the worst blender Waring ever made (in general, though, their blenders are usually top-notch).
Consumer Guide generally rates it high, but issues this:
"Cons: Strong churning motion requires you to hold the lid in place to prevent leakage through the top and limits the ingredients capacity, especially for hot mixtures"
The sites that invite the most user input into the rating generally give it a 2-star rating.
Waring seems to have escaped somewhat from their usual blender shape - and I have even heard that the shaft is made out of rubber, which is frightening.
Mar 31, 2009 | Waring RB75 Specialty Blender Stainless...
Can't get drive coupling off bosch unversal blender blade fixture
Mar 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
The blender coupling on my oster snapped in half. I have the replacement part already I just cannot figure out how to get the broken coupling off the base of the motor. I also got a replacement square...
Jul 11, 2008 | Oster 465 Work Top Blender
Broken gear on BFP-703 base
The drive is replacable and available from Cuisinart, you will have to sign a waver to get the part. the drive is screwed onto the motor shaft with reverse threads. the plastic drive will have to be completely broken off of the unit to expose a brass"nut" which was internal to the drive. depending upon your model you may have to remove the lower half of the base unit to access the lower part of the motor shaft. there will be a slot in the end of the shaft for a large flat blade screwdriver. this is used to hold the shaft still while turning the drive "nut" with a vice grip pliar or similar. the new drive is just threaded onto the shaft and normal operation tightens it.
Feb 14, 2007 | Cuisinart BFP-703 Blender
Blenders Logo
85 people viewed this question
Top Blenders Experts
eyecam
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
