Question about Krups Coffee Makers & Espresso Machines
My krups EA80 NOT WORKING RED CALC LIGHT FLASHING WHAT CAN I DO?
2 Suggested Answers
SOURCE: I have a Krups Espresseria Automatic. All lights flash
The "calc" light on and pulse.
Posted on Apr 01, 2011
Can on/off red light be fixed on a krups 321. cofeemaker works
The bulb in the switch button will be faulty, it is not available separately from the switch and the switch is obsolete with no alternative part number supplied.
Sep 21, 2015 | Krups ProCafe 321 Coffee Maker
Krups ea8010 expresso machine The CALC light comes on when switching on the machine . Then after 1 min it's starts spraying water from the frother . And keep doing that every 1 min. What should I do ?
It seems like it is part way through the descale process, put 500ml of water in the tank and let it run. Once tank is empty after a couple of minutes it may detect nil water and request next part of the process. If not then brain may be scrambled which may involve a trip to authorised service agent.
Mar 17, 2015 | Krups Coffee Makers & Espresso Machines
What to do when you see CALC indicator on Krups
clean the maker with CRL and that should take care of it
Jun 22, 2014 | Krups Coffee Makers & Espresso Machines
Krups ea 8010
Error code 9 is temperature detected as too high or too low. Check NTC on boiler
NTC fault (component, bonding, connector, wires...)
Coffee leakage on NTC (resistor value)
Jan 15, 2014 | Krups Coffee Makers & Espresso Machines
Saeco intuita- performed clac/ clean, and now calc/ clean fast flashes. Pressing only goes to slow flash and water dispensor light fast flashes.
Use a paper clip to clean the Needle that penetrates the Kcup. If it still happens call 1-866-901-2739 for direct assistance.
Dec 29, 2013 | Keurig B60 Coffee Maker
What do you do when it says calc. on the display?
Calc is indicating that it's time to descale the lime build up inside your coffee maker. Most machines are easily cleaned by running a solution of 4 parts water to 1 part vinegar. Run this solution through a regular coffee cycle (no coffee). After running this solution, you may want to run straight water once more to ensure there's no vinegar aftertaste. Your machine will now be clean and the CALC message should disappear. If not, post back with the Model # of your Krups coffee maker for further instructions. Some machines have a Descale or Self Cleaning option built into them.
Apr 24, 2011 | Krups Coffee Makers & Espresso Machines
On FME4 coffee maker the error message CALC
it means de"CALC"ify its detecting calcium build up the manual says to run white vinegar without the filter followed by two clean water cycles goto krups.com to download the manual
Oct 10, 2009 | Krups FME4 Coffee Maker
Flashing red light
Just found the answer!
The type 453 coffee maker offers a carafe ‘pre-warm’ function.
This feature will heat the carafe for 5-10 minutes before the brewing process begins and is indicated by a flashing red light.
To toggle this feature, push the top-right button in the control panel until the display reads "off".
Aug 08, 2008 | Krups ProAroma 453-71 Coffee Maker
The display reads CALC.
I have a Krups model FME4 and it means that you should descale the machine. Here's a link to the use and care instructions for my model, I assume it would be the same for yours.
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Use+and+Care/ResultUseAndCare.htm?SelectedService=Use%20and%20Care&SelectedGuIDService={EC10140D-AA43-4DCA-8D3A-A5A4823D9E52}&SelectedProdRef=FME4
My problem is that CALC continues to display even after I've descaled several times. Good luck with yours.
Oct 30, 2007 | Krups ProAroma 453-42 Coffee Maker
Coffee Makers & Espresso Machines Logo
110 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
