Question about The Office Equipment & Supplies
Printer does not print.goes trogh the printing but paper is clean i have new ink
  • Deneen Lewis
    Deneen Lewis May 06, 2017
    what is your model number on printer?
    Also, which program? WORD, Excel or PPT?
    Master:
  • 636 Answers
Try doing a nozzle check and print head cleaning... These options can be found on the printer software.
Posted on May 06, 2017
The head cleaning cannot be completed by the printer?
Epson printers use a lot of ink to do head cleaning. If you're low on ink, it will give you that message. Put in new ink carts, and head cleaning will happen. You may want to purchase "cleaning carts" that have a special solvent to help un-clog the print heads.
Sep 11, 2014 | Epson Office Equipment & Supplies
I put new ink cartridges in my hp 2575 about ~six months ago and hadn't used the printer since then. I tried to print and it goes through the motion of printing but nothing shows up on the page. The...
The Ink at the head of your Printer Cartridges has dried up.
Try this:
Load some plain paper in the printer
Remove the cartridges from the printer and carefully dab the print heads of the cartridges with a damp paper towel. ( when you start to see ink, the ink is starting to flow).
Replace the cartridges into the printer.
Go to:
Start
Control Panel
Printers
RIGHT click on this printer
choose Printing preferences
services
clean print cartridges 9some papers may print)
follow the instructions and do the heavier cleaning as well
Run the calibration function and allow the paper to print.
Jan 10, 2011 | HP Photosmart 2575 All-In-One InkJet...
All 8 new ink cartridges, new MT tank, nothing prints. it goes thru the motions of rinting, but no little to no ink is on paper, less and less ink each subsequent print. Most recent print has a hint of...
take your ink cartridge out from your printer. you can see at the ink carriage there are little pipes where the ink usually flow from cartridge. If head cleaning and power cleaning does not work, then try to clean those pipes by using 96% alcohol fluids and **** the pipes using something.
Sep 12, 2009 | Epson Stylus Pro 4800 InkJet Printer
Acts like it's printing, ink is good, but nothing prints out on paper.
Nothing at all? Poor you are. The pump may damage or lost electricity.
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Nothing prints out on paper.
Did you remove the little sticky tabs from each new cartridge? They allow air in, and ink out.
Have you removed the tear off tape from top of cartridges, it lets the air in and ink flows.
May 28, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Canon Mp480 wont print!
you have a purge unit problem, if you have done a few cleans then throw machine away cost more to fix it. but a new printer
Canon tech
Mar 30, 2009 | Canon Pixma MP480 All-In-One InkJet...
Printing problem - you cannot see the ink on the printed papers
The ink is not flowing from the cartridges to the paper. The reasons for this can be numerous, so we must tackle it step-by-step, which will require a bit of interaction between us.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles (this will waste ink). Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back with a new comment.
Feb 20, 2009 | Epson Stylus C84 InkJet Printer
Epson c60 printer
Common problem with Epson Printers.
Either the print head is clogged, or the tube that goes from the pump to the printhead fell off.
Open the printer cover so that the ink cartridges are in open view and then UNPLUG THE PRINTER" so that the ink cartridges wont go back to home position. (If there is a change INK cartridge button, then press that then uplug the printer when the cartridge stops moving.)
You can try to clean the print head by folding up a couple paper towels, then saturate it with windex with amonia. Place it under the print head assembly and manually move the print head assembly over the paper towel back and forth to clean the bottom of the print head assembly. You should start seeing ink on the paper towel.
After cleaning, run the cleaning program that Epson has, and try it out.
If it still doesn't work, then you might have to repeat this a couple more times.
If it still doesn't work, then it might be time to get a new printer.
Hope this info helps.
Good luck.
Mac
Feb 07, 2008 | Office Equipment & Supplies
No ink is coming from my ink cartridge?????
Hi, I find this problem occurs when the Print Head dries out. You can buy special cleaning fluid for this. Just google search for "epson 440 print head clean" You can clean the print head yourself with some warm water on a lint free cloth but this is quite messy.
Aug 25, 2007 | Epson Stylus Color 440 InkJet Printer
27 people viewed this question
Top The Office Equipment & Supplies Experts
Victorman
Victorman
micky dee
fhonwizards
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
