Question about Garden
I have a murrary 300 e lawnmower its recoil string came off and I rewound it but when put it back on it won't turn the fly wheel
  • 11 Answers
SOURCE: i need to pull the fly wheel off of my lawnmower
get a flywheel knocker. you will either place it over the threaded crankshaft top or thread it on. then, hit the knocker with a hammer while GENTLY prying the flywheel up.
Posted on May 23, 2009
  • 61 Answers
SOURCE: recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Posted on Jul 04, 2009
  • 78 Answers
SOURCE: Recently, the rope recoil mechanism on my lawnboy
Im sorry but it sounds like the spring has broken. So I am not that familiar with Lawnboy but some rewinder are not serviceable and the whole housing has to be replaced .
Posted on Oct 22, 2009
wadembly
  • 513 Answers
SOURCE: I have a toro self propelled lawnmower. Ireplaced
the spider gears are in on the wrong side more less like you put the rear end in backwards
Posted on Nov 10, 2009
kel1guy2002
  • 3740 Answers
SOURCE: pull string won;t recoil
The recoil spring has broken. These are available at any lawn mower parts supply store. The process of changing the spring is tedious but can be done by anyone with average mechanical ability. If you removed the recoil assy (and air shroud if it is riveted on) and took the assembly to a Lawn Mower Repair shop usually they will change out the spring while you wait. If you can't get the recoil assy off take the mower with you to the repair shop. Again most shops will fix it while you if wait but if they are very busy usually they are serviced within 24 hours.
If you do attempt this yourself check in the tips section of FixYa on how to change the recoil stater rope after replacement of the spring.
I highly recommend you replace the pull rope at the time of the recoil spring replacement.
One final note... there is a possibility that the pull rope spool has been damaged where the spring attaches.
Thanks for using FixYa,
Kelly
Posted on Apr 29, 2010
Honda issy lawnmower engine will not stop once startedl
I suspect the braking pad and or mechanism around the fly wheel is worn, mal-adjusted or disconnected. Hint start at the bar you are supposed to pull down to the handle in-order to start the mower, follow the cable, check the spring loaded mechanism the cable connects to & then remove the recoil to examine the brake band. See if it works and if it has worn down. Repair/replace as needed.
Feb 27, 2016 | Honda Garden
Why won't mypull string recoil
when it broke it may have unwound. the spring has to be wound up before it will recoil. you tube has many videos to show you how to rewind the spring. be careful as when wound up it has pressure on it. also be sure to back it off one turn past the string hole so if you pull all the way out it will not break the spring.
Jan 30, 2016 | Garden
HOW TO REPLACE RECOIL SPRING IN FG110
the rope probably has broken at some point and they did not relode spring enough take the take the spring housing off remove the rope relode spring stick a screwdriver in it to keep it there put rope back on pull screwdriver out put it back on
Apr 26, 2015 | Honda FG110
How do I get my jiffy ice augerI need the pull starter to connect to the engine where does the pull starter rope connect to the motor
The pull starter connects to the recoil starter which sits on top of the engine. When the string breaks, it can be rewound or you can buy a new recoil starter @ Jiffy http://www.jiffyonice.com/EComStore/pages/home.aspx
Dec 24, 2014 | Garden
Pull string won't recoil
its your Recoil spring that is causing it to do what it is doing it may have came off or broke
Jun 07, 2013 | Garden
Pull rope will not pull
Remove recoil rope assembly. Ensure rope is properly wrapped around. While recoil assembly is removed use ratchet and socket to rotate fly wheel, remove spark plug first, observe compression and exhaust at spark plug whole during rotation of fly wheel. Clean or replace spark plug. Ensure oil is full. 30w. Set spark plug gap. Always use Stabile in gas. Replace coil rope is required. Purchased by the foot at any mower repair store.
May 12, 2013 | Toro Super Recycler Super Bagger Lawn...
The starter cord jammed on recoiling, after attempting got release it the recoil spring rewound, now the cord and spring are interlocked. I'm looking to strip the recoil mechanism but I believe I
Its an easy opperation to undertake if you know how. Take note of where everything goes during the stripping down of the recoil assembly. Use eye protection when trying to recoil the rewind spring, they have a tendency to jump back out at you while coiling them back in. easiest way is to start by putting the hooked end into the plastic housing and work your way inwards coiling it back in. Then place the starter cord roller in on top, adding the one or two black sliders, the washer and the spring clip to hold it all in place.
Feb 16, 2013 | Stihl Trimmer Oe Rewind Starter Spring 36...
Recently, the rope recoil mechanism on my lawnboy mower would not recoil completely or not at all. I removed the complete recoil assembly and the rope in order to rewind the coil, which appeared to be...
Oct 22, 2009 | Garden
Recoil not recoilling good
hey fark
This is easy. Take off rope housing (four screws). Once off, pull the string out 3/4 of the way. Once out, tie string around spindle one extra time ( real easy just wrap string once more around winding spool ). This oughta make string snap back after pulls.
Jun 28, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
