Question about Coffee Makers & Espresso Machines
Red calc light flashing machine not working? - Coffee Makers & Espresso Machines
When I turn on the coffee machine flashing red button calcing. and 'put in a container for water descaling solution., when I hold the button for more than 5 seconds nothing happens.
push it for 5 second and if its still flashing doesn't matter turn the steam knob anti-clockwise end let the machine do to the descaling cyrcle, when then water tank emptied the rest of buttons starts to flashing, turn the knob off and your machine is ready!!
Jan 12, 2014 | Gaggia Syncrony Compact Coffee...
Saeco intuita- performed clac/ clean, and now calc/ clean fast flashes. Pressing only goes to slow flash and water dispensor light fast flashes.
Use a paper clip to clean the Needle that penetrates the Kcup. If it still happens call 1-866-901-2739 for direct assistance.
Dec 29, 2013 | Keurig B60 Coffee Maker
Intuita coffe machine not working
Needs a service take it in let them replace the seals,If the seals go faulty this happens
Dec 29, 2013 | Coffee Makers & Espresso Machines
Calc-clean function light keeps flashing
Press the reset button
Nov 12, 2013 | Irons
Descaling problems
Don't run the clean operation. Just put white vinegar/ water, half and half and run as if making coffee. Let it cool and run through about 3 times and this will remove all scaling/buildup.The rune through plain water.
Nov 08, 2013 | Coffee Makers & Espresso Machines
What is error code 4 on a Candy washer (GO 682)? Stain Vanish and 90m light are flashing 4 times.Thank you.
the problem may be caused by too much dirty inside the washing machin such as soap and or calc.
it can be the water level pressostat faulty
Apr 07, 2011 | Candy Washing Machines
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
