Question about Lands Phones
Entering redial numbers - Lands Phones
Automatic redial phone option
On most cell phones, to redial the last phone number dialed, press the green phone icon when the keypad is displayed on the screen. You can only redial the last number dialed. To obtain a copy of the user manual, follow this link and download the pdf. http://www.gsmarc.com/huawei/ascend-g610/manual/
Nov 14, 2013 | Huawei Cell Phones
Needs to reprogram fax machine, has old fax numbers in
1. Press Menu/Set, 2, 3, 1.
2. Press the One Touch key where you want to store a number.
The LCD shows the location you selected.
3. Enter a number (up to 20 digits), and then press Menu/Set. If you want to enter a pause in the dialing sequence (for example, to wait for an "outside line"), press Redial/Pause as you're entering digits. A dash appears on the LCD. Pressing Redial/Pause enters a 3.5 second pause when the number is dialed.
4. Use the dial pad to then enter the name (up to 15 characters), and then press Menu/Set. You can use the chart on page 4-2 to help you enter letters-OR-To store the number without a name, press Menu/Set.
5. Return to Step 2 to store another One Touch number-OR-Press Stop/Exit.
When you dial an auto dial number, the LCD shows the name you've stored, or, if you haven't stored a name, the number you've stored.
If you loose electrical power, auto dial numbers in memory will not be lost.
(For USA Only) One-Touch key 1 has been pre-programmed for the Brother faxback system. One-Touch key 2 has been pre-programmed for the CallManage long distance plan. You can override them if you wish.
Note If you need to store a pause longer than 3.5 seconds, press Redial/Pause two or more times.
Note - You can store Groups (for Broadcasting) on the One Touch keys.
Dec 11, 2010 | Brother IntelliFax-2820 Laser Fax
We lost our manual and I am trying to reload our speed dial numbers. I have tried everything but can't seem to figure it out. Help?
1 Press Menu/Set, 2, 3, 1.
2 Press the One Touch key where you want to store a number.
3 Enter a number (up to 20 digits), and then press Menu/Set. If you want to enter
4 Use the dial pad to then enter the name (up to 15 characters), and then press
press Menu/Set.
5 Return to Step 2 to store another One Touch number-OR-Press Stop/Exit.
Dec 07, 2010 | Brother IntelliFax-2820 Laser Fax
How to fax
Load an original in the automatic document feeder (ADF)
You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
placing it in the document feeder tray.
The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
sheets of legal-size paper.
To send a basic fax from the control panel
1.
Load your originals. For additional information, see Load originals.
2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed
dial button to select a speed dial, or press Redial/Pause to redial the last number
dialed.
TIP: To add a pause in the fax number you are entering, press Redial/Pause,
or press the Symbols (*) button repeatedly, until a dash (-) appears on the display.
3. Press START FAX Black.
If the device detects an original loaded in the automatic document feeder, it
sends the document to the number you entered.
TIP: If the recipient reports issues with the quality of the fax you sent, you can
try changing the resolution or contrast of your fax.
for further refernce check out the online manual
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Mar 29, 2010 | HP Officejet J3680 Multifunction Printer...
How do you use the Redial function?
Redial in ITR-8D-3 IP Phone
Press key to activate redial feature. Press redial and scroll back through
numbers that have been dialled. Until the desired number is displayed. Press the * key to activate dialing
Nov 05, 2009 | NEC ITR-8D-3 IP Phone
When I redial a number outside of my area code, how do I set up my phone to redial an automatic 1 before the number I want to dial? I have a GE cordles 28111 model
I can't redial.. How do I set up my phone to redial an automatic 1 before the number I want to dial? i have a GE digital 5-8
May 07, 2009 | Uniden Cordless Phone
Owners Manuals are missing after the office remodel
Redial is used by pressing the redial button to access the stored numbers, each press brings up another number. To dial the number you want hit the # key. i.e. to dial a number you called 3 phone call ago you press 'redial', then 'redial', then 'redial' followed by '#'.
Apr 14, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Speed dialing
· Without lifting the handset, press redial button. Press the button on the strip you wish to store the telephone number on. Note that these 5 buttons are position numbers are 100, 101, 102, 103 and 104. 100 is the first button above EXT PICKUP, and 104 is the first button below DND. These numbers can also be programmed using the method in Step 2 below and entering the position number (100 – 104).
· Enter the telephone number. Be sure to program the 9 in front of all local numbers, and 9+1+(Area Code) in front of long distance numbers.
· Press redial.
· To use the numbers stored on these buttons, lift the handset and press the button.
Oct 29, 2007 | Toshiba DKT-2010 Corded Phone
Lands Phones Logo
35 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
