Question about Hisense Televison & Video
How can I fix the power button on my Hisense model LTDN55XT770XWAU3D TV. All other buttons work perfectly.
  • Allan B
    Allan B May 06, 2017
    Tx Gian. Problem was that the power button was worn down. Repaired it by inserting a piece of foil between the button and the contact point.
  • Allan B
    The problem was that the power button was worn down. Problem resolved by inserting a piece of foil between the button and the contact point.
    Problem Solver:
  • 8 Answers
The problem probably is that the power button on your remote is jammed or stuck, try pressing it a couple of times to check if its the button or the remote itself is the problem.
Posted on May 06, 2017
Is there a reset?
An internal fuse may be open
Nov 02, 2017 | Hisense Televison & Video
I have a Hisense 50M700UW TV. It works perfectly except for one problem. When we try to watch netflix through out Fetch TV box the sound comes out as a high frequency unintelligible mess.
You cannot hot swap HDMI connections. First thing to try is to power off and unplug all the devices from everything. Then make the connections to the Fetch and the Television, Then power to the Fetch, then the television, then turn on the Fetch, then the television. There is also a chance that the HDMI cable is an older one and needs to be replaced.
Feb 17, 2017 | Hisense Televison & Video
How do you turn up the volume on hisense ledn32d33 without a remote
See if the set has volume controls on it. Some sets have a power switch and volume/channel controls on them.
May 29, 2016 | Hisense Televison & Video
Hisense tv factory reset :
To do a factory reset; you should enter its service mode option. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy.
Service mod entry, adjust and exit procedure to many popular brand TVs are given in detail.
Jan 23, 2014 | Televison & Video
The GUIDE button on the remote (model EN-33926A) for a Hisense 55K610GWN does not work
my children messed around with the remote and now i can turn the tv on from the actual tv but from the remote when i press channel up or down or hdmi buttons it turns the tv of.. remote model en-33926a
Dec 19, 2013 | Hisense Televison & Video
hello, i've repairing one at the minute with same fault, but you could try this i'm not going to say it will work but can try it. turn the tv off and back on again with the tv on press the menu button while taking the power lead out keep your finger pressed on the menu button and replug the lead back in if it works the menu will come back on the screen you might need to retune it back in. i hope it works
regardsshaun
May 12, 2012 | Hisense Televison & Video
HiSence Flat Panel TV, Model TL 2020
Hey Billy Lee,
If you're unsure how to unlock your TV, you may wish to check out Hisense's online documentation for the TL-2020 through the following link:
http://www.hisense.com/en/Support/download_manual.jsp
Instructions on how to disable any feature locks should be included in downloadable files on "page 9" and "page 10" of Hisense's support forums.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 22, 2008 | Hisense TL-3220 Television
My Hisense lcd is lock.
This is how I got mine to work after weeks of struggling just trying to find a new remote (hisense is really hard to contact....).
1) Turn the TV ON. unplug the tv while still ON 2) hold down the "menu" button on the side of the TV and plug it back in. keep holding it down. the TV should turn on with the menu popping up. use the Vol <> keys and Channel <> keys to navigate the menu. go to the Vchip menu, and play around. I'm not sure what ultimately worked, but i changed the Vchip password to 1111, turned the reset menu to "on" and played around with the ratings settings (turning most of them to "u"s etc).
I went through this process several times and finally, the black background behind the menu turned to static. I played around with the channels, and the TV was unlocked. I turned the TV off, and then on again, and the channels showed up normally (no static). and it was no longer locked. I had to do the unplug thing several times, and was getting really frustrated looking for an "unlock code" in the manual (it just says press the button on the remote. so it was not really helpful).
But really, once you can just get to that menu you've made some progress, and just keep playing around with it until something works.
Best of luck!!
Jun 03, 2008 | Hisense TL1700 17 in. LCD Television
Hisense TL2020 LCD TV
Try turning the main power switch on the back of the tv off.
Then hold the menu button and push that switch back on while still holding the menu button.
Keep holding the menu button until the setup menu pops up.
Next, be sure your input is set correctly(air or cable).
Next, do an auto channel search.
That did it for me. After I shut it off I had to do it one more time but it did the job. A friend of mine gave me the tv for free because nobody he new could figure it out. I took it home, got lucky, and figured it out in about ten minutes.
jb
May 23, 2008 | Hisense TL1700 17 in. LCD Television
Televison & Video Logo
44 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
