Question about Xerox Office Equipment & Supplies
How we solve the fuser moduleR3 temperature fault in the xerox machin of modul 5755
When i start my xerox machine it show the message for fuser moduleR3 temperature fault and also give us the two options one to power down and second id ignorr error. please help me
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 41 Answers
Http://www.usask.ca/consumer_services/officecopiers/Replace_Fuser_Module_and_Ozone_Filter.pdf
if you have replaced the ozone filter also, ignore.
if not, shut down.
Posted on May 06, 2017
I have a problem of fuser module (r3) temperature error in xerox workcentre 5755
Can you feel any physical heat from the fuser. Sounds like either the thermistor that controls temperature or the lamp failed.
Sep 15, 2016 | Xerox Office Equipment & Supplies
I have xerox dc 250 machine, it shows fault code 077-909, paper jam at tranfer module but i checked there is no paper in it??
Hello friend, you are not alone !!!!
From http://www.copytechnet.com/forums/xerox/28764-dc-250-fuser-problem-077-909-a.html
At the bottom of the page it says.......
'what sometimes happens is that the sensor flag/arm call it what you will, twists out of its holder and jams, hence the machine thinks that there is still paper. the flag/arm should pivot freely'
Sep 03, 2014 | upbright AC / DC Adapter For XEROX...
Workcentre 7242, it was showing 01-333 fault at first but after correction another error 010-319 how can i sort out this error code
Error 010-333 for this machine is "Fuser Center Thermistor Overtemp (Over temperature) or Overheat Error"
Error 010-319 for this machine doesn't seem to exist (Yes - I know you've got it - hence the problem post.)
Error 010-319 for other Workstation models (7655, 7665, 7675, 7755, 7765, 7775) is "Fuser Heat Control problem *NOTE: This code must be cleared from Diagnostic Mode"
As regards fixing this error the Xerox website should be helpful
Feb 16, 2014 | Xerox Office Equipment & Supplies
Xerox Phaser 4500 printer has a U4 fuser code.
From the Xerox Phaser 4500 Service Manual (here), the main problems could be one of:
  • Warm-up failure - Fuser warm-up not complete within 110 seconds after
  • starting.
  • Cool-down error - Cool-down process not complete within 200 seconds.
  • Low trouble temperature - The fuser temperature drops to the low trouble
  • temperature (approximately current control temperature, minus
  • approximately 25°C).
  • High trouble temperature - The fuser temperature rises to the high trouble
  • temperature (approximately current control temperature, plus
  • approximately 35°C).
  • STS circuit open
  • STS failure - The heat rod remains on for at least 10 seconds after warm-
  • up has completed
It could be that your fuser needs to be replaced, but as you can see that code relates to a couple of problems, so even replacing the Fuser might not fix the problem.
If it doesn't even do the warm up checks it is likely to be the fuser because the other components such as STS failure and cooldown won't have had a chance to run..
May 03, 2011 | Office Equipment & Supplies
A fault or error has occurred. Code 010-327
Solution : Power the Machine OFF and ON CAUTION: Wait at least 30 seconds between powering the machine OFF and powering the machine ON. Damage to the optional hard disk could occur.
  1. Press the power switch to the OFF (O) position.
  2. NOTE: If the machine is equipped with the optional hard disk, the machine remains on for approximately 10 seconds, while storing files and preparing for shutdown. The machine then shuts down completely.
  3. Press the power switch to the ON position.
IF THAT FAILS TRY THIS NEXT:
Solution : Clear the Paper Jam Behind Cover A
  1. Open Paper Tray 5 (Bypass Tray).
  2. Lift up the Cover A release lever, and open Cover A.
  3. Remove any paper below the Fuser Unit by carefully pulling up and out.
  4. WARNING: Do not touch the Fuser Unit, as it may be hot.
  5. If the jammed paper is inside the Fuser Unit, lower the green A2 lever in the direction of the arrow to open the Fuser Unit Cover.
  6. Push down and rotate the green A1 lever in the direction of the arrow to feed the paper from the top of the Fuser Unit.
  7. NOTE: Do not pull paper downward during removal.
  8. Close Cover A until the cover latches.
  9. Close Paper Tray 5.
For pictures on this procedure please follow link: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=218,E=0000000002703126506,K=8100,Sxi=4,Solution=obj(1027)
Hope it helps!
Apr 22, 2011 | Xerox WorkCentre PRO 128 Copier
ERROR CODE 010-327
Hope it helps!
Apr 07, 2011 | Xerox CopyCentre C128 Black and White...
134 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
