Question about Whirlpool Ovens
I have whirlpool buil in oven it gave us s6f2 we replace. A new board it worked for 1 minute and then gave us code e1f2 what do we do now.thank you
    Dedicated:
    Visited the website for 20 consecutive days.
  • Whirlpool Expert
  • 84 Answers
An E1-F2 Error is a "ribbon cable not connected" Error.
It is a keypad related issue. Try cleaning the ends of the ribbon cable, the plastic strip which comes from the keypad and clips into the control board, lightly with a pencil eraser. ( http://www.fixyourboard.com/techzone/ovens/keypad_tail_clean/keypad_tail_clean.html ) Often, the contacts become corroded and will cause an E1F2 error code. Also double check that the ribbon cable is attached straight and secure in the connector. https://www.youtube.com/watch?v=YylBTJYBlGk - watch this video from the 1 minute mark. It will help you with the the ribbon cable. Inspect the ribbon for creases; if it's creased, an E1F2 error doesnt cease, or buttons do not respond, the keypad is faulty.
If youre looking for a replacement Whirlpool touchpad but notice that they're no longer manufactured, Ledgestone Technologies makes nice replacements.
http://fixyourboard.com/ledgestone.html
Posted on May 25, 2017
  • 279 Answers
SOURCE: RMC305PDD1 Whirlpool oven/micro
F5 is an error with the door latch, though the fact that it won't auto-latch may have tipped you off to that. The latch should be a replaceable part. First, check to see if it's just a bent latch. If so, you can probably bend it back with a pair of pliers, and you're done. If not, you can order a new latch assembly here: http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=589939&PPStack=1 Or, if you're not comfortable dismantling it, it shouldn't be that expensive of a repair, if you find an honest shop.
Posted on Sep 05, 2007
  • 84 Answers
SOURCE: Hi, I have a Whirlpool RBD275
Hello these control boards can be fixed quickly and reliably at www.fixyourboard.com. The cost is lower and the warranty is longer that new.
Posted on Oct 30, 2010
TheMobilian
  • 8220 Answers
SOURCE: Power failure and error codes
You could send that board to Bruce at fixyourboard.com and he would fix it for around 135 bucks and warranty it. I have a guide to late model oven repair manuals and more here
Posted on Jan 03, 2011
  • 32 Answers
SOURCE: I have a whirlpool double oven mod GBD 307PDS10.
Try removing the ribbon connector and cleaning the end that plugs into the microcomputer. You can rub it lightly with an eraser or use electrical contact cleaner on it.
Posted on Jan 13, 2011
sb1234098
SOURCE: Whirlpool range gas model GS445LEMS
I'VE the same problem lower oven don't work and the error is F03. My oven is new (It was included in the kitchen furniture I both from the outlet. What it can be? Maybe wrong installation?
Posted on Nov 24, 2014
I replaced circuit board in whirlpool combo microwave / oven, shows fault code F2, error code E1.
Did you get the circuit board from a trustworthy place?
It is a circuit board error. Did you install it correctly - right wires to right connections?
Control displaying F2 E1:
There may be a problem with the User Interface (Touchpad), or the associated wire connectors.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation
Have to go the long way to bring up the link by first:
e1 f2 whirlpool oven Google Search
and then click on https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjprvf2_7nJAhXKVRoKHe7zAmMQFggdMAA&url=http%3A%2F%2Fwww.whirlpool.com%2Fproduct-help%2Ferror-code-oven-f2-error-code-f2-e1%2FPH7389%2F&usg=AFQjCNFoDK8E-zgNHF3Kp4EoihGu1tbyEw
Dec 01, 2015 | Whirlpool Ovens
Kitchenaid superba failure codes e1,f2, and door is locked
Hi Bill:
The E1F2 error code indicates replacing the board. It is in the realm of possibilities that your new board is defective. If I were certain the board was good I would focus my efforts on tracking down an electrical fault.
The likely failure is the control panel; however it could be the control board.
Since you did replace the control board already, the problem is most likley a key pad that is sticking.
I added a portion of the technical data sheet in the image below. You will need an ohm meter to be able to check the key pad operation. I added the information needed in the image below. If the control panel tests OK, replace the control board, if it fails, replace the control panel.You may need a hands on tech to run these tests and diagnose and repair your oven. Or just buy the key pad controls. Check THIS LINK.
Here are the parts
Replacement parts for WHIRLPOOL KEBS208DSS8 ' AppliancePartsPros.com
Here is a manual and a tech sheet
https://secured.whirlpool.com/Servic...all%20Oven.pdf
http://www.servicematters.com/docs/w...%204451879.pdf
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 20, 2011 | KitchenAid KEBC208 Electric Double Oven
EO F2 whirlpool range
you have a bad keypad or a loose wire or ribbon,you can try unplugging it for 10 minutes and see if that helps or unplug it,remove the ribbon that connects to the keypad,plug the ribbon back in and see if that does anything,if not you need a new keypad. next time send the model number so i can help you betterF2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool Range / Stove / Oven Fault Codes#ixzz1dikBsooc
Nov 14, 2011 | Whirlpool Ovens
My Whirlpool oven is displaying E2 -F1- and won't turn on. What do I do?
The fault code indicates that the control has failed. Erc/ clock main board.
Before replacing try unplugging for 1 minute then turn back on if code reappears you need to replace the main control board.
www.appliancehelponline.com
Apr 09, 2010 | Whirlpool Ovens
My oven has gone out and gave this message before dying.(.E1 F2) I think that means I need a new panel but not sure. Can you help? Where can I buy the part if need be?
HI. This code is in reference to a unplugged key pad cable. Use the check list below to address this issue further.
CLICK HERE TO BE DIRECTED TO AN ON-LINE PARTS DEALER.
Dec 16, 2009 | Whirlpool GMC275PD Electric Double Oven
My whirlpool oven is displaying E6 and F2. It
Your cancel key is defective at this point. follow these steps below?
Aug 08, 2009 | Whirlpool RBS305PDS Electric Single Oven
After a power outage oven will no longer work
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirpool GBD307 - Display not working
We had the same error codes F2 E6. We were told to turn off the breaker to the oven for 5 minutes and then turn it back on and it will reset itself. We tried it and it worked! Whirpool wanted to send someone out on a service call. Thank goodness we didn't!
Mar 28, 2008 | Whirlpool RBS245PDS Electric Single Oven
Error Code E1F2
looked up tech sheet for this model and it states E1F2 - keypad connection not detected.. check connection, press cancel if returns in 60 secs replace keypad.then lists to replace control.
Mar 01, 2008 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
