Question about Electrical Supplies
My generator k450 onan keeps stopping - Electrical Supplies
crayzeetrayn
  • 837 Answers
SOURCE: Looking for an ONAN Emerald I GenSet generator manual
I have an account in the Buffalo NY area .. they can help you with this .. call 716-668-2666 after 9:00am EST tomorrow (sat)
Posted on Apr 03, 2009
erickg
  • 116 Answers
SOURCE: Oil type for Onan 4000 generator
SAE 15W-40 is what i used to use
synthetic? not sure about that one there may be oil pres switch that could give you a problem.
Posted on Apr 17, 2009
SOURCE: Have an Onan RV generator. WHat kind of oil do I
Standard 30W motor oil.
Posted on Apr 30, 2009
sal_kh_sab
  • 98 Answers
SOURCE: our onan generater runs but the power in the rv comes & off,
if ur problem is why does it get loud when the power is off...the answer is GLATOR calibaration..
if u have any further questions email me at sal_kh_sab@yahoo.com
Posted on Oct 15, 2009
SOURCE: onan microlight 2500 lp stop working
This type of generator has an oil-level sensor to prevent operation when it is too low. They burn oil pretty quickly, and 138 hours may have put you below the minimum. Check to see that the oil is filled to the right mark on the dipstick, and be sure it is on level ground when you do this.
Posted on Mar 20, 2012
My generator stop after few hours onan 2005 15.5 kl
Most likely it's either out of fuel or you have a plugged fuel line. If it's a gasoline generator used on a boat, I would check for water in the fuel line (water in the fuel line will cause the engine to begin sputtering and then stop altogether.
Mar 14, 2016 | Electrical Supplies
The generator surges and stops while rv is in motion.
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Oct 05, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
Onan marquis gold gas generator 5500 stops running after 5 minutes
Check fuel pump pressure, how long has it sat. What load is on after it stops?
Jun 10, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
Have a k450 onan gen will only run with choke almost closed
My K450 onan tag along was doing this and an adjustment of the governor set screw ( voltage +/- )cleared it up.
Oct 01, 2013 | Electrical Supplies
Onan 4000 generator
Check the rotor slip rings and brushes first, the rings should be clean and bright
Jun 24, 2013 | Watts Onan Portable Generator - 4000 ,...
Starts runs for a minutes quits but if you keep pushing the start button it keeps running
You say Guardian that is Generac???? Then you indicate Onan 4.0KY. If it is a Onan and it stops after you release the button there are a couple of things. 1 st check the brushes, and polish the rotor slip rings, check the resisitance of the rotor, the electrical harness plugs are tight. The control requires a voltage feedback while cranking to engage the PCB run circuits, if all those check out you have a bad control board.
Feb 15, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Have a 2.0kva-fr/26119 onan genorator which runs for 5 minutes and stops can you be of any help
If it stops after 5 minutes whether under load or not, and assuming the air filter, plugs, and fuel filter are new and or clean. The fuel pump is suspect. If it is in a motorhome try conencting it to an external fuel source that is at the same height as the generator. Then higher than the generator. If the problem persisits replace the fuel pump. Or just check fuel pump pressure with a gauge. BE CAREFUL do not use an automotive fuel pump Onan have special low pressure pumps, so use OEM part
Nov 13, 2012 | Onan Cummins 300-5332 Generator Switch and...
WHEN I START THE GENERATOR I HAVE TO HOLD THE START SWITCH ON TO KEEP THE GENERATOR RUNING.
The switch should be three positional.
The upper position is only for starting. Continuous running is in the middle (self holding) position. Lower position is to stop the generator.
If left in middle position it is not running you may have the switch bad, or the generator is stopped by low oil level.
Jun 03, 2010 | Watts Onan Portable Generator - 4000 ,...
Lost electric power to fuel pump on Onan Generator
there should be a fuse at the housing by the start/stop switch. if deisel then take the 10mm screw out of the coolant cap cover and check those fuses. verify power after. good luck.
Jun 05, 2009 | Watts Onan Portable Generator - 5000 ,...
Electrical Supplies Logo
35 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
