Question about Konica Minolta Office Equipment & Supplies
I have Konica minolta 210 copy print but paper no clearly pages
  • Konica Minolta Master
  • 6,595 Answers
Replace the drum and developer
Posted on May 06, 2017
  • 4 Answers
SOURCE: Streaks on printed page
You need to clean the printer. See your manual for instructions. It is probably dust on the laser lens
Posted on Aug 23, 2007
  • 214 Answers
SOURCE: Konica/Minolta majicolor 2300DL printer
pleas check the driver settings, maybe there is a setting fit to paper or something.
Posted on Jul 02, 2008
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Posted on Jul 19, 2008
  • 10 Answers
SOURCE: service manual for KONICA MINOLTA Bizhub 210/162
Swithc off the machine Press stop button and hold switch on the machine. problem will go.
Good Luck
Posted on Jan 07, 2009
Kevin Hayes
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
Konica minolta bizhub c203 blue data light blink copier not working
Have you cleared all the print jobs currently in the que and on the control panel. also disconnect your network cable power off the machine then on will it copy not print? data light blinking mean job is trying to run is the paper draw or by pass tray have paper an in the correct orientation landscape or portriat
Jan 24, 2016 | Konica Minolta Office Equipment & Supplies
Konica Minolta 1690MF causing Fuser Paper Jam error when printing color. Does NOT happen when printing black and white. (Paper is genuinely stuck entering the fuser). Why is the problem happening for...
I was wondering if the original poster of this problem found a solution. My printer does the EXACT same thing. B & W printing is perfect. Any color print jams in the fuser. The printer feeds the paper too far (from thin copy paper to cardstock) so that the top of the page is cut off. Konica sent me a new fuser but that did not solve the problem. Again, this only happens when printing any page that has color on it (even a document with only one letter in color). B&W printing is unaffected.
Aug 27, 2013 | Konica Minolta magicolor 1690MF All-In-One...
My copier is konica minolta bizhub 210 have problem error code M1. please help me solution.
My Friend You must do general service in your photocopier and then you must program your machine.
Sep 29, 2010 | Konica Minolta bizhub 180 All-In-One...
No matching paper size set paper on bypass tray
Someone has told the machine to either make a copy or print from a PC to the Bypass feed tray on the copier. If you are not trying to print something by using the bypass tray then just turn the machine off, then on again to clear the request from the copier. If you are trying to print or copy from the bypass tray then simply insert the correct paper size and direction into the bypass tray slot and the machine should automatically begin printing.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Konica Minolta DiALTA Di200 Copier
I connect the konica minolta bizhub 210 to my win xp system then i try to print but i can't the system show the message "failed to print" what is this .please help me
SOLUTION:- Follow these steps. 1-First of all take a usb cable. 2-Connect its one end to Bizhub 210 and the other end to your computer. 3-you will see your computer will show a notification " Found new hardware". 4-Now insert the printer Driver disc of Bizhub 210 in CD-ROM. 5-autoplay will show at the desktop 6-Now click on "Install Printer" 7-Follow the instructions and install the drivers. 8-when the drivers are correctly installed you will see printer icon of bizhub 210 in "Printer and Faxes" at control panel of your computer. 9-Now right click on this icon and click on "Properties" 10-now click on "PRINTING PREFERENCES" tab. 11-select Paper size, i.e if you are using A4 size in bizhub 210 then select paper size=A4 from the list. 12-now give a print command.ctrl+p. of any document. 13-printer will start printing.
if still having problem, then please do check the usb cable, it may be broken. if there is any other printers are installed on your computer which are not in use then remove them/ delete them. use konica minolta bizhub 210 as a default printer.
Jun 28, 2010 | Konica Minolta bizhub 180 All-In-One...
The print margins on my Konica Minolta Bizhub c203 cut off the bottom of my pages. how can I fix this?
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
May 20, 2010 | Konica Minolta Bizhub c203 Copier
Konica Minolta bizhub 210 error m2 appear on display
You can reset (M2) by reset clear data
Enter to service mode By Pressing :
Utility - clear -0 - 0 - clear -0 - 1
Turn OFF Copier and Switch it ON
Feb 28, 2010 | Konica Minolta Office Equipment & Supplies
Konica Minolta 2490MF - Paper size error
Need to set A4 size default on the printer driver itself.
Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
Click apply.
should be o.k.
Jan 13, 2009 | Konica Minolta magicolor 2490MF Laser...
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
