When viewing a DVD from an external player connected to the tv how do I adjust the picture to maximise the screen size my hi sense tvn is a model 50K3300UW thank you
    Sergeant:
  • 197 Answers
You may need to change the aspect ratio ... to change go to
1.
Press the [cog] button to open the Quick Setup
menu.
2.
Press the [>] button to
view the full menu settings
3.
scroll down to aspect ratio
4.
change to desired zoom format
Heres a link for your TV manual anyway...
https://ns323666.ip-37-187-156.eu/manuals/Hisense%20LED%20Television/Hisense%2050K3300UW%20LED%20Television.pdf
Good Luck!
Posted on May 06, 2017
My panasonic dvd player will not show the whole screen when in dvd mode
Hi
First make sure your Panasonic has 16:9 TV mode selected within its menu. Then try chainging the picture size on your TV. You didn't say what model TV you have. On my Samsung you would press the menu key then select picture, scroll down and select picture size. From hear you can select 16:9, wide zoom, zoom, 4:3. Try looking for picture size and selecting 16:9 on your TV.
Jun 03, 2014 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Cannot change the picture back to full screen. remote control want return the picture to full screen with the
Hi, Turn your TV on, select the menu and see if there is something in picture settings (wide screen or full screen) Try to connect a DVD player using HDMI cable. See if there is any difference.
Some DVD players will also have screen sizing. If nothing helps contact TV repair. Good luck
Jul 24, 2011 | Hitachi CLU-5713TSI Remote Control
No picture on dvd screen - has sound put on picture
hi
if there is any out put check it in external tv or monitor or lcd
if it is ok on external monitor your player lcd got problem 1- hi voltage that connect to lcd Fluorescent (has 2 wire)
2 - or Fluorescent is broken
Jul 29, 2010 | Cyberhome CH-LDV 712 Portable DVD Player
Picture too large for screen
It appears that on this television you can only adjust the picture size when you are using the twin picture feature. You must adjust the picture size with your other remote control. Since I do not know whether you are connected to a cable box or a satellite tv box or a blu ray player or a DVD player I cannot be very specific. On your other remote control you should had an hd zoom button, aspect, format, ratio, #, or etc. Those buttons change the picture size. The other factor determining picture size is the resolution the equipment connected to your tv is set to. This tv supports 1080i but you should also try setting the connected equipment to 720p or 480p or 480i. Also the connected equipment may be connected to your tv in two places so make sure you are on the correct selection using the tv video button on the Sony remote.
May 06, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Is there any way to adjust the screen image size? I recently connected a computer to the DVI input, and at 1280x720 there is quite a bit of overscan. Is it possible to reduce the image size?
Change the display settings on the computer desktop, try various sizes.
If using programs like word or firefox change display size with shift/mousewheel. Also change font sizes for best view. Don''t worry about resolution numbers, adjust for good picture.
Mar 02, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
How do you get DVD picture to show up? Power is
You DO NOT use "Channels" to View a DVD player it usually connected to the AV External input. via AV, Yellow, (Video) Red & White, (Audio) or Component Video, Blue, Red & Green. (Video) + Red & White (Audio). These are selected via the External Inputs.
Feb 18, 2010 | Zenith ZDA311 DVD Player
I am trying to view pictures and videos as well as music form my seagate 250gb expansion portable hard drive, through my dvd player via usb port. it reads "no data" is there anything that i can do to...
Most probably your harddrive is formatted using NTFS file system, while your DVD player only understands FAT32 filesystem.
Check the format of your drive by hooking it up to a computer and opening it's properties. And check your DVD player's specifications regarding USB support in it's manual or online, on manufacturer's website support section.
If indeed the filesystem type is the problem, you can do a couple of things:
1) Purchase a Flash pendrive of suitable capacity (these are FAT32 usually) and use it for viewing pictures & videos on your DVD player,
2) Move everything temporarily from your external hard disk to your computer's disk and re-format your external drive using FAT32 filesystem. Note, that FAT32 has some disadvantages, like a 2GB file size limit. And also remember, that formatting the drive wipes everything from it, so be sure to copy all stuff to your computer's internal drive first!
3) Check the possibility of connecting your PC to the TV directly and forget about the DVD player for viewing pictures and videos.
Dec 25, 2009 | Computers & Internet
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Small picture screen
on the remote there is a button called "View Mode" on the bottom right that changes the size of the screen. Try that. I don't know you would adjust it without the remote
Apr 24, 2008 | Mintek LCD TV Progressive Scan DVD Player
No image on tv using video card.
If you open the Radeon software utility, in the advanced screen settings you should be able to set "extend my windows desktop onto this monitor" to on for the TV screen. Then all you have to do is open your video player software and drag its window across to the tv, then maximise it. If you are having trouble doing this, some video player programs, especially dvd players playing dvds will not show the picture on the tv. If you want to watch .avi files then the best free player around at the minute is DivxPlayer - go to http://www.divx.com to download. Hope this helps, please ask again if not :)
Apr 06, 2007 | MSI RX300SE-TD128E RADEON X300, (128 MB)...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
