Question about Garden
Hi this pump is on my weed sprayer Thank you Doug.
Unable to remove lid from pressurized weed sprayer
you just have to hold down the trigger till all the pressure is drained off
Jul 30, 2014 | Roundup "" Weed & Grass Killer
I just want to know how much of roundup to put in the tank, you use air to disperse the weed killer?
Yes I do use it, you can put about 1qt of round up for every gallon of water. This should kill your weeds, for most precise mixing instructions check the bottle label.
Jul 28, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
I have 2 sprayers one is the Roundup Professional Sprayer the other is the all in one sprayer from Roundup - neither of them are working - what am I to do?
Um what do you mean by not working. spray not killing weeds, or sprayer itself not working???
Sprayers clog up if not cleaned after each use, try cleaning the entire sprayer.
Oct 06, 2010 | Roundup "" Weed & Grass Killer
Pump is presurized but no spray
Most weed killers and fertilisers either crystalise or turn to gel when left unused. Pull sprayer wand to pieces and run hot water through the hose and wand, they especially clog up at the spray tip and at the on'off control.
May 14, 2010 | H.D. Hudson 1 Gal Poly Deck Sprayer
I have the hudson eliminator sprayer and squeeze the trigger I just get one burst of spray and then a couple of drips. I do have it pumped up all the way. What is the problem?
IF your sprayer is full you should be good to go after 20 or so full stroke pumps
If it is not spraying unscrew the adjustable tip and clean out the little holes around the end
If you leave spray in the unit after using it it will get crudded up and plug up
Mar 08, 2010 | H.D. Hudson Hudson, H D Mfg Co 1 - 1/2gal...
Want to Kill Clover in Vinca Beds
vinca is pretty hardy..but check the label on weed be gone ..if its not listed i would try putting it on a FEW vinca plants and observe if they will know in 1-2 days.
May 31, 2009 | Ortho Chickweed Clover Killer Pint
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
