Back to:
Tags:
Zebra Stripe S600 Thermal Label Printer
Zebra s600
posted by christmaseve on Nov 21, 2007
paper/ribbon light flashing twice a second. can't get take up spool to run. done all cal procedures in the manual. still same. prints ok with direct labels but the paper/ribbon LED keeps flashing all the time. help!
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 02, 2008
FixYa! (100)
itdude4321
Rank:Master Master
Rating: 92%, 25 votes
The factory default setting for the S600 is thermal transfer (ribbon). depending on your OS there is a command that can be echoed to the printer to change the setting to direct transfer (non ribbon). It sounds like your printer thinks is should use a ribbon and in fact you are not using a ribbon. Here is the procedure I use to get the ribbon motor to turn on:
1. start with the printer turned off.
2. open the printhead, retract the ribbon completely onto the supply spool. leave the printhead open.
3. Press and hold the top three buttons (PAUSE, FEED and CANCEL) while turning on the printer. When the botom couple lights turn off release the buttons.
4. When you are left with the power light on and the printhead light blinking reinstall the ribbon and close the printhead.
The printer will autoclaibrate and run a sensor test.
Once complete the take up motor should have turned on and you should be able to use thermal transfer labels and a ribbon.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on zebra s600:
I don't want to Accept this solution
Can you Help with these Printers problems?
Hi: We are trying to print a label where the data being...
My label program is set to print to a 1"x3" (h x...
When I follow the instructions to adjust the "media...
How do you adjust the return roller speed on a Zebrs S600...
i am printing a format that need to print qty of 1000 pcs....
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
