When switched on the machine trips the house fuse
    Top Expert:
  • 12,104 Answers
What ever it is has a short or is seized
Posted on May 06, 2017
    Top Expert:
  • Washing Mach... Master
  • 44,233 Answers
Then I suggest you replace it . internal shorts can be fixed by qualified electricial people
The machine has been working well but recently when switched on now trips the whole house safety circuit.
Try plugging something else into the outlet socket to see if that throws the trip fuse. If it does then the outlet is faulty. Try plugging the washer into another outlet and see if it throws the trip in which case the machine is suspect.
Sep 23, 2015 | Washing Machines
Hoover 1400 AAA washing machine tripping house fuse
Possible that the control panel is short and so is tripping the fuse. Remove the connection to the panel and check if there is short , also remove the motor and check and this can confirm the case.
Jul 03, 2012 | Hoover Washing Machines
Have Fisher paykel GWL15 washer. Drain pump and fuse are good,pump not receiving 120volts.Have put machine into diagnostic mode still no luck. Help
see the diagram attached:
1) see the power from your house, c. breaker tripped or blown fuse.
2) test inside the machine the LID switch for open or defective see the diagram. if the lid switch is open the machine will NOT start.
God bless you
Jun 19, 2012 | Washing Machines
Washing machine trips electric when fills with water
From the symptons described, I would suspect that the heating element is faulty, disconnect the heater, and try it again, if it does not trip, then replace heater.
Please rate my solution.
Thanks.
Aug 15, 2009 | Washing Machines
When the machine is switch on from the main socket and than on from the machine on /off switch, it trip the whole house fuse box.I have change the 13amp.plug fuse, I cannot locate where the machine...
hi..It is next to the switch where you turn on.Open the
casing that stores the motor etc.Should be able to locate
it there,usually hidden inside a capsule.
check it out..
thank u..
kindly rate my response..
May 09, 2009 | Exercise & Fitness
Beko WMA1715S Tripping the fuses for house
Hi there......possibly couple reasons for this....(1) faulty heater.......(2) where the mains lead enters the machine it connects to a mains filter unit..this unit may have broken down and leaking to earth....try this area first
regards Sir Galahad
Mar 23, 2008 | Whirlpool LCR5232H Top Load Washer
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Kenmore 60 series washer
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Dec 07, 2007 | Kenmore 24032\24036 Top Load Washer
Zanussi turbodry w 1042 w
probably short to earth on the dryer elements. to check. take top off, disconnect dryer elements then run on dry program. if the trip stays in, then you have identified the fault
May 16, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
