Question about Kenmore Dryers
Need wiring schematics for Kenmore series 70 electric dryer model number 110 66702690
    Top Expert:
  • Kenmore Master
  • 49,235 Answers
What size resistor does a kenmore 70 series electric dryer use....?
none that i know of.what is the model number and what is the problem you are having?there are thermostats,thermal fuses element,timer and the door.look around the opening where you put the clothes in and you'll see a tag with the model and serial numbers,just need the model,it will start with 110. or 417.
Jan 30, 2011 | Kenmore 62602 Electric Dryer
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
May 19, 2010 | Kenmore 77632 Gas Dryer
Kenmore 70 series electric dryer not coming on
next time send the model number,if it's not starting unplug the dryer,on top of the blower wheel housing there will be a thermal fuse,if the filter is on top it's behind the back panel of the dryer,if the filter is inside it's in the front of the dryer,it will be near the duct that the lint filter slides into,you need to remove at least one of the wires before you read it out with a meter,it will be a 3392519 or a 3390719,these are the two most used thermal fuses.let me know what you find,if it is the fuse most likely you need to clean out the dryer.blow out the vent line i use a leaf blower if it's long,clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is
Apr 23, 2010 | Kenmore Dryers
Where can I get a manual for a Kenmore Series 70 drier
try sears .com,then click on parts,your model number is inside the door-mike
Feb 11, 2010 | Kenmore 62602 Electric Dryer
I have a 70 series. It runs but will not
most likely a fuse ,remove the back and you will see the heater box to your right,it is the smaller fuse on the box,most people replace both,you can get it at your local appliance parts store it is called a thermal kit,the model number is inside the dryer door-mike
Feb 06, 2010 | Kenmore 64742 Electric Dryer
Heating element or coils not glowing and getting no heat model is a kenmore 70 series and is electric
Bad Thermal High limt,
Bad Thermistor,
Bad heat element.
Need model number, located on inside of door, usually.
Oct 01, 2009 | Kenmore 62882 Electric Dryer
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
I need to change the electrical cord from a four wire to a 3 wire and i want to make sure i do it rite. i do not have a manual. its a kenmore 80 series electric dryer 220v model #11062812101
You can find a copy of the installation manual at describes how to connect as 4 or 3 wire.
Enter your model number (I had to delete the last digit), and make sure you enter Kenmore in all capital letters.
Feb 03, 2009 | Kenmore 62872 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
