Question about Philips Televison & Video
Should the speaker at the back of the Philips TV 55PUS718 be at an angle. I because on my set it is
Good sound no picture
Check and replace the back-light inverter board.
Sep 25, 2013 | Philips 47PFL5603D/27 Flat Widescreen TV...
If the front panel indicator lights, power is getting to your TV. Pushing the power button and getting no results indicates that something is wrong with the internal power supply
Jan 04, 2013 | Philips 47PFL5603D/27 Flat Widescreen TV...
Philips tv smokes
Do this only if you are a qualified service technician:
This problem can come if any moisture has entered or is formed inside the TV.
Switch of the power outlet, and remove the plug. Open the back cover and check what are the parts burnt visibly. If it is in the SMPS area, you may require a thorough check on the load and replace all the burnt parts by looking through a Service Manual. Anyhow, this might require attention by a qualified service technician.
Jul 11, 2012 | Philips 47PFL5603D/27 Flat Widescreen TV...
When my tv is turned on starts to smoke
Perhaps due to moisture build up inside. Anyhow, this might require attention by a qualified service technician.
Hi, I just bought a Philips HTS3540 home theatre system and I am having problems hearing the TV (Sony Trinitron) through the home theatre system. The DVD / CD / Radion work fine on the philips, but I...
Ok my situation is similar-i did exactly as u described here bobhifi and it worked initially . Then after some weeks suddenly the Aux display now shows 'AV1 Coax' and no sound is coming out of my LG DVD speakers except under Tuner and DVD modes. Pls help
Mar 28, 2011 | Philips Televison & Video
Just wondering where to purchase the EasyLink speakers for my Philips flat panel tv and how much they cost. Any info will be helpful.Thank you.
I tried to find this kind of speakers for a long time with no success. The reason is clear to both of us: internal speakers on Philips TVs **** and you want some external speakers and use the TV remote to control them. With this in mind I bought a cheap memorex ipod speaker-dock with its own small remote control, took everything out and installed in a nice looking black plastic box (about 2''x2''x4'') which now sits under my Philips TV. I got rid of the small and inefficient speakers in the ipod dock (which, by the way, gets 5V DC from a usb port) insert 2 1KOhm resistors and on the + wire (one for left channel and one for right channel) and use these speaker output as output towards a 2.1 computer speakers. I turned the TV speakers off from the TV menu and now I have a great sound to my Philips TV using the analog output at the back (red and white) and I can control it from the remote that came with the ipod dock. Hope this was helpful to you and hope Philips will review their policy about ''easylink'' which is the most idiotic thing I heard. It's sad they have this flaw with their TVs because they are indeed affordable, excellent products otherwise.
Feb 11, 2011 | Televison & Video
I had the 7 blinking lights problem. Replaced 2
Do a tv system over haul reset.Tries unplug,replug the tv an hour later.Go to the tv menu,goto AUDIO,go down to do the resetting,now the tv is back to factory setting.Go to the tv menu,than goto PICTURE,go down to resetting,to reset all the Tuner board setting,back to the factory setting.The audio,should be back now.Not,retraced from the speakers,wires back to the board connections,unplug,replug every connnetoins and replaced all the supporting components near the speakers wires are connected.
Jul 22, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips tv with sound going in and out
Try bypassing the set's speaker by running an external audio amp. I use my bookcase stereo for audio direct from the satellite receiver and turn the volume off on the TV. Sounds better this way! Could be the audio amp in the TV is going bad or the speaker may be bad and the TV's audio amp goes through a shut down cycle.
Feb 10, 2010 | Philips 30PW850H 30" TV
Pictures not lined up and angled
Sounds like your convergence is just out. First make sure the mirror in back is pulled out completely (if you have that model). Otherwise, there is a convergence feature on the menu that should fix it all.
Jan 03, 2009 | Philips 60PP9202 60" Rear Projection...
Connect my cinema speaker
The cinema speakers will need to have a receiver with a digital in connector to connect to the back of the set to the digital audio out. You will need to do the set up on the receiver the set will play it.
Mar 26, 2008 | Philips 42PFP5332D 42 in. Plasma...
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
