Amazon fire stick remote not woking correctly
The buttons are working but not doing the correct operation
SOURCE: REMOTE NOT OPERATING CORRECTLY
i had the same problem.i took the remote to the store where i purchased the system,and it worked perfectly on a display model .i realised then that it was sitting under my television at home.i moved the unit to another location away from the tele and the remote worked correctly.give it a try."barsue"
Posted on Jan 13, 2008
freetek
  • 5568 Answers
SOURCE: The fan is
These motors normally use a sintered-bronze, graphite embedded bearing. They are normally pretty reliable but they can get clogged with a combination of graphite and contaminants from the air.
I would first try getting some WD-40 or other penetrating lubricant on the motor shafts if you can see them. It would work best if the fan was running if you can safely get some spray onto the shafts' ends.
BTW, WD-40 is not a lubricant and evaporates fairly quickly so isn't good for sewing machines for example. A resin-free light oil such as 3-in-1 is much better; it doesn't evaporate fast or leave sticky residue when it gets old.
Posted on Nov 29, 2009
  • 1768 Answers
SOURCE: memory stick may not work correctly
the memory stick has to be formatted with the device it is to go into or it may not recognize it
Format the stick with the camera. If this is a Web cam then format the disk in Windows with a SD memory card adapter. Can be found on Ebay for small price
Posted on Apr 20, 2010
  • 17 Answers
SOURCE: I am trying to find a remote code for the Cox 7820
I have a Hannspree 42" LCD and I have the exact same problem, the code worked to control all functions except "Power On". I checked the Hannspree web site's support section, it says that their TVs will not work with a universal remote unless you have DirecTV. So why does everything work except to turn it on if they claim their TVs do not work with other remotes?
Posted on Dec 10, 2010
ronharvey_ll
  • 14 Answers
SOURCE: how do i upgrade soft wear to my amazon fire tv stick
URL for software updates and instructions
Should also be in your user's manual.
http://www.amazon.com/gp/help/customer/display.html/ref=ya_kindle_sb_swupdates?nodeId=200529680
Ron Harvey
Posted on Jun 24, 2015
Ireset my fire stick to factory and now won't work
hi there.
this is all i can find out.
How do I fix my Firestick? Hold down the Select + Play buttons together for 5 seconds to Restart the device. Restart the device: Settings > System > Restart, then once restarted unplug the power cable for 5 seconds then plug back in. I hope this helps you and hopefully fixes your Fire TV issues. problem with the Amazon Fire Stick and the remote.30 Sep 2015
SOLVED: Why won't my Amazon Fire TV remote work ... - iFixit
https://www.ifixit.com/Answers/.../Why+won%27t+my+Amazon+Fire+TV+remote+wor... Search for: How do I fix my Firestick?
or try this link for more help if you need it.
amazon fire stick not turning on Google Search
Nov 26, 2017 | Computers & Internet
Why can't I get HOME WITH MY FIRE STICK
Either your WiFi is not configured correctly on the Fire Stick or your WiFi is not working correctly in your house
Sep 05, 2017 | Amazon Computers & Internet
How do I open the remote to replace the batteries on my Fire Stick.
To remove the back cover of the remote and insert the included AAA batteries:
  1. Rotate the remote so the top edge is facing downwards.
  2. Apply pressure on the indent of the battery door and slide upwards. ...
  3. Pull away the battery door and insert the batteries.
  4. Slide the door back into place and push in to secure.
Amazon.com Help: Remote Basics
https://www.amazon.com/gp/help/customer/display.html?nodeId=201452700 Feedback
About this result
Amazon Fire TV Stick: How To Open The Remote's Battery Door ...
? 0:44
https://www.youtube.com/watch?v=F__fFr7nZOE Nov 30, 2014 - Uploaded by The App Store Chronicle
Here's how to put the batteries into the remote for the new Amazon Fire TV: Read our review of the Stick ...
Amazon Fire TV Stick Remote: How to Change Batteries - YouTube
? 0:54
https://www.youtube.com/watch?v=sBbTLXvWjzg
Jan 25, 2017 - Uploaded by WorldofTech
I thought I'd make a quick video on how to change the battery on your Fire Stick remote since my father said ...
Open Amazon Fire TV 2015 remote battery compartment - YouTube
? 2:35
https://www.youtube.com/watch?v=FyTHjZu3L6M Oct 6, 2015 - Uploaded by sfsilicon
then once it's open you push it down. it's still a little tough okay to about this this length okay. and then once ...
Installing batteries into Amazon Fire TV Stick with Alexa voice remote ...
? 0:40
https://www.youtube.com/watch?v=cZ1tidv478M
Mar 9, 2017 - Uploaded by Richard Robinson
You would think this part of getting your new device would be easy, right? Here's my easy to follow video ...
Amazon Fire TV Stick Remote Battery Replacement - iFixit
https://www.ifixit.com/Guide/Amazon+Fire+TV+Stick...Battery+Replacement/65199 If you follow the easy steps you will successfully change the remote batteries in your Amazon fireTV stick. Step 1 Remote Battery. Use the plastic opening tool to press into the seam between the remote and battery cover. Place two fresh batteries back inside the remote and slide the cover back on
replace the batteries on my Fire Stick Google Search
Jul 31, 2017 | Televison & Video
How do i know alexa remote for fire stick will work in my area
need to notify manufacturer for compatibility or regional area of operation
Oct 15, 2016 | Amazon Fire TV Stick with Alexa Voice...
Why did it suddenly stop working?
the "pat answer" is the magic smoke leaked out. all electronics work on magic smoke, once it gets out of a device, the device wont work anymore. OK smoke comes from burned out devices. Point the remote at a digital camera and watch through the view finder, does the led in the remote light up? (you cant see it with the human eye) if so next step. plug the dongle into the TV, select the correct input and point the remote directly at the window on the dongle and try to operate the fire stick, if it works, you may need an HDMI EXTENSION cable (male to female) to move the dongle to a position where it isn't blocked from the view of the remote. Also, can you operate it from your computer using Google Chrome and the correct firestick extension? (incase the remote isn't infrared operated)
Apr 03, 2016 | Amazon Fire TV Stick
Why can't I register it?
Fire tv stick can't register - Amazon.com
https://www.amazon.com/gp/.../ref=cs_hc_g_tv?...
Amazon.com, Inc.Received my new fire tv stick today. I'm able to get past the wifi connection screen. But registering it with my Amazon account is I'm possible. Tried over 50 times ...
Amazon.com Help: Basic Troubleshooting for Amazon Fire TV
https://www.amazon.com/gp/help/.../display.html?...
Amazon.com, Inc.Make sure your Amazon Fire TV device is registered to your preferred Amazonaccount. To verify your registration ... Can't Access External Storage. Note: External storage options are not available for Fire TV Stick. First, make sure you're using ...
Amazon.com Help: Can't Connect to Wi-Fi
Dec 26, 2015 | Amazon Fire TV Stick
How can I get my new Amazon fire tv stick to install? Every thing is plugged in correctly and powered up but the screen says it "Can't contact Amazon.com so try a new router or wireless network"
Check this first:
  • Connect your Amazon Fire TV device to one of these network or router types:
    • Open, WEP, WPA-PSK, and WPA2-PSK encrypted networks
    • B, G, and N routers on 2.4Ghz
    • A and N routers on 5Ghz
    • Hidden networks
  • Enable wireless connectivity on your Amazon Fire TV device. From the Home screen, select Settings > System > Wi-Fi.
  • Make sure you know your network password (if required). If you see a lock icon, a network password is required. This password is not your Amazon account password.
  • Make sure your Internet connection is not down. Restart your router and modem to solve most Wi-Fi network issues.
  • Do not place your wireless router or Amazon Fire TV device in a cabinet, as it impacts your Wi-Fi signal strength.
Also, try this for Fire TV Stick:
  • Use the included HDMI extender to optimize the location of your Fire TV Stick. The HDMI extender can improve your wireless connectivity by positioning your Fire TV Stick further from the TV.
  • Plug the power cord into the included power adapter and then into a wall outlet to ensure the device receives enough power for optimal performance.
Still having trouble?
  • Restart your Amazon Fire TV device. Disconnect the power cord from your Amazon Fire TV device for three seconds, and then plug the power cord back in.
Tip: You can also restart your Amazon Fire TV device with your remote. Press and hold the Select button and the Play button at the same time until the Amazon Fire TV device restarts (about five seconds). Or go to Settings > System > Restart.
May 06, 2015 | Computers & Internet
Accidentally turned off my blue tooth on my fire stick now my remote will not work
1,Before you pair an Amazon Fire TV Remote or Amazon Fire TV Voice Remote, verify that the remote is compatible with Amazon Fire TV, is within range, and has the required batteries installed. 1. From the Home screen, select Settings, and then select Controllers. 2. Select Amazon Fire TV Remotes, and then select Add New Remote. 3. Press and hold the Home button on your remote for five seconds. Fire TV Stick searches for the wireless signal of the remote. After the remote or game controller is discovered, select it from the list of discovered devices using your already paired, existing remote or game controller.
Apr 02, 2015 | Amazon Fire TV Stick
Accidently turned off blue tooth
Open Questions:
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
