What is the main problem cause growblug on???
Is my problem the Main Digital Board?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 19, 2016 | Hitachi 55HDS69 55 in. Plasma Television
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
Duet sport with an error code f01
A power glitch may have cause this error.
Try this; Unplug washer or disconnect power for two minutes.
If that doesn't work the main control board (CCU) has failed. replace it to fix the problem.
Hope this helps. Please be sure to rate my answer.
Thank you.
EEPROM ERROR
A communication error between the Central Control Unit (CCU)
and the EEPROM onboard the CCU occurred.
Possible Causes/Procedure
A power glitch may cause this error.
- Unplug washer or disconnect power for two minutes.
- Verify CCU operation by running a Diagnostic Test or any
cycle.
PUMP DRIVE ERROR
The pump driver fails to activate.
Replace CCU board.
MAIN RELAYS ERROR
One of the main relays is not working properly.
The relay might be soldered or always open.
- Replace CCU board.
Sep 09, 2014 | Whirlpool Duet GHW9150P Front Load Washer
What is the main cause of tooth loss?
In general, one of the main causes of tooth loss in adult is gum disease.
Feb 03, 2013 | Health & Beauty
System error E010
A specific revolution is not detected from the main motor rotation detection
signal (MLOK*), causing the signal to go '1'. (main motor fault)
Possible cause .
The main motor (M101) is faulty. The controller PCB is faulty.
1) Connector
Is the connection of the connector (J903) of the main motor and the
connector (J06) on the DC controller PCB normal?
NO : Correct the connection.
2) Main motor (M101), DC controller PCB
Try replacing the main motor. Is the fault corrected?
YES : Replace the main motor.
NO : Check the wiring; if normal, replace the DC controller PCB.
Dec 30, 2010 | Canon iR1600-2000 PS
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
Condensing tumble dryer tripping main power switch , power getting to power switch on the machine and buzzing when pushed then tripping at mains. any ideas?
found that moisture is getting to the timer control and causing mains trip!!!!!! need to dry out timer control then all should be well , aided drying with hairdryer, design flaw will cause this on most is70c i think.
Dec 23, 2009 | Dryers
I have gestetner 2722ztd copier when i replace the explosure lap the copier dispalys error code e1 on the screen .how i clean/remove the error massege ? please help me
Please check after replace the continuity the expo lamp,expo thermofuse.The E codes are displayed in the copy counter.To display both digits of the E codes press the enter key.
E 11 - Exposure lamp error.Possible cause: expo lamp open,expo thermofuse open,power supply defective,main board defective.
E 12 - Exposure lamp error.Posible cause:AC drive board defective,main board defective.
E 13 =Zero cross signal error.Possible cause:main board,power supply defective,zero cross line open or the conector on the main board is not conected correctly.
For reset turn ON/OFF the main switch unplugged wait 10sec and turn ON or:turn ON the main switch,turn DIP switch 101-1 ON/OFF and turn the main switch OFF/ON.The DIP switch is located in the rear parts into the main board.
Sep 20, 2009 | Gestetner Office Equipment & Supplies
Open Questions:
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
