Why is the power on button flashing and the DVD player not turning on?
Didn't use player for a while and now won't turn on. power on button light just flashes. unplugged for 10 minutes, pushed & held eject button while plugging back in. still nothing.
    New Friend:
  • 3 Answers
What type of DVD player do you have and what are you using the DVD player on
Posted on May 06, 2017
Need remote codes for dvd onn
most times you dont need codes just make sure dvd player is turned on then hold setup then when light lights up press dvd button then when light flashes hit the power button over and over till dvd player turns off then press enter
Dec 20, 2013 | Microsoft Windows Vista Ultimate Edition
I have a ripspeed DVD 720 when I wired it in the power button just flashed red for a bit and that's it it won't turn on or do anything?
Sounds like the power supply in the dvd player has failed. It works just well enough to turn on the led infront but as soon as you go to do anything it shuts off. This is common in cheaper dvd players. Unless you can troubleshoot electronics. Or know someone that can. Your best bet is to unplug the unit and disassemly and retrieve your dvd.
Oct 06, 2012 | Televison & Video
Try changing the input device to something you are sure, works such as a DVD player. If it is same, there are leaky/dry capacitors and/or dry solders. Please refer it to a qualified service technician.
Aug 02, 2012 | LG 42LC2D 42 in. LCD HDTV
Hi Tried already codes 147 & 256 w/Greenbrier
Hi Carlos,
First of all thank you for posting your question here at
My first advice is to confirm if your remote control is working fine by aiming the infrared emitter(sensor) directly to your cellphone camera, while pressing any button key, you can see the flash of an infrared through your camera indicating that the remote is in good condition. Watch the video below for more info.
You are entering the right codes for Apex DVD player. And this remote control has only two 3 digit codes for Apex DVD (147 & 256).
If the two codes didn't work to your player, I would advice you to do the auto code search mode. At this state, the remote control will automatically find the compatible codes available from its memory. Follow the steps below.
> Turn on the DVD player.
> Hold down [SET] and the device you want to set (AUX) so that the red LED light goes on
> Press [SET] again. The LED will start flashing
> Press [POWER] button continuously until the DVD player turn off
> Once the DVD player turned off, press the device key(AUX) you are working with to end the setup
Please be patient while doing this steps because the remote control will try to find the compatible codes listed on its memory.
If the auto search mode didn't work also, this is an indication that this Model no. is not compatible (no compatible codes) to the remote control.
Again, thank you!
Have a nice day and take care!
Kind Regards,
Dec 09, 2011 | RCA 3-Device Universal Remote
When we turn the power on iit only stays on a few seconds then turns off with the light flashing.. what does this mean and what can we do to fix it?? tks
I had the same problem. We watched a DVD, and the unit worked fine. We went out for ice cream, came back, and decided to watch a VHS. Instead of taking the VHS, the CST.IN light flashed and the unit cut off after a few seconds. We didn't have a VHS in the unit at the time. After cutting the unit back on several times without success, I looked online for solutions. One person said to hit 'eject' 5 times in a row, but that didn't work for my unit. Someone else said there was a lever inside near the power button that ejected the VHS, so I checked that out next. I washed and dryed my hands well, and used my finger to jiggle the white lever. Then I saw that the tray that the VHS sits on wasn't all the way forward, so I gently pulled and pushed it. I'm not sure which of the two actions worked, but my light is now a steady green and my unit is working fine now. I am so glad because we've had this unit for almost 10 years now, and I really didn't want to have to buy a new one! Good luck!
Jan 17, 2011 | Emerson EWD2202 DVD Player/VCR
My sony SLV-D300P suddenly would not turn on. The blue ps button/light just flashes, but no attempt to turn the unit on works. It was working fine, without any problems, until this one occurred.
I have the same problem -- tried power reset, tried holding stop button for 5 second reset, nothing works. If I push the power button or the eject button, the blue light flashes momentarily then goes out.
Aug 28, 2010 | Sony SLV-D300P DVD Player/VCR
Need code to Dish Network Remote Control for Sharp DVD Player DV-S1U
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Apr 20, 2010 | Sharp DV-S1U DVD Player
this is from your producer: Product Description ? BASIC OPERATION OK ? everyone knows what a handheld remote control unit does for your home electronics. You can control your basic four (4) components: TV, DVD player, VHS player, Cable or Satellite tuner. Setup is simple for these basic 4? put in the batteries, look up the manufacturer of your component (Mitsubishi TV) and note the possible 3-digit ?program codes?? turn on the component, press the remote control?s PROGRAM button until the light stays red, press the component button (i.e., TV), enter in the ?program code?, and press the ?power off button? ? if the component (i.e., TV) turns off: you are programmed! If the component (i.e., TV) doesn?t turn off, then repeat the sequence using another of the manufacturer?s program codes until it does. Easy ? took me about 3 minutes to program my old Zenith TV (in the bedroom), my SONY DVD player, and my Mitsubishi S-VHS player. No problems at all. HOWEVER, in case you do run into a component for which the ?program codes? don?t work? you can go through a sequence to self-identify the coding. While I won?t go into it here, it is only slightly more time consuming than the other method. As my codes worked fine, I can not address this aspect, so I won?t make a claim we didn?t test.
Jun 06, 2007 | GE HO97685 Remote Control
I change settings
The reset on my son's CH-DVD 300 was the stop button. All i did was turn on the dvd player and then held in the stop button for 10 seconds. And badow, I have video.
Nov 28, 2006 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
