I have a w1712 front loader that doesn't seem to completely spin dry the clothes. I need to put every wash through a separate spin cycle at the end to get the clothes so they are not super wet? Roger
  • 1,138 Answers
Try turning the spin speed up if you can the pump could be dodgy try on a different cycle
Posted on May 06, 2017
Why does my washing machine not complete a rinse & spin cylcle?
is it a top loader? if so, older top loaders do not have a balancing function so you must evenly distribute the load.
Oct 16, 2016 | Washing Machines
Our washing machine is being placed in storage, but we can still hear water in the bottom of the machine (not in the tub). Is this normal? It seems like we should get all the water out before storin
If its a front loader there is liquid inside the drum put there by the manufacturer for balance and stability when the machine is running, that's probably the water sound you hear when you move it around.
Feb 16, 2015 | Kenmore Washing Machines
Miele W1712 honeycomb care front loader the door will not unlock after cycle has finished, it has been 24 hrs
Try unplugging the washer's electrical connection, wait for about 20 seconds then plug back in. See if that resets your cycle to Start mode from an unfinished mode. If not, see if you start another cycle, such as a spin to complete any draining of water. It might have blockage that is keeping the water from draining thus thinking the cycle is not over - or- a bad sensor not telling the computer that the cycle is over and it's OK to release the door lock.
Nov 24, 2014 | Washing Machines
Hi We have a miele condensor dryer. It is working fine except that you have to put clothes through twice to dry. It seems to cut short the drying process and then you need to put the machine back on...
The first thing you need to check is your vent system. If your dryer vent is clogged with lint, the dryer has a hard time expelling the moisture.
Then, if the vent is clean, try using a timed drying cycle instead of a sensor cycle. If your clothes get dry using the timed cycle, then you might have a sensor problem.
Also, make sure your wash machine is properly spinning out the clothes. I saw that once before where the customer thought the problem was with the dryer, but it ended up being their wash machine's ATC switch adding water at the end of the spin cycle.
Nov 01, 2014 | Dryers
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
My wmd 1050 front loader won't continue with its cycle. It fills, does a few turns, empties and finishes., all in a few minutes. It doesn't seem to wash but will spin dry when manually put on a spin dry...
Are you sure the machine is not overfilling? next step after filling would be water heating - sounds like a water heating problem if machine spins and drains ok. Maybe a coin in the wash has punctured the element? water heater can be test for insulation / continuity if you have a high voltage tester, or remove it and examine if not by releasing the nut and pulling firmly. If it is scaled, holed or black replacement will be needed. Sometimes socks or clothing stuck on the heater cause localised overheating that will make it fail.
Dec 16, 2017 | Electrolux Washing Machines
Will not spin out at end of cycle
if there is till water in there the drain pump may be need to use a wet dry shop vac and attch it to the end of the drain hose then drain out the water. remove the two screws on the bottom of the washe pull down the front panel. then remove the two hoses on the pump and look for the blockage.i hope this helps with your problem.good luck let me knwo how it goes
Jan 23, 2010 | Frigidaire FEX831CS Top Load Stacked...
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
