Question about Coby Televison & Video
My coby tv/dvd model tf-dvd1595 has sound but no picture.
SOURCE: wrong disc error coby poeratbel
Dale una limpieza al laser si no funciona checa la tira flexible que conecta el laser con la tableta tiende a quebrarse por el uso excesivo.
Posted on Mar 17, 2008
  • 3 Answers
SOURCE: Coby TF-DVD7050 no video.just a blue screen
you simply need a new screen
Posted on Jul 20, 2008
  • 89 Answers
SOURCE: Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Posted on Jul 28, 2009
  • 133 Answers
SOURCE: my coby tv remote is not working, for my coby TV model Tf-TV1913
There are no universal remotes compatible with any of Coby's televisions. You can get a replacement original from
Posted on Jun 04, 2010
SOURCE: Replacement battery for Coby TF-DVD7005 DVD Player.
need a coby rechargeable batt pac. Where can I get it and how much is it?
Those units are bottom of the barrel. Sorry. You and I have already spent more time on it than it is worth. Check power, and switches. Ewaste. Invest In a Panasonic or other major brand. You will enjoy the picture a lot more also. Check Fry's or Ebay.
Nov 16, 2013 | Coby TF-DVD7005 Portable DVD Player
Problem with Coby TF-TV3217 32 in. LCD TV
sounds like there is a fault with the tv or there is a bad cable.but you have tried av cables to. I would use another tv for time being. capacitors in the tv may be week and need changing. if its been used alot by i mean on and off a lot then it will wear out quicker than normal use. and the startup wear components out a lot quicker than normal home use.
May 20, 2013 | Coby TF-TV3217 32 in. LCD TV
TV turns on, but screen goes black after a minute. Audio only after that. Coby TF-DVD1972 19inch LCD DVD combo
The LCD inverter board is dead.That why u not getting a backlight to the LCD screen to get a picture.Tries websites like, to buy a refurbish LCD inverter for the replacement.It a long board.
Jun 07, 2010 | Coby TF-TV1901 19 in. LCD Television
Does this tv have a digital tuner or will I need a converter box?
Coby tf-dvd1540 tv
No ATSC tuner in this TV. You will need a converter.
Product Features
  • 15-inch flat-panel TFT LCD TV with built-in side-loading DVD player
  • Standard 4:3 aspect ratio, native 1,024 x 768 resolution
  • Plays DVD, CD and recordable MP3 music CD-R/CD-RW
  • Built-in NTSC TV tuner lets you switch between DVD and terrestrial broadcast viewing
  • Stereo speakers with 3 watts per channel; includes full-function remote control; onscreen display simplifies setup and operation
Technical Details
  • Brand Name: Coby
  • Model: TFDVD-1540
  • Display Technology: TFT active matrix
  • Display Size: 15 inches
  • Image Aspect Ratio: 4:3
  • is_hdtv_compatible: N
  • speakers_included_description: 2 speakers
May 13, 2009 | Coby TF-DVD1540 15 in. TV/DVD Combo
My portable COby DVD player stopped working. DVD rotates when I put it in by screen remains black... With TV out option sound comes out and picture/sound shows on TV once I connect it to DVD
I have had some very bad luck with Coby products and am sorry to hear that you have too but please make sure that the connector jack is clean and functioning properly. The connection jack has a device inside it that knows when the plug is inserted and then sends the audio and video out to the TV. If the connector is really dirty it could be that the connector is not working properly.
There isn't a lot more to look at unless there is some obvious problem with the screen such as a loose wire or a broken hinge.
Feb 26, 2009 | Coby TF-DVD8107 Portable DVD Player with...
No Sound when playing a video game on Coby Pertable DVD player
Do you have the audio plugs in the proper spot? The red & white audio plugs from the PS 2 need to be plugged into the audio in jacks on the portable dvd player in order to get sound. Should match up red to red; white to white for sound, yellow to yellow for video. Hope this helps.
Feb 03, 2009 | Coby TF-DVD1023 Player
Channels above 10
maybe s similar to TF-DVD1540.
first press "-/--" (choice for one or two digits), then press the number or two numbers.
Nov 15, 2008 | Coby TF-DVD1540 15 in. TV/DVD Combo
Coby TF-DVD1540
Yes, use a VGA Cable and conect it. just select source to pc.
May 04, 2008 | Coby TF-DVD1540 15 in. TV/DVD Combo
Televison & Video Logo
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
