Question about Welding Tools
How do i convert 4.5scfm @ 40psi to see if it will supply a plasma cutter needing 4.5cfm @ 80psi???
    Top Expert:
  • 51,255 Answers
Wind up the pressure regulator to 80 psi
Posted on May 06, 2017
I purchased a I60 Plasma cutter and I don't have an instructions manual. Can I download one?
Plasma Cutting Guide - Plasma Cutter Tips - The Eastwood ...
www.eastwood.com/plasma-cutting-guide-plasma-cutter-tips-plasma-cutt...
Check out Plasma Cutting Guide at Eastwood tech library to know about ... hasapproximately 25 amps of output, a 1/2" machine has a 50-60-amp output, while ...When buying a plasma cutter, the manufacturer should provide cutting .... Finally, follow all safety tips and guidelines that are detailed in your instruction manual.
How To Select And Operate A Hand-Held Plasma Cutter ...
https://www.millerwelds.com/.../how-to-select-and-operate-a-hand-held-...
The actual process of operating a hand-held air plasma cutter unit is relatively .... If you only have 115V primary service, don't worry. ... 50 or 60 Hz. This means you can plug this plasma cutter in anywhere in the world. ... If you opt to purchase such a unit, position it as far away from the particle ... Plasma Cutting Roller Guide.
Best Plasma Cutter Reviews 2015 - AIR TOOL GUY
Dec 27, 2015 | Welding Tools
Mishto plasma cutter won't work
You need to check the power supply, the air pressure switch.
Mar 29, 2013 | Welding Tools
Simadre plasma cutter
Green yellow would be earth ground. Confirm it with a test meter.
Solid green and solid brown would attach to the 240 hots- no return white.
Jun 01, 2012 | Welding Tools
Green light flashes
always remember the ground...
have a big air supply. small compressors can not keep up and machine stops cutting.
Nov 24, 2011 | Miller Spectrum 375 Cutmate Plasma Cutter...
Kit ni hawa bhare plesure me . rear aur frount me
here is a chart for you ... depending upon total weight along with your , choose a pressure value.
weight 50kg 75kg 100kg
Road bike = 90psi 110psi 130psi
Mountain bike/hybrid
(hard surface use) = 65psi 80psi 95psi
Mountain bike
(off-road use) = 30psi 40psi 50psi
Mar 02, 2011 | Cycling
I'm interested in buying a used Pro Cut 80 that on the inside of welder says 460/ 580 volt ? connection. Can this welder be converted to 240 volts? What if its connected to 240 volts. Will it work? Thanks
I doubt it. You will need the model number to determine for sure. There are two models that are listed for 460/580 with no mention of other voltages. Get the exact model number and you can download a manual at: http://www.mylincolnelectric.com/Catalog/lecooperatorsmanualsearch.aspx
Aug 23, 2010 | Lincoln Electric - Pro-Cut 80 Amp Plasma...
Spectrum 2050 plasma cutter . Cutter blows air and stops when trigger is pulled no pilot arc or any cutting when trig is released air flows again and stop after 10 sec new tips was working the day...
Check compressed air pressure is in limits otherwise unit will cut out. Try adjusting the pressure up. also make sure the supply pressure is correct as it may not be your plasma cutter at fault.
Jul 30, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
Our 2050 plasma cutter will not start,we have electric to it,we had a employee change air supply at the time it was working great then when he changed air it had water in line what can we do to find out...
Clear the lines out let the plasma dry out for about 3 weeks then get more air an blow it out agen and try too use it or if you just bout it take it back if thears a warrenty thares all ways a 90 day warrenty on them and if your lucky a two year an make shure you have proof you bout it
Dec 16, 2009 | Miller SPECTRUM 2050 PLASMA CUTTER NR NEW...
Hobart 250 a keeps cutting off the flame
If you have a bad air supply then the moisture in the air will cause the torch to cut off and the cut quality depends also on air supply,speed,metal thickness and condition of your consumables,meaning your electrode and other related parts in the torch tip.Hope this helps
Jan 05, 2009 | Miller Hobart AirForce 250A Plasma Cutter ...
Welding Tools Logo
159 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
