Question about Ovens
We have replaced the fan oven element and the oven still doesn't heat
    Master:
  • 604 Answers
Switch is bad
Posted on May 06, 2017
Testimonial: "Which switch"
Hoover bottom oven not heating up
Hoover Oven not heating? How to replace a Hoover fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 14, 2012 | Ovens
Hello, We have a bosch hbn7052gb oven. The lower oven flashed and now the bottom oven doesn't heat up, everything else works ok the fan, the top oven etc. Can you advise what needs...
Bottom element has failed. Probably 2 screws at rear to remove & replace. Disconnect fast-ons from rear - extract element - replace. best to get electrician to do this - simple job & element should be inexensive. - Rick
Jun 11, 2011 | Bosch Ovens
Hi. My oven doesn't heat up after I've used oven pride on it. It's a New World DF 90 make. Everything else works, the fan, grill and hobs, but not the oven itself.
Unfortunately, it sounds like your heating element broke. Suggest using an ohm meter to make sure of that before you replace.
The good news is that element is pretty easy to replace and not very expensive either. Just make sure to trip the circuit breaker BEFORE you attempt the remove and replace.
Jun 05, 2011 | Ovens
My sarena electric oven is not heating up
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for Necht element How to Repair Home Appliances
May 17, 2011 | Ovens
TOP OVEN WORKS OK BUT BOTTOM OVEN DOES NOT HEAT UP
There are a number of reasons why you may find that your oven doesn't heat up, and troubleshooting oven heating elements is not too complicated, so you should be able to manage this in a few hours. When you are trying to decide what is the cause of your oven not heating up properly, you should be able to identify the different problems, and also understand how to repair the oven without too much difficulty. If you find a lot of problems, then you may need to provide a different solution, for example replacing the heating element and fittings completely.
Heating Element is Broken
This is perhaps the most common cause of the oven not heating up. The element inside the oven will not become hot if the electrical connections are damaged, or if the element itself is not working. The heating element can be removed and replaced easily, and this is perhaps a very good idea if you have any problems with the heating system of your oven. Test the heating element by firing up the oven with the door open, and your hand close to the front of the element. You should be able to feel it warming up, so if it doesn't, take of the screws which hold it in place, and then unplug the connections. You can take the heating element to a store and they should be able to replace the part for you.
Hope this help in solving the problem.....
Main oven light works fan runs but oven doesn' get warm
ROSIERES Oven not heating? How to replace a ROSIERES fan oven element
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for ROSIERES element How to Repair Home Appliances
May 23, 2010 | AEG U3100-4 Electric Double Oven
Beko dvc62 main fan oven stopped working, doesn,t get hot but fan still works, it tripped circuit breaker and hasn,t worked since, peter
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer
Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 14, 2010 | Ovens
It would appear that the main oven element is not working. I had a power cut whilst using the oven recently and have only just realised that the oven will not heat up. Everything else is working ok. If it...
If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
To replace: Turn off power!!
-Remove side racks from oven, then remove rear panel.
-You should now see fan blade and fan element.
-You need to remove oven from cavity, then remove rear outer panel.
-You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
Aug 10, 2009 | Smeg Ovens
Fan but no heat
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please
Mar 14, 2009 | Smeg SE280X Stainless Steel Electric...
Smeg SNZ91MFX1 Fan heating not working
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Jan 01, 2008 | Smeg SE250XUK Stainless Steel Electric...
Ovens Logo
35 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
