Where do I find the red thermostat light? - Heating & Cooling
Why light blinks then goes off when switch is still in the on position
The thermostat in the iron controls the temperature of the iron. The red light indicates when the power applied to heat the iron which is set by the temperature dial on the iron. When it reaches the correct temperature the thermostat turn off the power and that is when the red light switches off.
Jan 15, 2012 | Irons
I cannot get power to bring the induction fan on. I have a solid red indicator light.
Solid red is normal, no call for heat. Try jumping (in the FAU) between the R and W thermostat terminals on the circuit board. Be sure when you do that the interlock safety switch is on delivering power to the heater, the red light is on. Also be careful not to touch the R side to any ground, it may blow a fuse within the circuit board.
If that works, try jumping from the thermostat itself (remove the thermostat and jump the red and white wires) if that works, your thermostat has failed... replace.
If jumping the terminals in the FAU fails to run the inducer fan I suggest you call a technician, as something in the circuitry has failed and will probably need to be replaced.
If jumping from the thermostat wires fails, then the wire is broken somewhere between the thermostat and the FAU (either by literal break, or a signal interruption... like a security system or zoning system).
Good luck.
Oct 05, 2011 | Goodman GMS90703BXA Heater
My la cornue oven not heating, turn 1st knob to function desired and then temperature knob to desired temp but oven does not heat up
First thing should be to make sure the top selector switch is not set to the optional Pizza element.
Make sure the power to the unit is OFF. Also keep in mind that the following tests should be done by a qualified appliance specialist. To find one near you, contact the La Cornue Service Center @ 877-522-6768
Is this the first time using the oven? If so, make sure the overall power to the range is 240 volts. This can be checked at the main terminal block.
If your model has three indicator lights and the red light is illuminated, then it is likely the hi-limit thermostat has tripped and you will need to reset it. The reset switch is located underneath the cycling thermostat. To access this, you will need to remove the front fascia. Please note: The original safety thermostat is no longer available. Use current safety thermostat (reference: 06ELTS01). If your model has only two indicator lights and the red light is illuminated, that means the oven is heating up. If the red light is not illuminated when the thermostat is set at the desired temperature, then check the hi-limit thermostat.
Power relay/contactor on the back of the unit should be checked. It
Jan 06, 2011 | La Cornue Grand Maman Dual Fuel (Electric...
2 0f the trhree tiles are not turning bright red.
This heater is a three stage heater...how many tiles are burning is dependent on the setting of the thermostat... (the knob on the top) and the temperature in the room...
If the setting and the temperature are close then the heater will only burn one tile....if the temperature in the room starts to drop then another will light.... and if there is a wide difference then the three will light....
If you have a room that is warm already then you may not be able to get all three to light as the thermostat may not go that high...
If the room is cool and the other two tiles are not lighting then either the thermostat has gone bad or the gas valve is bad.... troubleshooting that is very difficult....it is best to replace the thermostat first and then if that does not work either replace the heater of the gas valve... however the gas valve will cost very nearly as much as a new heater...
heatman101
Nov 07, 2010 | Vanguard International Infra Red - Medium...
I HAVE A 45000 BTU GOODMAN FURNACE RED LIGHT
There may not be a call for heat being registered by the control board. Take the R and W terminals on the control board and put a jumper between the two. If the heater starts, you have either a broken thermostat wire or a bad thermostat or connection.
Jan 25, 2010 | Goodman Heating & Cooling
Trying to reconnect an old thermostat. The wires on the thermostat are yellow, white and there is a jumper wire between two points. There is a G which I presume is ground. The wires coming in are white,...
G (green) = fan
w (White) = heat
y (yellow) = a/c
r (red) = power
Connect white to w terminal and red to r terminal on t-stat since we know they are right, then touch one green to red r terminal if fan starts that is G or (green). If a/c Outside unit starts then that one goes to y terminal on t-stat.
Nov 03, 2009 | Heating & Cooling
Drayton Digistat SCR thermostat not working.
Go online to www.cheapboilers.com who deal with this type of boiler. It would be very difficult to troubleshoot this boiler with the information supplied. I hope this will be of some help to you.
Sincerely, Shastalaker7
They should also be able to get you a manual for your thermostat.
Oct 27, 2009 | Heating & Cooling
I have the same problem.
transformer going bad or bad connection check for 24v ac from red to common batteries only for mem storage and if no common used at stat to hold program red to g fan red to y comp
Jun 09, 2009 | Honeywell Programmable Thermostat Heater
Replaced thermostat - still getting red light
sounds like a faulty sender unit not passing the right voltage which is causing the gauge to read high
May 30, 2009 | 2001 Oldsmobile Intrigue
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
