Question about Coffee Makers & Espresso Machines
I have de- scaled my machine twice now since the de-scale light will not stop flashing, and tried to re-do the water hardness test, it will not let me, red descale continues to flash.
    Master:
  • 604 Answers
Pour a carafe of vinegar into it and turn it on.do that 3 times then rinse it
Posted on May 06, 2017
Both lights on my older model machine won't stop flashing
Try holding both buttons down while you turn on the machine - hold down till they stop flashing, usually 2 - 5 seconds. This resets the machine to its original factory settings.
Oct 11, 2014 | Nespresso Coffee Makers & Espresso...
I de-scaled my maker twice , it worked for one day then the de-scaled light came on again, now the water will not run through the machine at all
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 28, 2011 | Keurig Elite B40 Coffee Maker
De-scale light came on. What do we do???
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Jan 02, 2011 | Keurig B100 Coffee Maker
De-scale message appeared. Followed instructions in manual. Product not working. Everything smells like vinegar. Now what???
you should have done whats below, it may need to be done twice...last but not least..you have to put more fresh water in to remove the taste
Dec 23, 2010 | Keurig Platinum B70 Coffee Maker
There used to be enough steam to froth milk for 2 cups of coffee, now I have to turn the knob off, to let the machine build up steam 3 times too get enough froth for 1 cup of coffee.
This a
clear problem from scale builds up in the boiler. The scale layer is acting as
an insulation layer which is reducing the efficiency of the heating element to
the boiler and also reducing the water capacity thus also the steam production
capacity.
So you
should first try to de-scale your machine three four times with intervals of
three days from each de-scale. Try also to perform the de-scale very slowly
like when you will flash the water solution from the water reservoir take about
30 minutes why drawing a coffee cup every five minutes. With this way you have
very good chance to remove a lot of scale and you machine heating efficiency to
be increased. If after the above procedure you have no difference then you need
a new boiler which is one unit with elements and sensor.
Here below we
have a link with more information for your machine which can help you.
http://www.partsguru.com/SaecoMagicDeluxeSuperautomatica.html
Dec 23, 2010 | Saeco Magic De Luxe Espresso Machine
Two blue lights stay on, neither activate the water.
if you are talking about the flashing blue lites, that means tank need waters..if you have water in it..
re seat the tank.. also
Dec 22, 2010 | Keurig Elite B40 Coffee Maker
My machine was ready to brew a cup. At first it put out a few drops and stopped. Then I turned it off and back on. This time it had a weird sound but put the water through the pod but the water did not...
64
456
Dec 17, 2010 | Keurig B50 Coffee Maker
We only use filtered water in our machine and were wondering if we still have to de-scale it as often as it requests. We have been told that it works on a certain amount of coffees and then requests a...
Hi
Yes you should descale on a regular basis. All water except distilled and RO water have some minerals in it, just some waters have more than you want. Distilled and RO water has their draw backs like the are on the acid side and can disolve the metal parts of your boiler. They don't taste as good as most water. Water that taste sweet has calcium that needs to be removed, this is why we descale on a regular basis. You can set you machine to tell you when you need to descale and it will also descale for you, so you don't have to stand in front of it while it does so. I prefer to set my water hardness to the max.(4) all lights lite on a Palazzo to prevent what I have seen where a Palazzo was so plugged with scale no water would go through it. These are great machines if you take a little care. Descaling is all I do to mine. I lubed my brew group when I first got it. and just rinse it twice a year.
Oct 13, 2010 | Solis Palazzo Espresso Machine
Water line on intermittent flash after trying to clear the steam
I was able to fix the problem after reading your post.
I had lost my manual and found a copy of the instruction manual online. http://www.espressoitalia.com.au/viewStory/Coffee%20Machine%20Manuals
I read the instructions for de-scaling (page 15) and followed it EXACTLY the way it instructed me to.
The entire process took roughly 2.5-3 hours. I set an alarm to remind me to re-dispense the solution again (for 15 seconds) every 10 minutes.
I'm not sure if you skipped a few steps(I did the first time I went through it). If anything, the trick might be to hold the hot water button for 6 seconds to disable the de-scaling alarm.
Your de-scaling alarm probably hasn't been de-activated. ( To make sure I held the hot water button for about 15 seconds)
Jan 28, 2009 | Saeco Odea Giro Plus Coffee Maker
Coffee Makers & Espresso Machines Logo
37 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
